[ARCHIVE] Outdated UBU Tool related Questions, Reports and Suggestions
@SoniX
8086-0406 Intel Skylake VBIOS 9.0.1029
8086-0406 Intel Skylake VBIOS 9.0.1029.rar (37.9 KB)
Skylake microcode 06E3 Rev.4A (?) dated 2015/09/18.
06E34A.zip (91.1 KB)
Yes. SKL 06E3 - 4A
Thank you.
Did I miss something? UBU can now update X99 Aptio V? So it should work even on Z170?
Yes, perhaps only a partial update.
For some reason, my one onboard I210 updates from UNDI 6.0.24 to UNDI 0.0.09. Shouldn’t it be updating to 6.9.07? On Aptio V.
If only one network controller i210, the upgrade should be up to version 6.9.07.
Specify the a model board and BIOS.
Thanks for the reply.
I have an MSI X99S-MPOWER BIOS vM.71
hello to everyone.
i’m a new member and after reading a lot of discussion i decide to register me.
i have a little problem updating bios of my sabertooth x99.
i would like to update it with irst version 14 for nvme support to create raid with 2 sm951 nvme
the ubu works good, it update the driver, but the file that ubu create is not recognized from the ez asus bios updater.
anyone can help me?
thank you
Parrotts
p.s.
sorry for bad english
@parrotts
You’ve to do via Afudos !!! I hope you know the wright procedure. :slight_smile:
I installed this yesterday and it appears to give us SGX instructions, 3A didn’t have those. Both AIDA and HWInfo show this.
hi
thank you for the rreplay
today i’ve
update the bios with usb bios flash and it works but istill having problem with raid setup
i’m trying to install 2 sm951 nvme in radi 0 on my sabertooth x99 and i have some difficult to do.
the ssd is installed one in m.2 native slot and one in a pcie adaptor in the second slot.
bios see both.
i can install os in both.
i modded bios file to update with version 14 of intel rst driver ( in fact in the advanced mode of bios in intel rapid storage flag it shown version 14 but no disc is detected)
in the nvme configuration they are listed
bus 3 sm951…
bus 5 sm951…
but the irst don’t see that unit
wath i’ve missed to do?
@SoniX
Hello :slight_smile:
Skylake VBIOS 9.0.1030 & GOP 9.0.1036
VBIOS_GOP.zip (70.5 KB)
8086-22B0 Intel CherryView VBIOS 1009
8086-22B0 Intel CherryView VBIOS 1009.rar (36.2 KB)
That’s what i was inquiring.
I’ve this Microsoft update on my machine: https://support.microsoft.com/en-us/kb/3064209 , and HWiNFO64 showed 1B
But my Bios file was still in version 17 and I updated today to 1B with UBU…i just wasn’t sure of the result…
This Microsoft KB3064209 contains Haswell microcode, which disabling overclocking features on Intel non-Z chipsets motherboards (like popular combination Pentium G3258 + H81). After this update, Windows doesn’t boot.
Suggestion for SoniX: If UBU contains same microcode, can you insert warning?
Here is solution for Windows 7/8.1 users:
1) open command prompt as administrator, type
1
start /wait wusa /uninstall /kb:3064209 /quiet /norestart
2) hide KB3064209 update
3) enable overclocking
For Windows 10 users:
1) delete or rename C:Windows\System32\mcupdate_GenuineIntel.dll in safe mode
Hi everybody, I need your help. I have DELL PRECISION T5600 with processor Intel E5-2667 ES QB7T. This is engineering sample. Now i bought two processors Intel QA90, but i’dont know how i need add this cpu microcode to my bios.
Can you help me?
Dump my bios here: http://ewent24.pl/20151014_originalBIOS.bin
Please, help me. I have MMTOOL but i don’t know how this processor code. QA90 is like as E5-2660, E5-2665, but i see in UEFI BIOS ffs file with ES MICROCODE.
Thank you
Mario
it updates the cpu microcode list based on the current installed cpu! install the cpu, then dump, then update bios rom file, and finally flash modified bios file.
OK, thank you f3bandit, but i don’t know how microcode to this processor.
if I understood correctly:
1) i use MMTOOL, load dump bios, add microcode
2) install bios, install new processor
Tell me please, i have UEFI Tool and catalog Modules/CPUI with file LGA2011es … how i can write this file to my bios??. Maybe you can do it, link to file with my bios you have below: http://ewent24.pl/20151014_originalBIOS.bin
Thank you very much
no just run the ubu.bat
@ mariog3:
Welcome at Win-RAID Forum!
Regards
Dieter (alias Fernando
@ mariog3 and f3bandit:
Since you have written your contributions into the wrong UBU thread (it is reserved for SoniX’s announcements), I have moved your posts into this UBU discussions thread.
