@tistou77
Ok thanks. So I assume the R6E.CAP is the only one which works ?
@Sylar76 Yes
Can you tell me how to update UBU with MCE to the latest mCOde?
Only the developer SoniX can update UBU, but you can update the CPU Microcode by using the UBU tool. Just follow the UBU guide (=start post of the thread, where you wrongly posted your question).
At the moment, the next release of the UBU is delayed for personal reasons.If someone has not figured out how to add new microcodes
’UBU_Intel_Latest_mCode.rar"
https://cloud.mail.ru/public/z4dZ/JkpJvbcJb
Included latest MCE +DB + UEFIFind
Added:
@Fernando
For your Cloud download.
You can add the contents of this archive to the main archive of the UBU package under the name ‘UBU_1_70_rc20_1_Intel_mCode_update’’ or ‘UBU_1_70_rc20_1_t01312019’’
Thanks…
Aeeed2:
@plutomaniac
DrvVer 0.24.1 (Fix EFI IRST 17.0.1.0 RAI)
Thanks Fernando,
The banner of the tool v1.70.rc20.2 does remain v1.70.rc20.1 ?
Yes, because I didn’t want to touch the UBU.bat file.
Let it be so for now (20.1 as 20.2).
I will put myself in order and lay out in February version 1.71.
@SoniX :
To avoid any misunderstandings I just have renamed the updated UBU tool to “UBU_v1.70.rc20.1_updated-01-31-2019”.
Thanks for the updates!
Thanks for your fast-update! I have donate to you
I hope my compensation arrived via paypal!
New - EFI LAN Realtek Undi v2.047 (UEFI UNDI Driver)
Date published Jan 25th, 2019.
File size: 124Kb
https://www.realtek.com/en/component/zoo…xpress-software
5556V100.rar (5.8 MB)
!!! Do not upgrade the LAN in any way!
OROM XE (10Gb) in the composition of the UBU is not for x550 chips.
For such chirov there is another OROM.I will think about what can be done in such cases.
Thank you for the report.
Added:
Fixed in next version.
Any newier microcode for Skylake X platform 50654 than 02000057 ?
Intel RST EFI 17.0.1.0 RAID was ok how about 17.0.1.0 SATA OROM ?
I wish to testing both on 17.0.1.1075 WHQL soon.
Thank.
As long as nobody found a new BIOS module, we cannot offer it.
You should better ask Intel.
New 02000059 microcode for Skylake-X (cpu50654)
Extracted with UBU
@Sylar76 if you update the 1603 bios (Rampage VI Extreme)
Thanks
cpu50654_platB7_ver02000059_2018-12-20_PRD_D2B4FBC1.rar (32.3 KB)
@tistou77
Try https://cloud.mail.ru/public/JUJA/RSGLnF91Y
Update only latest mCode .
@SoniX
Thanks, I’ll test
@SoniX
It’s good, how did you do it ?
But always the same error when I want to open the bios with UBU
Thanks
@tistou77
This is a bug in MMTool. This problem can be circumvented like this:
1) Open in UEFITool 0.26.x
2) Find GUID B981F167-9D2B-4CA0-82E9-63DF0E3C3BF3
3) Extract As Is this GUID, example as _VBIOS_R6E_extr.ffs
4) Remove this GUID.
5) Save and Exit
Use UBU or MMTool.
After:
2) Find GUID B1DA0ADF-4F77-4070-A88E-BFFE1C60529A
3) Insert before - use file _VBIOS_R6E_extr.ffs
4) Save and Exit
