I do not have PCI-E to USB2.0 or PCI-E to PS/2 card.
Is it possible to reinstall Windows with the USB driver added?
Hello @Mr_Fox and all the others, Iām trying to install W7 on my Asus Prime Z690-P D4 Mobo and found all the drivers needed except the one for Intel RST VMD Controller A77F (PCI\VEN_8086&DEV_A77F&SUBSYS_86941043).
Iāve tried to access your Double Driver backup but all the content at that old link is expired. Did you succeed in finding the Win 7 RST VMD Controller driver for the Z690 ?
For all the others here is the way I found all the other drivers:
- Most of them are available via SDIO.
- PCI Simple Communications Controller (PCI\VEN_8086&DEV_7AE8&CC_0780)
Found via āDriverMax Pro v14.14.0.8ā - Intel(R) Serial IO GPIO Host Controller - INTC1056 (ACPI\INTC1056)
Found via āAuslogics Driver Updater 1.13.1.0ā - ACPI Wake Alarm Driver (ACPI\ACPI000E)
Unsigned driver found here.
Signed driver found on this forum here, thanks to @canonkong.
Iām struggling to find this last one, hopefully somebody has a link to share ?
Thanks and have a nice day,
V.
BTW Iām using latest Gen2 W7 iso from web.archive.org
Hi @Virgus
Unfortunately I have never attempted to locate a VMD driver because I disable that in the BIOS and never use it. I do not have one to share with you as much as I wish I could help. I hope that someone else reading this has a solution you can use.
Thanks for your prompt reply @Mr_Fox
I took your comment as example and, for now, I disabled VMD driver in bios too. In the latest SDIO there are drivers entries for it but they all give errors. Letās see if something comes out in the future.
Cheers,
V.
Hello Virgus,
Can you confirm that you have installed Windows 7 on Z690 ?
Did you modify it in any way or did you just integrate it in Windows installation USB stick with DISM?
If it works on Z690 I presume it will work on all the previous motherboards , i.e. Z490, Z590?
So where can I obtain 3.0/3.1/3.2 intel USB for 300 up chipsets for Windows 7?
I got lost in this fightā¦
Heya, just setup win 7 on z590 and 11900k but got lost about USB 3.1
can you let me this what you have on priv as Fernando removed all links to intel āintellectual propertyā
this is the least but not last driver issue, but will pass it through finally, maybe with your help also
the mobo is Gigabyte z590 Vision D.
Hello to everyone.
The problem that I have is that Iām not able to move my mouse inside the Windows 7 VM x64 bit virtualized with bhyve (the best hypervisor on the bsd world) and I want to find a workaround. Maybe an idea could be to enable usb 3.0 on my Windows 7 x64 bit VM. For example windows 8 work well with xhci devices while win7 x64 bit sp1 doesnāt. I have googled usb3 drivers for win7, but none of them work. This is the parameter that I need to add in bhyve to pass thru the xhci USB 3.0 devices that I use (mouse and keyboard (the keyboard works,I donāt know why,but the mouse does not)
-s 30,xhci,tablet \
I think I need to know which kind of drivers I need. Where can I get them ? With which method ?
Iām not sure if it is relevant,but the hardware of my pc has one Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller with the mobo Gigabyte Aorus Pro Z390. On the website of the Gigabyte I didnāt find any package correlated with the USB 3.0 xhci drivers.
Or maybe,what counts more is not the hardware of my PC,but the virtualized components used by the hypervisor. In every case I donāt know which kind of drivers I should install. Please advice.
@johnconnor
Welcome to the Win-Raid Forum!
I have moved your request into this already existing thread about a rather similar topic topic.
Hopefullly you will find a solution here.
Good luck!
Dieter (alias Fernando)
