Hi,
Supermicro company reported that factory versions of processors are not supported by boards in the x11 series. This means they have a different microcode. The microcode has been removed. Could someone please share the microcode for Xeon 8176F LGA 3647 Skylake-SP (Intel® Xeon® Scalable Processors SKL-F)?
What is the difference between these two Skylake-F and Skylake-SP versions in microcode? What is the firmware number for the Skylake-F version?
Previously, support was declared in the documentation.
This firmware should be suitable for other versions, the difference can only be in stepping.
Intel® Xeon® Gold 6126F Processor
Intel® Xeon® Gold 6130F Processor
Intel® Xeon® Gold 6138F Processor
Intel® Xeon® Gold 6142F Processor
Intel® Xeon® Gold 6148F Processor
Intel® Xeon® Platinum 8160F Processor
Intel® Xeon® Platinum 8176F Processor
Omni-Path Architecture (OPA) was a high-performance communication architecture owned by Intel - Omni-Path - Wikipedia
Here you can see the difference between the simple version and SKL-F https://www.techpowerup.com/img/7qnbUvDeWZXvXwDs.jpg
This microcode does not work apparently, the motherboard does not start.
Socket 3647 (LGA)
50653 Skylake-SP Xeon Platinum
cpu50653_plat97_ver0100013B_2017-08-09_PRD_984E6F2D.bin
cpu50653_plat97_ver01000140_2018-01-29_PRD_4981DEEA.bin
cpu50653_plat97_ver01000144_2018-04-20_PRD_5F6D2EC3.bin
cpu50653_plat97_ver01000146_2018-08-24_PRD_9F52DEC6.bin
cpu50653_plat97_ver01000154_2019-12-20_PRD_909D6278.bin
cpu50653_plat97_ver01000155_2020-02-21_PRD_028841AD.bin
cpu50653_plat97_ver01000157_2020-04-24_PRD_D44BC2EB.bin
cpu50653_plat97_ver01000159_2020-06-18_PRD_8A7CB578.bin50654 Skylake-X, Skylake-SP Xeon D,W, Skylake-SP Xeon Gold, Skylake-SP Xeon Platinum
cpu50654_plat97_ver02000021_2017-05-25_PRD_4FFA0668.bin
cpu50654_plat97_ver02000022_2017-06-01_PRD_CE8A8AEC.bin
cpu50654_plat97_ver02000023_2017-06-09_PRD_DEC08313.bin
cpu50654_plat97_ver02000026_2017-06-30_PRD_226329FE.bin
cpu50654_plat97_ver0200002B_2017-08-09_PRD_5FFAAE55.bin
cpu50654_plat97_ver0200002E_2017-09-01_PRD_7EFD5486.bin
cpu50654_platB7_ver02000035_2017-10-17_PRD_0D66C8E3.bin
cpu50654_platB7_ver0200003C_2017-12-08_PRD_A4059069.bin
cpu50654_platB7_ver02000043_2018-01-26_PRD_4840163E.bin
cpu50654_platB7_ver02000049_2018-03-27_PRD_DC30919B.bin
cpu50654_platB7_ver0200004D_2018-05-15_PRD_205C031D.bin
cpu50654_platB7_ver02000050_2018-08-09_PRD_88EFAF9F.bin
cpu50654_platB7_ver02000055_2018-10-08_PRD_43EA874C.bin
cpu50654_platB7_ver02000057_2018-10-22_PRD_26B11B5A.bin
cpu50654_platB7_ver02000059_2018-12-20_PRD_D2B4FBC1.bin
cpu50654_platB7_ver0200005D_2019-03-07_PRD_2C268A86.bin
cpu50654_platB7_ver0200005E_2019-04-02_PRD_13470AAF.bin
cpu50654_platB7_ver02000064_2019-07-31_PRD_8E7C22B2.bin
cpu50654_platB7_ver02000065_2019-09-05_PRD_460640CD.bin
cpu50654_platB7_ver02000068_2019-11-18_PRD_707F7CDD.bin
cpu50654_platB7_ver02000069_2019-12-20_PRD_6A6A88C5.bin
cpu50654_platB7_ver02006901_2020-02-12_PRD_2F78C3D8.bin
cpu50654_platB7_ver02006906_2020-04-24_PRD_B163D4FA.bin
cpu50654_platB7_ver02006A08_2020-06-16_PRD_8B444904.bin
cpu50654_platB7_ver02006A0A_2020-12-31_PRD_A8BC2C73.bin
cpu50654_platB7_ver02006B05_2021-01-15_PRD_0BFAA366.bin
cpu50654_platB7_ver02006B06_2021-03-08_PRD_095E1DFE.bin
cpu50654_platB7_ver02006D05_2021-11-13_PRD_060B1D6D.bin
The Intel Xeon processor Scalable family on the Purley platform supports Cornelis OPA in one of two forms: through the use of an Cornelis Omni-Path Host Fabric Interface 100 Series add-in card or through a specific processor model line (SKL-F) found within the Intel Xeon processor Scalable family that has a Host Fabric Interface integrated into the processor. The fabric integration on the processor has its own dedicated pathways on the motherboard and doesn’t impact the PCIe lanes available for add-in cards. The architecture is able to provide up to 100 Gb/s per processor socket.
Thank you in advance!
