[Request] Biosmod Legion 5 15IMH05 - Unlock Advanced Features
Hi All,
@Sweet_Kitten or @BDMaster can you help me to help a friend to unlock his legion Bios? What i need to do?
Here is the results of the Vars: https://drive.google.com/file/d/1MFUps2P…iew?usp=sharing
I Used this tool: https://www.mediafire.com/file/4s2lp3ig8…ools20h.7z/file
Tks so much!
Hi
Hello. Welcome to the Win-Raid Forum.
How about sending a backup of BIOS variables? We need to perform preparation to avoid error on flashing. Download H20UVE_200.00.01.00, extract to a separate folder. Run "GET VARS.bat" as administrator. I need "vars.txt" file.
Hey Sweet, thank you one more time!!
@ewerton10jz is the friend that i’m helping!
Here in Brazil is morning and Ewerton is at work now and he arrives only at night. As soon as I can, I run the H20UVE in his machine to get the BIOS variables oks?
tks buddy!
No problem.
Hello Sweet,
Follow the Vars File:
https://drive.google.com/file/d/16SvPxjx…iew?usp=sharing
tks!
Complete BIOS flashing package for you, @ewerton10jz
DOWNLOAD. Extract the contents of the archive to a separate folder.
1. Set variables and reboot.
2. Flash bios.
2. Flash bios.
Thankyou thankyou thankyou my friend, advanced menu is now showing, you are the GUY!
@Vernnon
Many thanks for report !
@Sweet_Kitten
The Swap didnìt work , we made many tests and the "Info" tab is not usable, we also modified the AoD IFR and nothing well … there is another lock or not full
enabled into code …
Regards
