@alexander86
We can use a software name “Dism++” to add the driver into the images. Also we can use PE system run winNTsetup to intall win7 and add the USB driver.
Where should I look? It’s the only unknown device in device manager, further USB 3.0 working fine. Should I give you the device ids from installed USB 3.0?
Can you post links please? I want to try it on my B360 in WinPE.
Thanks
@George_King
It is still testing,when I finish it, I will post it.
To all people with issues
https://www.youtube.com/watch?v=-0xqUoHUVAo
Thanks to all the parties involved, the drivers released by reducer, dricks and canonkong successfully unlock the USB2.0 / USB3.0 / USB3.1 features of the Z390 chipset (A36D device identifier).
I have been using / testing / benchmarking all the Z390 USB ports of my Asus Z390 WS Pro motherboard with a 9900K CPU, and have not experienced a single issue.
So a big thank you for this collective effort.
This + wufuc + the UHD630 driver released by Canonkong in another thread of this site, allows full usage of W7 on the Z390/9900K, which makes for an incredibly fast and stable system, without the threat of the uncontrollable W10 update train.
@canonkong
Any change to make UCSI USB (USB-C) to work under Windows 7? I guess not, it’s only available in Win10. I tried using driver from Win10, but even if I sign it, it doesn’t work, because it’s a stock win driver…
The drivers he sent for me make usb c automatically work
maybe its different for you
@canonkong
@Prodif
sorry if the links were posted already but i’m unsure exactly which driver to download, can either of you guys please post a link to the driver that enables A36D usb 3.1 port on z390 motherboard in windows 7?
I need a driver that I can add to the win7 iso with DISM, I know how to do it, just dont have the driver…
do I have to worry about signing or certificates etc? or just add to iso with DISM and it should work next time i boot win7 iso from usb key?
or, can I skip adding the driver to the iso and just put it in a folder on the usb key and load it next time win7 install fails and asks for driver?
please note that I can’t even install win7 with ps2keyboard/mouse from my win7 usb boot stick, it fails and asks for usb driver, so I need the driver to be able to be loaded during install/added to iso, thanks for any help!
EDIT: I guess the 32bit and 64bit driver links in the first post in this thread by you @canonkong is the correct ones I need for my A36D ports to work in windows 7 ? what is difference between 32bit and 64bit in this case and what is best to use?
can I just put these in a folder on my win7 usb boot stick and load when windows 7 install fails and asks for driver? I have a ps2 keyboard I can use for the installation, but right now it wont even let me install with ps2keyboard and requires driver,
thanks and appreciate any help
Password on the zip files ?
The passkey in the 1st post is in all white so you have to select it to make it more readable.
Please finish this unwanted puzzle & tell the pass key on the driver zip!
Update : So the pass key is : xiaofengmod
did anyone have success integrating these drivers into a win7 iso or loading them during win7 install on z390 motherboard?, I need to do load the drivers on to my win7 usb stick…
1. Are you aware of : [Guide] Integration of drivers into a Win7/8/10 image
2. Don’t you have USB 2 ports with boot support ? Make installation from a USB 2.0 port, Get the right Hardware IDs for unknown devices from Device Manager & try out the driver(s)
1 = I know you can use DISM or poweriso for example to integrate drivers into a iso, I am just asking if anyone had success doing it with these drivers before I try.
2 = no, my msi z390-a pro motherboard will not allow win7 installation to continue at all even with ps2 keyboard connected, it asks for usb driver anyway
Hi All,
Greets,
@alexander86 :
From a kind senior : Extract Win 10 ISO, change Win 10 Install.wim with Win 7 Install.wim & proceed with the installation.
It is using Win 10 Boot.wim to install win 7. Win 10 Boot.wim certainly has all the basic drivers so it successfully installs win 7 but the final/real win 7 installation depends on the drivers integrated into win 7 Install.wim. So, the method will take to a successful win 7 installation without installed/working USB 3 ports if all other basic / chipset drivers are available.
@alexander86 :
EDIT: see below post
managed to get it to work after some trickery !
