UEFITool 0.22.0 Alpha (?)
https://github.com/LongSoft/UEFITool/releases/
@ SoniX:
cpu000306C3_plat32_ver0000001F_date#02-02-2016 (HSW)
cpu00040671_plat22_ver00000014_date#22-01-2016 (BDW)
uCodes.rar (32.2 KB)
Many Thanx!
I just ran the UEFI BIOS Updater tool and for Haswell 1F CPU Microcode does not show in the list,1E is the last microcode showing with v1.51 Update 1 or maybe I did something wrong. My cpu is a I7 4790k.
I have 1F CPU Microcode now. I must of unzipped it wrong.
@NIK1
How to use the update.
Update Files "UBUxxxUpdx.exe" copy to folder UBU and start UBU.bat.
* xxx - UBU version for which this update
* x - Update version
that tool is a miracle…
i ll check the bios it made later , but that looks incredible how it updated all my roms …
i made screen copies and pasted them in one txt file
Platform BIOS AMI Aptio 4
Brand ASUSTeK COMPUTER INC.
Model SABERTOOTH-X79
Found Option ROM in GUID A062CF1F-8473-4AA3-8793-600BC4FFE9A8
Found EFI Intel Raid Controller GUID 43A0A7B3-1E92-42EF-A46D-DDC03E52CB5C
Found EFI Intel LAN PRO/1000 Undi GUID 4953F720-006D-41F5-990D-0AC7742ABB60
Found EFI Marvell AHCI Comtroller GUID 4331898D-CCB8-4108-898C-A5CC81442B28
Press any key to continue . . .
Select option for update
1 - Intel RST(e) OROM and EFI SataDriver
OROM IRST RAID for SATA - 12.7.0.1936
OROM IRSTe RAID for SATA - 3.5.0.1005
EFI IRST RAID for SATA - 12.7.0.1936
3 - LAN OROM PXE and EFI UNDI - Intel, RTK, BCM, QCA
OROM Intel Boot Agent GE - 1.3.72
EFI Intel PRO/1000 UNDI - 5.5.23
5 - Marvell SATA Option ROM and EFI
OROM Marvell 88SE9128 - 1.0.0.1031
EFI Marvell SATA AHCI - 1.1.0.1001
7 - Update Intel CPU MicroCode SandyBridge-E/IvyBridge-E
CPU Microcode 0206D7 SNB-E - 705
CPU Microcode 0206D6 SNB-E - 610
9 - ME Analyzer
i - Versions, HomePages and etc.
0 - Exit
Press ENTER - Re-Scanning ALL EFI modules.
Enter number:
Enter number:1
Intel RST OROM and EFI SataDriver
1 - Update to v11.2.0.1527 only OROM
2 - Update to v11.6.0.1702
3 - Update to v12.9.0.2006
4 - Update to v13.1.0.2126
5 - Update to v13.2.2.2224/13.2.0.2134
6 - Update to v13.5.0.2164
7 - Update to v14.8.2.2397
9 - Goto Update IRSTe/SCU
T - IRST TRIM-in-RAID0 Addon for Intel X79s motherboards
0 - Exit to Main Menu
Enter number:7
* Generate FFS Intel RAID Driver GUID 43A0A7B3-1E92-42EF-A46D-DDC03E52CB5C … O
k!
* Update EFI Intel RAID Driver GUID 43A0A7B3-1E92-42EF-A46D-DDC03E52CB5C … Ok!
* Update OROM Intel RST Device ID 2822 … Ok!
Intel RSTe OROM and EFI SataDriver
1 - Update to v3.8.0.1029
2 - Update to v4.1.0.1026
3 - Update to v4.3.5.1000 SATA/v4.3.0.1018 SCU and sSATA
4 - Update to v4.5.0.1012 SATA and sSATA/v4.3.0.1018 SCU
0 - Skip
Enter number:4
* Update OROM Intel RSTe Device ID 2826 … Ok!
OROM IRST RAID for SATA - 14.8.2.2397
OROM IRSTe RAID for SATA - 4.5.0.1012
EFI IRST RAID for SATA - 14.8.2.2397
Enter number:3
LAN OROM PXE and EFI UNDI Intel, Realtek, BCM, QCA
1 - Update ALL LAN OROM and EFI:
- OROM LAN Intel BootAgent CL 0.1.06 / GE 1.5.78
- EFI LAN Intel Gigabit UNDI v0.0.09 / PRO/1000 UNDI v7.0.06 or v6.6.04
0 - Exit Main Menu
Enter number:1
* Generate Intel LAN PXE CL OROM Device ID 1503 … Ok!
* Update OROM Intel LAN PXE CL Device ID 1503 … Ok!
* Generate FFS Intel LAN 1 GbE UNDI GUID 4953F720-006D-41F5-990D-0AC7742ABB60 …
. Ok!
* Update EFI Intel LAN 1 GbE UNDI GUID 4953F720-006D-41F5-990D-0AC7742ABB60 …
Ok!
