Hi guys, I need help and I don’t know where should I ask this, I flashed a modded bios to my motherboard so I can use nvme and the adapter arrived today, unfortunately upon inspection of the adapter it doesn’t have smd/capacitor which is visible to different model/brand of nvme adapter.
My question is, is it safe to use without those smds/components?
@ItzMeGab
Welcome to the Win-RAID Forum!
Since your question has nothing to do with the topic “How to get full NVMe Support for all Systems with an AMI UEFI BIOS”, I have moved your post here.
By the way - I don’t know the answer to your question, but maybe >this< discussion will help you.
Enjoy the Forum!
Dieter (alias Fernando)
@ItzMeGab
Ignore that “picky” doubt you have and move on, this are simple adapters bus conversion and you can find expensive ones and cheaper ones…with a lot of pcb designs, they all work, some better some worst.
Sorry for commenting on wrong thread and thanks for moving it
Ok thank you very much for clarifying
