i have been trying to build an HP EliteBook g3 from a dump file with a corrupt INTIALIZED file system state with a downloaded one from HP site with an UNCONFIGURED file system state, same csme version 11.8.93.4323 with the right flash image tool and i keep getting this error Error 52: [FitActions] IDLM Binary is invalid or corrupt Failed to remove IDLM binary.
uefi password should be solved by cmos reset(or their HP solution), not tuning some inner needs.
use official Intel IMEI drivers(maybe also RST Storage for CD, SATA,RAID needs often if nb needs), but HP own solution without drivers on Windows Update Catalog goes into HP web for download tools, their own partitions but also there is HP builder for installation needs somewhere if partitions missing or deleted. Service department otherwise if troubles ahead, not public drivers probably, but HP assistents fully covered be there, including partition builder and Intel IMEI drivers from Intel web still possible.
(also 11-14 Gen,…)
7th-10th Gen
List of Drivers for Intel® Graphics https://www.intel.com/content/www/us/en/support/articles/000090440/graphics.html
official Intel rapid storage technology - Intel RST drivers(Raid, Optane, Sata, …) if needed
download center: intel serial io drivers for windows 11
______
GitHub - microsoft/secureboot_objects: Secure boot objects recommended by Microsoft. · GitHub
GitHub - fwupd/dbx-firmware: DBXUpdate files from Microsoft · GitHub
______
community versions (for) legacy: Recommended AHCI/RAID and NVMe Drivers
ubu community tool and its ubu archives
Thanks, but i uploaded the wrong shot as regards to what i needed help with, i could not build a working BIN file for HP EliteBook G3 with the correct Intel Flash Tool, even after downloading the right CSE ME from Hp website, though the CSEME file system state says UNCONFIGURED - i get FAILED TO BUILD each time i try to build this file with the intel flash tool
- look at the screenshot for better clarity
winget view HP.ImageAssistant
winget install HP.ImageAssistant
This package provides the HP Image Assistant tool which assists in building a stable Windows
image optimized for supported HP systems. This package is provided for supported Commercial
computer systems using a supported operating system.
winget search bios
winget search Microsoft.Windows
