[Request] ASMedia 106x and X79-DELUXE
I installed the BIOS from Lost_N_Bios.
with
14. ASMedia 0.97 Inserted.
I bought a new BIOS Chip and put the original ASUS Bios on it,
with the details of the old “BIOS Chip” with FD44Editor.exe from:
None of ASMedia’s programs for F/W 106x work, neither with Dos boot on USB, nor in windows.
If I try to change it with UBU it shows that it changes … but it only becomes IDE.
AHCi is disappearing ! .
Even when I only change the F/W 0.97 , from 0.97 to 0.97.
In MMTool I am not able to work it.
Can someone help me?
Thank you. Regards.
The status of bios at this time is:
                  Main Menu
        [Current version in BIOS file]
1 - Disk Controller
EFI Intel RST VMD Driver - 13.2.0.2134
OROM Intel RST for SATA - 13.2.2.2224
EFI NVMe Driver present
2 - Video OnBoard
3 - Network
EFI Intel Gigabit UNDI - 0.1.00
OROM Intel Boot Agent CL - 0.1.16
EFI Realtek UNDI Driver - 2.056
OROM Realtek Boot Agent GE - 2.67
4 - Other SATA Controller
EFI Marvell SATA AHCI - 1.1.0.1029
OROM Marvell 88SE9230 - 1.0.0.1028
5 - CPU MicroCode
View/Extract/Search/Replace
S - AMI Setup IFR Extractor
0 - Exit
RS - Re-Scanning
A - About
Choice:
MC Extractor v1.90.2 r274
mCode Intel
306E4│2019-03-14│ PRD │0x4000│0x6814A8│Yes ║
306E2│2013-03-21│ PRD │0x3000│0x6854A8│Yes ║
206D7│2020-03-24│ PRD │0x4C00│0x6884A8│Yes ║
206D6│2020-03-04│ PRD │0x4800│0x68D0A8│Yes ║
206D5│2011-10-13│ PRD │0x4800│0x6918A8│Yes ║
306E4│2019-03-14│ PRD │0x4000│0x7014A8│Yes ║
306E2│2013-03-21│ PRD │0x3000│0x7054A8│Yes ║
206D7│2020-03-24│ PRD │0x4C00│0x7084A8│Yes ║
206D6│2020-03-04│ PRD │0x4800│0x70D0A8│Yes ║
206D5│2011-10-13│ PRD │0x4800│0x7118A8│Yes ║
306E4│2019-03-14│ PRD │0x4000│0x780060│Yes ║
306E2│2013-03-21│ PRD │0x3000│0x784060│Yes ║
206D7│2020-03-24│ PRD │0x4C00│0x787060│Yes ║
206D6│2020-03-04│ PRD │0x4800│0x78BC60│Yes ║
206D5│2011-10-13│ PRD │0x4800│0x790460│Yes ║
306E4│2019-03-14│ PRD │0x4000│0x7C0060│Yes ║
306E2│2013-03-21│ PRD │0x3000│0x7C4060│Yes ║
206D7│2020-03-24│ PRD │0x4C00│0x7C7060│Yes ║
206D6│2020-03-04│ PRD │0x4800│0x7CBC60│Yes ║
206D5│2011-10-13│ PRD │0x4800│0x7D0460│Yes ║
These microcodes are in your BIOS file
GUID 17088572-377F-44EF-8F4E-B09FFF46A070[wrap=“right”]