OROM Intel Boot Agent CL - 0.1.06
EFI Intel Gigabit UNDI - 0.0.09
Enter number:5
1 - Update OROM Marvell
OROM Marvell 88SE9128 - 1.0.0.1038
EFI Marvell SATA AHCI - 1.1.0.1020
0 - Exit Main Menu
Enter number:1
* Generate FFS Marvell AHCI GUID 4331898D-CCB8-4108-898C-A5CC81442B28 … Ok!
* Update EFI Marvell AHCI GUID 4331898D-CCB8-4108-898C-A5CC81442B28 … Ok!
* Update OROM Marvell SATA Device ID 9128 … Ok!
Enter number:7
1 - Update CPU MicroCode IvyBridge-E and SandyBridge-E
6E4-428, 6E2-20D, 6D7-710, 6D6-619, 6D5-513
2 - Update CPU MicroCode Engineering Sample
6E3-308, 6E0-008, 6D3-304, 6D2-20C, 6D1-106
9 - View CPU Microcode Patch list
Enter number:
No CPU MicroCode Patch present in Volume 2.
| MMTOOL 5.00.0007 |
| Copyright (c)2014 American Megatrends, Inc. |
| CPU Patch Information |
|Vol|No| Boot |MicroCodeID|Platform|CPUID| Revision |Date(YYYY/MM/DD)| Size |
|03 |01| YES | 06D6D705 | 6D |06D7 | 05 | 2011/12/14 |00004000|
|03 |02| YES | 06D6D610 | 6D |06D6 | 10 | 2011/12/14 |00003C00|
| Total Patch Size: 00007C00 |
| MMTOOL 5.00.0007 |
|04 |01| YES | 06D6D705 | 6D |06D7 | 05 | 2011/12/14 |00004000|
|04 |02| YES | 06D6D610 | 6D |06D6 | 10 | 2011/12/14 |00003C00|
| Total Patch Size: 0000F800 |
| MMTOOL 5.00.0007 |
|05 |01| YES | 0ED6E416 | ED |06E4 | 16 | 2013/07/09 |00002C00|
|05 |02| YES | 0ED6E20D | ED |06E2 | 0D | 2013/03/21 |00003000|
|05 |03| YES | 06D6D710 | 6D |06D7 | 10 | 2013/06/17 |00004400|
|05 |04| YES | 06D6D616 | 6D |06D6 | 16 | 2012/02/29 |00004000|
|05 |05| YES | 06D6D513 | 6D |06D5 | 13 | 2011/10/13 |00004800|
| Total Patch Size: 00022000 |
| MMTOOL 5.00.0007 |
|06 |01| YES | 0ED6E416 | ED |06E4 | 16 | 2013/07/09 |00002C00|
|06 |02| YES | 0ED6E20D | ED |06E2 | 0D | 2013/03/21 |00003000|
|06 |03| YES | 06D6D710 | 6D |06D7 | 10 | 2013/06/17 |00004400|
|06 |04| YES | 06D6D616 | 6D |06D6 | 16 | 2012/02/29 |00004000|
|06 |05| YES | 06D6D513 | 6D |06D5 | 13 | 2011/10/13 |00004800|
| Total Patch Size: 00034800 |
Enter number:1
Found 5 module(s).
Remove “Empty” module.
Update Microcode Patch…Ok!
Restore “Empty” module…
| MMTOOL 5.00.0007 |
|03 |01| YES | 0ED6E428 | ED |06E4 | 28 | 2014/05/29 |00003400|
|03 |02| YES | 0ED6E20D | ED |06E2 | 0D | 2013/03/21 |00003000|
|03 |03| YES | 06D6D710 | 6D |06D7 | 10 | 2013/06/17 |00004400|
|03 |04| YES | 06D6D619 | 6D |06D6 | 19 | 2012/05/22 |00004000|
|03 |05| YES | 06D6D513 | 6D |06D5 | 13 | 2011/10/13 |00004800|
| Total Patch Size: 00013000 |
| MMTOOL 5.00.0007 |
|04 |01| YES | 0ED6E428 | ED |06E4 | 28 | 2014/05/29 |00003400|
|04 |02| YES | 0ED6E20D | ED |06E2 | 0D | 2013/03/21 |00003000|
|04 |03| YES | 06D6D710 | 6D |06D7 | 10 | 2013/06/17 |00004400|
|04 |04| YES | 06D6D619 | 6D |06D6 | 19 | 2012/05/22 |00004000|
|04 |05| YES | 06D6D513 | 6D |06D5 | 13 | 2011/10/13 |00004800|
| Total Patch Size: 00026000 |
| MMTOOL 5.00.0007 |
|05 |01| YES | 0ED6E428 | ED |06E4 | 28 | 2014/05/29 |00003400|
|05 |04| YES | 06D6D619 | 6D |06D6 | 19 | 2012/05/22 |00004000|
| Total Patch Size: 00039000 |
| MMTOOL 5.00.0007 |
|06 |01| YES | 0ED6E428 | ED |06E4 | 28 | 2014/05/29 |00003400|
|06 |04| YES | 06D6D619 | 6D |06D6 | 19 | 2012/05/22 |00004000|
| Total Patch Size: 0004C000 |
Enter number:7
Enter number:2
Found 5 module(s).
