@Upgrader001 - "Write" button is the "Program" button, directly above 08h offset column, after "Read" and before "Verify"
Bios repaired. Mission accomplished. Thank you again.
@Lost_N_BIOS
hi i need your help again i bricked the laptop again. It’s a similar reason, i introduced a invalid value in the bios, now it’s bricked. Same laptop.
please help me
Hi friend, let me know and i will help you, i am sorry , but Lost_N_BIOS isn’t here form long time and we all are worried about him …
You have a brick ?
Have you an CH341a programmer ?
I will wait your reply to help you friend …
Regards
@BDMaster
hi BDMaster. That’s a really bad and sad news about lost n bios.
yes i bricked
yes i have a ch341a programmer
thanks for your disposition
have you the Firmware ? oler dumps or actual ones or the bricked too ?
First thing to do is the Firmware Dump (bricked or not) to get a copy to recovery it …
Let me get all you have actually and explain to me our goal (to recovery firmware i expect) …
delete this post
@BDMaster
https://www.mediafire.com/file/xpplkrqks…s_15_x9_BIOS.7z
the firmware you mean the bios?
beceause this is the bios
@Upgrader001
Hi friend, this is the Firmware, all regions , look here :
[Guide] Unlock Intel Flash Descriptor Read/Write Access Permissions for SPI Servicing
But this one is broken ?
delete this post
@BDMaster
the bios is unlocked, unlocked by lost n bios, the bios that i gave to you it is what he gave me. I did the region unlocking in teh previuos posts.
This is the Firmware unlocked and uploaded to you by LNB , so it is good … why you didn’t reflashed back into Eeprom ?
What we can do , do you want to unlock the FD Descriptors ?
Let me know better friend, this is an Insyde Bios there are two locks and i saw here :
Form Sets
Offset: Title:
0x9B944 Advanced (0x15C3 from string package 0x0)—> *
0xBE574 Power (0x1644 from string package 0x0)-------> *
0xCC1E4 Info (0xFC from string package 0x4)
0xCD374 Main (0x5 from string package 0x4)
0xCE944 Security (0x2E from string package 0x4)
0xD07C4 Boot (0x4C from string package 0x4)
0xD2314 Exit (0x86 from string package 0x4)
I haven’t read the posts before , so now i will make …
You asked about a Bios Unlocked to LNB ?
Ok He made IFR modifies , not to get Advanced and Power menu tabs.
Now it’s more clear …
What we want to do ? i will help you to unlock further and flash it again.
Please use the ASProgrammer v.1.41 :
https://github.com/nofeletru/UsbAsp-flash/releases
This is very good on win10.
I will wait your reply friend
@BDMaster
Yes, LNB did a bios unlock, just i need to install the bios, but i dont remember how to do that.
Thanks for ask, but i dont want to modify anymore the bios just install or reflash the bios.
Ok friend, if this Firmware is original one etc. download the tool ASProgram 141, install the driver if you didn’t with your previous program, and then
i will explain how to do …
I have connected and located the bios, I need the drivers. How I get them?
@BDMaster
There is a driver into the AS Programmer 1.41 packadge …
When you will install on your pc the Software and the driver, then i will help you to flash the Firmware, my friend …
Let me know
Regards
