Dump from Web. Try it!
Just google it! Or download on attach ![]()
CH341A Programmer 1.18.rar (733 KB)
clear me pro5.bin.zip (5.26 MB)
@yakumot1 - See above ^^
@Aditya - sorry, I don’t quite understand what you mean. You had this system for years, with a password on it, but didn’t find out until after warranty was up?? If yes, that doesn’t make sense, sounds fishy
Or, do you mean you can’t enter BIOS? If not, remove all hard drives, USB etc, and boot it, it should then give you the boot choice screen or allow you to enter BIOS.
Hi, I have a surface pro 4 i5 with not working touchscreen . On bios touchscreen firmware is 0.0.0.0.0.0 and under window system I have yellow icon on touchscreen and surface Me firmware with code 10 error.
Could I try to repair flashing bios?
Hello, could you please suggest if there is a solution to my problem.
My surface 5 got stuck on black/white logo and after flashing the bios with another dump my touchscreen stopped working.
Is there a dump that I can use to reflash the bios so that the touchscreen will be enabled back?
Thank you very much for your help and considerations.
Hey! Where can I find the Bios chip of the Surface Pro 4. I found one chip but no way I can get my clip on. I flashed many Thinkpads before but this one is tricky.
Need to get rid of the UEFI password.
