Great news! Thanks again for your assistance. I am going to report if succed ![]()
Hello everyone,
I’m a new member here, thanks for accepting me.
I’m working with a Gigabyte GA-X58A-UD3R Rev 2.0 motherboard and trying to update the BIOS to FH in order to properly run a Xeon X5690.
Unfortunately, I’m stuck because I cannot find a working DOS version of EFIFLASH.EXE (v0.80 / v0.85 / v0.87) anymore.
What I have already tried:
Q-Flash → FG1 and FH both fail with “Invalid BIOS Image”
FlashSPI → not compatible with Hybrid EFI
EFIFLASH v0.65 (DOS) → SPI Flash Initiate Failure
EFI versions (.efi) → not usable on this board
I know this tool was shared years ago in this forum (DOS EFIFLASH with DualBIOS support, /DB option), but the old links seem to be dead.
If any member still has a copy of the DOS EFIFLASH.EXE (v0.80–0.87) and is willing to share it (publicly or via PM), I would really appreciate it.
Thank you very much in advance,
and sorry if this question has been asked many times.
Best regards.
This is old Award bioses, i believe this topic/tools here have nothing to do with your mb model, you need to use the FLASHSPI that come on the archive, run in DOS from a USB disk.
The FLASHSPI has some cmd Switches options, look for them around the web.
Maybe @ ismailTPC_Hastanesi can give you a hand on this.
[Offer] Collection of NVMe Mod 2022-X58/1366 PIN MB BIOSes - BIOS/UEFI Modding / Offers: Already modded special BIOSes - Win-Raid Forum
Thanks for checking. I already tested FLASHSPI in DOS with multiple switches, including FG1, and it fails due to Hybrid EFI SPI init.
Your motherboard doesn’t support EFI, and EFIFLASH.EXE is useless.
I understand your motherboard BIOS is old and 1024KB.
But the new revision, “x58aud3r.fh,” is 2048KB.
I’ve prepared files for you to update without any problems.
Copy these files to an empty USB flash drive with a maximum capacity of 4GB and FAT32 format using Rufus software.
When the MS-DOS black screen appears,
Type “Flash.bat” and confirm.
That’s all.
Gigabyte GA-X58A-UD3R (Revision 2.0)_Flash.rar (1.2 MB)
Good afternoon. I wanted to share this with you, in case it’s useful to anyone, because a few days ago I updated my Gigabyte GA-x58A-UD3R motherboard, Rev 2.0. Of the three files in the BIOS section of the official website, I could only update the FF version. I couldn’t get the latest FH version to work, neither with flashspi.exe, nor with efiflash.efi, nor with efiflash.exe. Finally, I managed to do it by creating a bootable USB drive (max 4 GB) for MS-DOS using Rufus (FAT32). Once created, I copied flash.bat and x58aud3r.fh to the root directory. I booted into MS-DOS mode, ran flash.bat, and that was it—the BIOS was updated. All of this was made possible by ismailTPC_Hastanesi, without whom I would have given up. He shared this file with me. Gigabyte GA-X58A-UD3R (Revision 2.0)_Flash.rar (1.2 MB). Thank you
Hello, new member here.
I have an aorus gaming z370m fully updated to f14.
I tried using the efiflash 0,87, 0,85 and 0,80 to downgrade to f12, unsuccessfully.
The F14 has a default amperage cap, if anyone knows a way to bypass this it would solve the problem without the need to downgrade.
Hello!
Through the integrated Qflash, flash to an older version of the firmware, and then update via Efiflash.
That’s how I updated the DUAL-BIOS.
Thanks/
For native Qflash, change this code in your motherboard firmware using a binary editor such as Hex Editor Neo
For local Qflash aborigine, change this code in your motherboard firmware using a binary editor such as Hex Editor Neo
00 and you can flash any BIOS using Qflash/
tested for Z370PD3 works great/
thanks
@Zaver what does that do? You can flash any bios if that line was changed? I mean, say i downgrade to stock old bios, then i dump the whole bios chip, open that full dump, and then i change that byte you pointed out, and then flash the byte-changed dumped bios using efiflash, and after it flashed successfully, i can flash any bios (say i downloaded a stock latest bios and mod it), in Q-Flash inside the bios utility?
This is for DUAL-BIOS/ using efiflash.efi/efiflash.exe/ and if there is no programmer
After flashing the latest BIOS, which is on the Gigabyte website for Z370 boards, efiflash.efi refuses to downgrade the BIOS version to an older one, Qflash may also not flash older versions.
After changing the code line 50 01 07 00 you can flash the old BIOS using Qflash, and then using efiflash.efi or efiflash.exe (for DOS) reflash the backup BIOS chip
using the command:
efiflash.efi [Input File Name] /DB
efiflash.exe [Input File Name] /DB (for DOS)
/DB- Update both main & backup BIOS
This is the only way I solved this issue
Thank you
Ps/ Here is a screenshot from the Gigabyte website
Pps/And of course, we change the line of code of the BIOS we want to flash.
It worked, thanks
Hi so after some advice, I have a problem with the current bios I am on, on my Z390 Aorus Master rev1.0.
I updated a bios from gigabyte f13c all was fine, then they wanted me to updated the bios but since then i have OEM ID Missmatch.
So question is should I wait to see if gigabyte can sort this at the moment they saying I would need to return the motherboard, yet I have shared this bios online with others, who will now have the same problem, or would using the EFIFlash with the bios on the Gigabyte web site work, as the one on the website is f13a, I using f13c and they have given me f13f. ( Thinking f13c to f13a is rolling back.)?
@Zaver Hi so with your hex edit, and the z390 bios. If I am on a capsule bios the q-flash comes up with invalid image, when trying to downgrade. Pre capsule the Q flash hex works. not sure if you had said.
what I tested.
So testing bios, modified f13f to official f13f works.
f13 modified - f13 modified invalid image.
modified F13f to f9 invalid image.
RMA f9 To f9 works.
RMA or f9 to f13f or modified f13f works.
f13f to modified f13 invalid image.
Hello!
Look here again.
Choose 50 01 07 00 (zero zero)
After saving the modified BIOS file, give it the same name as the original file.
It works excelent for me. on Z370.
01, 02 or 03 doesn’t work for me.
Am using 00.
So your saying download say f12 bios, then hex edit that, save as orginal name than that file will q flash?
Yet for me being on offical f13f and tried the modified it gave invalid image. Will check it all correct, and try the above too.
It don’t seem to work for me, the hex editing. I edited bios f9 and f10 and both when I tried I got invalid image in q-flash.
Z390AOMA.rar (6.6 MB)
the above is a copy of the file f10 bios I modified, just so you can see, as far as I can tell I’ve done correctly and it still has the original name of the file, or am I still missing something?
Ні!
Yes, maybe you have a more advanced motherboard and that’s why.
If you want, you can use a modified Efiflash version for firmware from under DOS or UEFI. In this topic at the beginning there are modified versions of efiflash.
There are different versions, you need to test it yourself.
@Zaver will try efiflash, it seems capsule related as I can flash from pre capsule f9 up with a modified bios, just not f13f back.
