[Problem] No NVMe booting with HP Stream 11-ak0040nr
Hi guys!.
hp mini.rar (4.2 MB)
Can someone please add the option to boot from internal m.2 slot to this laptop? I’ve dumped stock bios .
Laptop is able to see drive attached to the slot and also install windows to it but can not boot it.
Thanks in advance!.
Edit by Fernando: Thread title shortened and customized
I see NVMe DXE in bios, its original bios or your mod?
What OS did you install? Went smooth?
What disk type you attached?
Isn’t that a NGFF Wifi/BT connector…
EDIT: That’s quite interesting…an NVMe disk, bios and OS setup can deal with it…smooth install and no boot…no new EFI boot entry in bios after installation?
Well i really dont know for sure the mb model on the laptop, i just took this one (da0y0hmb6f0-quanta-y0h) as reference
No mods done, is stock. Windows 10 and 11. No problems installing. NGFF Wifi/BT connector i think thats the connector lol, sorry , disk is a nvme which as i said is recognized and installs windows fine just is unable to boot . Long time ago i had another laptop which had a wifi card in a same slot as this, replaced with a nvme and system improved thats why i want to replicate it. Thanks !
I can upload motherboard images or video of all i mentioned if needed (tomorrow).
Edit3:
Edit 4:
I’m using an NGFF to nvme adapter as you may know that there is no way for the nvme to fit as is hehe
In the end the problem with this pc was some kind of dust or something in the adapter (but nothing was visible, cleaned with alcohol) and reinstalled windows and was able to boot normally .
Thank you MeatWar , your confirmation of a nvme driver present in bios , told me to look for that!!.
Idk why you guys hate this cheap laptops. As they are are trash , but with some tweaks are good machines for medium user, in my case for leaving downloading large files overnight with the less power usage possible and having a good response time (hate slow pcs).