| MMTOOL 5.00.0007 |
|03 |01| YES | 0ED6E308 | ED |06E3 | 08 | 2013/03/21 |00002C00|
|03 |02| YES | 0ED6E008 | ED |06E0 | 08 | 2012/07/26 |00002C00|
|03 |03| YES | 00F6D304 | 0F |06D3 | 04 | 2011/04/20 |00004000|
|03 |04| YES | 00F6D20C | 0F |06D2 | 0C | 2011/05/03 |00004400|
|03 |05| YES | 0076D106 | 07 |06D1 | 06 | 2010/12/01 |00002C00|
| Total Patch Size: 00010800 |
| MMTOOL 5.00.0007 |
|04 |01| YES | 0ED6E308 | ED |06E3 | 08 | 2013/03/21 |00002C00|
|04 |02| YES | 0ED6E008 | ED |06E0 | 08 | 2012/07/26 |00002C00|
|04 |03| YES | 00F6D304 | 0F |06D3 | 04 | 2011/04/20 |00004000|
|04 |04| YES | 00F6D20C | 0F |06D2 | 0C | 2011/05/03 |00004400|
|04 |05| YES | 0076D106 | 07 |06D1 | 06 | 2010/12/01 |00002C00|
| Total Patch Size: 00021000 |
| MMTOOL 5.00.0007 |
|05 |01| YES | 0ED6E308 | ED |06E3 | 08 | 2013/03/21 |00002C00|
|05 |02| YES | 0ED6E008 | ED |06E0 | 08 | 2012/07/26 |00002C00|
|05 |03| YES | 00F6D304 | 0F |06D3 | 04 | 2011/04/20 |00004000|
|05 |04| YES | 00F6D20C | 0F |06D2 | 0C | 2011/05/03 |00004400|
|05 |05| YES | 0076D106 | 07 |06D1 | 06 | 2010/12/01 |00002C00|
| Total Patch Size: 00031800 |
| MMTOOL 5.00.0007 |
|06 |01| YES | 0ED6E308 | ED |06E3 | 08 | 2013/03/21 |00002C00|
|06 |02| YES | 0ED6E008 | ED |06E0 | 08 | 2012/07/26 |00002C00|
|06 |03| YES | 00F6D304 | 0F |06D3 | 04 | 2011/04/20 |00004000|
|06 |04| YES | 00F6D20C | 0F |06D2 | 0C | 2011/05/03 |00004400|
|06 |05| YES | 0076D106 | 07 |06D1 | 06 | 2010/12/01 |00002C00|
| Total Patch Size: 00042000 |
Enter number:9
--------- ME Analyzer v1.4.12 ---------
Firmware: Intel ME
Version: 8.1.51.1471
Release: Production
Type: Region, Extracted
FD: Unlocked
SKU: 1.5MB
VCN: 2
PV: Yes
Date: 28/08/2013
FITC Ver: 8.1.51.1471
Latest: No
@grml4d :
Thanks for your report.
I have moved it into this UBU Discussion thread, because the other one is reserved for SoniX and his announcements of a new UBU version.
Hi, as stated in the success/failure flashing bios thread, i coudn’t choose with ubu the cpu microcode update.
I have an amd fx 8350 cpu on a GA-990XA UD3 rev.3.0 mobo.
What i mean is this:
Can it be forced to update somehow?|addpics|6hp-1-b551.jpg-invaddpicsinvv|/addpics|
@kilyan :
Since your question is UBU related and can only be answered by SoniX, I have moved your post into this thread.
ok,thx
@ kilyan
Unfortunately microcode update for AMD processors are not supported.
ow…and can be updated manually eventually without ubu?
@ kilyan
Yes, only by hand. But too many pitfalls.
Microcode AMD processors are arranged differently than Intel. Even without Hex-editor can not do.
This question is better to know @lordkag.
ok i’ll wait him them,thx
i tested the bios and it did not worked…
i made an other one but without touching the :
and updating to the latest all others rom and the sabertoothx79 started well , i updated the Me firmware .
i wonder what has the microcode cpu update …i have a 3820 rev 1 , after the first one died killing the mobo .
so it is the first lga 2011 and its microcode should be well known. i plan to keep it instead of buying an other .
what cpus are updated with 7 ?
i ll check that by my side
i had a look at the original bios file and the ubu_cpu_updated file and found things
first , all cpu from my bios are removed…
secondly , my cpu are in “double” in the asus bios and in “quadruple” in ubu [ that should come the fact i applied both updates 206d7 and 206d6 ]
here is the list of cpu lga 2011 that should work with the mainboard : https://www.asus.com/Motherboards/SABERT…9/HelpDesk_CPU/
My Norton AV is saying theres a Trojan in the Ubu 1.51 package? I know Norton AV isn’t the best AV but anyone can explain please?
Thanks
EDIT by Fernando: Post moved into the correct UBU discussion thread. The other thread is reserved for the UBU guide and SoniX’s announcements of a new UBU version.
