@ring00 - those BIOS are made with user SPI Dump, you will loose your serial, UUID, LAN MAC ID etc if you do not make backup first and put back in your own board details instead. Link updated in place on the post you linked, thanks for letting me know dead link.
Hy Lost_N_BIOS, I’m trying to use a E3 1240V5 in a motherboard Asus H110M-C/BR. but it did not work. I did the modification on Resewood to Yes, the system turn on but do not appears video. I already install a video card. I think it is because of the version of ME. Could you make a Bios Image to me using the ME version 11.0.0.1191? I will thank you very much if can do it for me.
@Anaodjardim - yes, certain ME version may be required, did you read all this thread and see what everyone said? If yes, which ME, the one you mentioned, that is correct one to use? If you know how to do mod to change reserved setting, you can switch out ME versions too, just as easy as the change you already made. Follow the ME Cleanup guide and you’ll be fine.
@Lost_N_BIOS @dsanke I NEED HELP BRO PLEASE FOR MY ASROCK B150M Pro4 for e3 v5 processor , I want to chang FIT Reserve to yes, but i dont know how to put bios or load in FIT , because supported .bin .xml , asrock bios download insta flash .00 please tut me how im doing thanks
ill try to revert my me version 1126 into 1191 how im going to do ? ill try to change me region.bin but after reboot showing 1126 on my flash bin i replace 1191
My Me Version 11.6.0.1126 i want to back 11.0.0.1191 what im going to do, im try to flash instant flash asrock bios , only update uefi , please help me
Can you help me Version BIOS VERSION 7.10 11.6.0.1126 i want to back BIOS VERSION 7.0 11.0.0.1191 IM USING ASROCK B150M PRO4 , Only UEFI Update im using instant FLASH
