[Problem] No Battery Charging of HP ZBook 15 G5 after BIOS Flash
have an HP ZBook 15 G5, motherboard model: [DA0XW3MBAG0 rev g) and I am facing a charging issue after reflashing the full 32MB SPI chip (MX25L256) with an external programmer. I rebuilt and flashed the complete SPI image (descriptor, ME, BIOS region). Because iy was bricked, original is lost. After flashing, the system boots normally and is fully functional. However, the battery no longer charges. I tested with two different original HP batteries and two original HP adapters (150W and 200W). The behavior is identical in all combinations. In HWiNFO the battery is detected correctly, capacity and cycle count are readable, and the status shows “Charging”, but the charge rate is 0 W. The adapter wattage is detected correctly. On cold boot I sometimes get a “Battery not detected” or “Please insert battery” warning, but once inside Windows the battery appears normally and SMBus data is readable.
If I charge the battery in another laptop and then insert it into this ZBook, the laptop runs normally on battery until it discharges. Once the battery is empty, the laptop shuts down immediately and cannot recharge it. This confirms that the discharge path works correctly, but the charge path (adapter to battery) does not.
After the SPI rebuild, I also performed an official HP BIOS update from within BIOS, which updated the EC firmware to the latest official version. The problem persists.
Since discharge works, SMBus communication works, and both original batteries and adapters behave the same, this does not appear to be a battery compatibility issue. The charge rate remains at 0 W at all times. The system never actually pushes current into the battery.
My question is whether it is realistically possible that a wrong descriptor configuration or strap configuration from the full SPI rebuild could affect only the charging path (charge enable logic) while leaving discharge fully functional, or whether this scenario points much more strongly to a hardware issue in the charging circuit (charger IC, charge MOSFET, ACDET/ACOK line, current sense path, etc.).
Any guidance from someone with experience on based ZBook G5 boards after full SPI reflash would be appreciated.. thank you so much
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title shortened
Not likely
Most liekly
It hapened just after flashing dump so i was pretty sure that is something wrong with file.. is posible that i scratch some power tracd or conector .. would you be willing to look in to my bios file if you see somethin wrong . I am new to this and still learning.
No, i dont know the source and it’s not my work or time to lose, if it boots and CSME fw engine is working sounds viable. The only thing i could advice as possible fix is re-intialization/clean of the CSME fw by the guide.
That’s all., good luck.
I am attaching additional data from analysis. In the audit log I noticed repeated HP Sure Start recovery events. If anyone have some extra anyone to take a look.
