I am happy for you friend , cheers
Hi @BDMaster ,
one single question:
under Advanced -> PCI SUbsystem Settings there shouild be a setting called "Above 4G Decoding" bit in my bios, there is only on option called "BME DMA Mitigation".
Can you tell me the var offset and setting (enabled or disabled) for "Above 4G Decoding" and why it is not visible?
You have to use AMIBP 5 APTIO to set all to USER if there aren’t visible yet , save changes and flash it again, then if it isn’t visible yet , then may be i have to modify the EFI section /46 >> /47 to make it visible … but if it isn’t into AMIBCP , then there isn’t completely as AMIBCP doesn’t care about EFI IFR and shows all options availabily , but Bios use the EFI scetion to lock some variables and options.
So if it’sn’t into AMIBCP no way …
Let me know
Regards
@BDMaster
it is visible in AMIBCP but under root menu "PCI Subsytem Settings" which is not under Advanced
If I want to save the image in AMIBCP i get a rebuild error.
IFR Extractor says:
0x3646F Suppress If: {0A 82}
0x36471 Variable 0x2753 equals 0xF {12 06 53 27 0F 00}
0x36477 Setting: Above 4GB MMIO BIOS assignment, Variable: 0xFA {05 91 CF 09 D0 09 AC 04 16 00 FA 00 10 10 00 01 00}
0x36488 Option: Enabled, Value: 0x1 {09 07 8F 00 30 00 01}
0x3648F Option: Disabled, Value: 0x0 {09 07 90 00 00 00 00}
0x36496 End of Options {29 02}
0x36498 End If {29 02}
@projektion You friend wrote this … “Above 4G Decoding” and there is’nt …
Now you wrote “Above 4GB MMIO BIOS assignment” and i know that, i saw before, so i will unclok this one if you cannot see from Bios Menu Tabs …
and i will modify the SetupData subGuid to get the new settings.
Please make photos about Bios Menut Tabs visibles and AMIBCP settings you made , so i can see too what you are seeing,
i haven’t you pc
I will reply quickly ![]()
Regards
It will be saved wiithout sìgnature !
Your Variable is here , under Chipset folder …
Let me know, please
regards
@BDMaster ,
I only ment "Above 4G Decoding", thought "Above 4GB MMIO BIOS assignment" is the same?! Above 4GB MMIO BIOS assignment is not needed.
My AMIBCP looks the same like yours if I open your modded bios. I havent made any meaningfull settings within AMIBCP and if I want to save, i get an error, even if I change nothing.
Above 4GB MMIO BIOS assignment is not visible, too
does my actiual modded bios from you have signature?
is there any problem using unsugned bos?
@BDMaster :
I tryed againand could save the file.
What would you say, is it save to flash?
I madified the modded master, I received from you last time.
master2_patched.part1.rar (5 MB)
master2_patched.part2.rar (1.04 MB)
Yes , but after modifying it you have to flash again , so now use the Fptw64.exe to flash the new one and find if you are seeing the Tabs hidden …
Here is the AMIBCP 5 APTIO + my patched versions :
https://www.mediafire.com/file/1k4911guc…_APTIO.rar/file
I wrote save the modifies by AMIBCP and then flash to eeprom the mod file to see the unlocked settings into Bios Menu Tabs …
AMIBCP alerts are normal as all original UEFI bios are signed and we cannot reflash by original tool.
So we use Fpt and unlocked variables.
Please upload your Bios Menu Tabs so that i can see too , i cannot get your visual and haven’t any unlocked bios image of this pc !
Let me know if you can see the variable you are asking for and i will try to unhide it.
Regards
P.S. you didn’t make the AMIBCP i made into photos, you made only on first folder ?
ok, it worked
Hi @BDMaster ,
so setting the settings to user did the trick! THANKS!
One last question. Could you find a setting regarding resize bar / re-bar / resizable Bar?
I cannot find that option. Do I miss something?
Hi friend,
I can tell you some news about the strìngs into bios , they are wrote in two formats :
1. Unicode Format so opening the files by HxD can search any text and find if it exists (text = t.e.x.t. = 7400650078007400 )
As you can see any letter (ascii code) is followed by a null (0x00)
2. UTF-8 Format , any text has only the letters (ascii code) , if you search by HxD you’ll find if it exists (text = text = 74657874 )
The only place where are stored the variable’s names is the Setup Module 899407D7-99FE-43D8-9A21-79EC328CAC21 , where is the EFI IFR txt.
So i were looking for that patterns , but i can find something as “bar” only into vBios Module and i don’t think you are looking for that …
Let me know
Regards
P.S. there are three modules which are involved not at same time , about the bios AMI mod …
1. AMITSE PE32 = your main menu lock/unlocks (B1DA0ADF-4F77-4070-A88E-BFFE1C60529A)
2. AMITSE/SetupData/SetupData = your AMIBCP Access Level changes (FE612B72-203C-47B1-8560-A66D946EB371)
3. Setup PE32 = your AMIBCP textual menu name changes (899407D7-99FE-43D8-9A21-79EC328CAC21)
Lost_N_BIOS has all merits and gratitude to have explained it , GREAT Lost_N_BIOS !!!
OK, thanks again. Just wanna make sure my seach was not wrong. I came to the same result like you.
so my modding project is finished and my laptop still works ![]()
Thanks ![]()
I also have a Gigabyte Aero 17 laptop. Except mine is not the HDR OLED version. My last bios version is FB03 & EC F001 back in Jan of 2021. Would it be the exact same method to unlock the bios? Mine is also locked and i am having fan issues i would love some help unlocking this bios if anyone would kindly help me? Im not a complete n00b but have never modded a bios before so any help would be greatly appreciated!
Hi friend, use this tool run it as Admin and upload the result file , the i will explain all to do :
https://www.mediafire.com/file/flr80ru40…ols20i2.7z/file
Let me know
Regards
Thank you. I have dumped the files through other methods but this is a safe file i assume? Just wondering why it creates a passworded archive for a RW.dmp file?
