18- secure flash rom verify fail please help me!!!!
My laptop is onegx1pro
Trying to unlock the bios
I extracted the bios with AFUWINGUIx64.EXE
And after customizing it with amibcp And I want to flash again
18 secure flash rom verify fail
use afuwin , afudos , afuefi
I am very sad
Where can I get the latest ftpw files?
help me :
Start here and pay attention to point 2…u have to unlock bios first and follow other guides mentioned in links, take dumps etc…REAL careful and dont do anything if ur not sure, ask again with a REQUEST.
Besides… seeing MEI 15 in ur screens…its a brand new platform/system.
U could have a CH programmer to be more secure and having a FULL DUMPS of the current SPI.
DONT do blind flashes as u did…
[Guide] How to flash a modded AMI UEFI BIOS
Upload my bios
afuwin dump
I don’t know how to unlock
I don’t know which guide to follow
one.zip (4.89 MB)
@mina97 - Thread moved, since this was in unrelated forum section
FPT you get here in section C.2, you need V15 package - Intel Management Engine: Drivers, Firmware & System Tools
DO NOT FPT flash anything from AFU!! And DO NOT FPT flash anything from a stock BIOS package.
ONLY dump BIOS region with FPT, modify, then flash that BIOS region with FPT
I assume you will need BIOS unlock request, AMIBCP is generally ONLY going to help you to make “Some” things visible in menus that you can already see
Stuff in menus you cannot see now, and usually many settings, will require setup module edit via hex.
Here’s how to dump and flash BIOS region, if you get error at #2, upload your file from #1 for me and tell me what error # you get at step #2
Also, please link to your BIOS Download page if you can, and or if not, also please give your system brand and full exact model #
If you have already modified the BIOS in ANY way, you will need to re-flash it back to factory defaults using factory method (NOT FPT)!!!
Additionally, please remove all BIOS passwords, disable secure boot, and disable TPM or Encryption if you have enabled. Do this before moving on to below
If you do not have Intel ME drivers installed, install them now from your system driver download page, then start over here after reboot.
Check your BIOS’ main page and see if ME FW version is shown. If not then > DOWNLOAD HWINFO64 HERE <
Once HWINFO is open, look at the large window on the left side, expand motherboard, and find the ME area.
Inside that section is the ME Firmware version. Take note of the version. (ie. write it down or get a screenshot)
Once you have that, go to the thread linked below, and in the section “C.2” find and download the matching ME System Tools Package for your system.
(ie if ME FW version = 10.x get V10 package, if 9.0-9.1 get V9.1 package, if 9.5 or above get V9.5 package etc)
> DOWNLOAD " ME System Tools " packages HERE <
Once downloaded, inside you will find Flash Programming Tool folder, and then inside that a Windows or Win/Win32 folder (NOT x64).
Highlight that Win/Win32 folder, then hold shift and press right click. Choose “open command window here” (Not power shell! >> * See Registry file below *).
If you get an error, reply to this post with a screenshot of it, OR write down the EXACT command entered and the EXACT error given.
((If “open command window here” does not appear, look for the “Simple Registry Edit” below…))
Step #1
Now you should be at the command prompt.
You are going to BACKUP the factory un-modified firmware, so type the following command:
Command: " FPTw.exe -bios -d biosreg.bin "
>> Attach the saved "biosreg.bin ", placed into a compressed ZIP/RAR file, to your next post!!! <<
Step #2
Right after you do that, try to write back the BIOS Region dump and see if you get any error(s).
Command: " FPTw.exe -bios -f biosreg.bin "
^^ This step is important! Don’t forget! ^^
Here is a SIMPLE REGISTRY EDIT that adds “Open command window here as Administrator” to the right click menu, instead of Power Shell
Double-click downloaded file to install. Reboot after install may be required
> CLICK HERE TO DOWNLOAD CMD PROMPT REGISTRY ENTRY <
If the windows method above does NOT work for you…
Then you may have to copy all contents from the Flash Programming Tool \ DOS folder to the root of a Bootable USB disk and do the dump from DOS
( DOS command: " FPT.exe -bios -d biosreg.bin " )
My version 15.0 build 1345
Can I download this from your link?
CSME 15.0 Consumer PCH-LP B v15.0.10.1469
For systems running CSME Consumer LP B v15.0
thank you
succeded
and eedit winbcp?
A post was merged into an existing topic: Intel (Converged Security) Management Engine: Drivers, Firmware and Tools (2-15)
