Updating me for i5-4460T
hi im trying to figure out how to update intel me firmware for i5-4460T
i think it can be upgraded since windows 10 automatically installs 11.0.0.1166 intel management interface driver but if i try to run CSME v11 tools I get
Error 107: Failed to create dependency list for features
how do i know if it has v11 or if it can be upgraded?
ME Firmware = part of 'bios’
ME driver = driver for OS
(MEBx = interface module to ME in bios)
They (can) have different versions. All information regarding your question is explained (perfectly) in the first two posts of the thread Intel Management Engine: Drivers, Firmware & System Tools
You probably have ME firmware 9.0 or 9.1, that defines the version of tools you could use.
@h321671 - Here’s how to check what ME FW you have if you are still not sure >>
Check your BIOS’ main page and see if ME FW version is shown. If not then DOWNLOAD HWINFO64
Once HWINFO is open, look at the large window on the left side, expand motherboard, and find the ME area. Inside that section is the ME Firmware version as shown in image below
What‘s your mobo’s name?
I think microcode and ME count at the same time.
I read the sticky thread wrong, i thought HWINFO was MeInfo from the tools archive
when i ran HWInfo it reported me version was 9.1, after that I downloaded the 1.5 MB fw and updated it with intel me tools v9
Thanks
