Ryzen 9 5950X or I9 11900K for Win7
HI @canonkong
i don’t have PS/2 mouse or keyboard just have USB only
you told recommended x570 to install win7 buy ASUS, Gigabyte
i do buy ASUS OR Gigabyte what model best recommended for Win7
i was plan to get NEW PC why i need Win7 i want play old game DOOM 3 support Win7 that why once i play finished old games then i will change Win 10 lol
spec CPU is Ryzen 9 5950X or I9 11900K
i don’t know will work Win7 Intel ??? fully function
can you recommended which Ryzen 9 5950X or I9 11900K for Win7 fully function
For 5950x, you can buy B450/X570 mainboards without wifi cards or buy a mainboard can easy replace wifi cards. If you don’t have any PS/2 mouse or keyboard, you can use PE system to run DISM++ to install the system. And do not to buy ASRock.
For 11900k, you can only buy MSI B560/Z590 mainboards because others will have A5 BSOD problem.
i prefer X570 i don’t need Wifi Cards because my PC always use LAN Cable
so i must Take 5950x can you give me model best for ASUS OR Gigabyte what model best recommended for Win7
i do buy brand ASUS OR Gigabyte i wont buy ASRock
can you give me List Mainboard for Recommend ASUS OR Gigabyte because i checked both to many model don’t want problem
batter you give me list best motherboard ASUS OR Gigabyte List
11900k, you can only buy MSI B560/Z590 but ASUS Or Gigabyte also will get A5 BSOD problem correct
then i think i must choose 5950x only then 11900k
ASUS PRO WS X570-ACE or GIGABYTE X570S AORUS MASTER
i checked GIGABYTE X570S AORUS MASTER look wifi card inside that mean windows 7 can install
motherboard that mean wifi can’t install driver windows 7 so leave correct
how about this ASUS ROG CROSSHAIR VIII EXTREME can install Windows 7 ?? any problem fully function
we no need use Wi so we don’t need install wifi just leave any problem this motherboard ASUS ROG CROSSHAIR VIII EXTREME
BIOS can disable the Wi-Fi cards.
C8E also can work on win7,also can disable the Wi-Fi card in bios.
ohh nice C8E i can do bios disable WI-FI no problem
i have Windows 7 Ultimate Original DVD 64bit
Windows 7 Ultimate do need Modified ISO ??? to work install windows 7 ?
can you guide tutorial step then i will follow
i need C8E fully Driver complete for Windows 7
which batter use install for DVD OR USB IF DVD then i can do DVD Burn for Modified ISO windows 7
Hi Canonkong, Crosshair VIII Extreme runs Windows 7 is an amazing news. But it has ALC4082 chip. That has drivers for Windows 7, I didn’t expect that. Also please note ALC4000 series has some issues too from the internet posts specifically around that new USB Audio ALC RealTek chip. Igor’s Lab also noted it. Also upon checking the Windows 7 drivers for this ALC4082 I found ASUS forums, problems associated with the drivers, the worst one can imagine with the 408x. The boards with these have top notch ESS DACs and Nichicon Capacitors with Impedance sensing circuitry but without the ASUS Sonic bloatware (UWP / Appx) the drivers will have lag during and there’s no fix apparently except installing the OEM bloatware pack.
Plus Crosshair VIII Extreme also has Marvell AQtion AQC133CS 10Gbe LAN which is the latest PCIe based Ethernet controller and apparently unlike AQC107 10Gbe and other series based on 3.0 this is 4.0 and doesn’t have a Windows 7 compat from it’s spec sheet.
Sorry I do not have any personal experience but just what I read online. I could be wrong in these as you may know more.
Thanks.
Edit 2 - ASUS released a beta BIOS for Z590 Apex XIII i think it enabled Windows 7 and XP support. Here’s the info from Hwbot
