[ARCHIVE] Outdated UBU Tool related Questions, Reports and Suggestions
@ Fernando
Found a small bug. I corrected it, the new archive has time 13:05 and
MD5 f0abbc54bc8c484267810b2a50a9a7b8
SHA1 a1f8773426205894803404912852ae6910e0bf17
There is also a mirror on SendSpace.
Hi all,
I’m trying to update with UBU 1.8.0 my ASUS P8P67 Motherboard BIOS Version 3602:
http://dlcdnet.asus.com/pub/ASUS/mb/LGA1…7-ASUS-3602.zip
That’s what happened:
1. UBU 1.8.0
Select option for update
5 Marvell SATA Option ROM and EFI
OROM Marvell 88SE9120 - 1.0.0.1029
OROM Marvell 88SE9172 - 1.0.0.0022
Enter number:5
2. UBU 1.8.0
1 - Update OROM Marvell
OROM Marvell 88SE9120 - 1.0.0.1038
OROM Marvell 88SE9172 - 1.0.0.0032
0 - Exit Main Menu
Enter number:1
3. MMTool:
ERROR: insufficient space remains to add the file 2f4ddd35-f8c0-46d2-b0e3-a70136
0d7499
File Name : PcieLaneDXE
Volume Size Specified : 0x1F0000 bytes
Required size : 0x1F00C8 bytes
4. MMTool:
0d7499
Required size : 0x1F0128 bytes
5. UBU 1.8.0
* Update OROM Marvell SATA Device ID 9120 …Ok! ;Actually it’s not Ok
* Update OROM Marvell SATA Device ID 91a0 …Ok! ;Actually it’s not Ok
* Update OROM Marvell SATA Device ID 9172 …Ok!
* Update OROM Marvell SATA Device ID 917a …Ok!
OROM Marvell 88SE9120 - 1.0.0.1029 ;Must be 1.0.0.1038
OROM Marvell 88SE917a - 1.0.0.0032
Press any key to continue . . .
6. UBU 1.8.0
Enter number:
So the UBU can’t update the OROM Marvell 88SE9120 from 1.0.0.1029 to 1.0.0.1038 because of insufficient space remains to add the file 2f4ddd35-f8c0-46d2-b0e3-a701360d7499 (PcieLaneDXE)!
What I need to do to update Marvell 88SE9120 OROM to the latest version?
Thank you all in advance!
Regards,
mswg
@ mswg:
Welcome at Win-RAID Forum!
I can confirm, what you have written. This is what I got:
So it is not a bug of the UBU tool, but just a space problem of the AMI Aptio MMTool to replace the module.
Maybe SoniX knows a solution.
Regards
Fernando
Hi.
try modding this bios with UBU it can Update marvell sata modules: http://och.boxup.ir/fileup/uploads/14071391711.rar
EDIT by Fernando: Unneeded parts of the fully quoted text removed (to save space)
@ErfanDL
Yeah, thank you. I see than on your computer MMTool is working OK.
But on my computer and as we can see on Fernando’s computer MMTool is not working well.
I’ve tested this on 3 more machines and the result is always the same - Not working!
So I don’t know the reason.
Regards,
mswg
Do you like I mod your BIOS with latest update ?
@ mswg:
Very likely same problem like here with the very similar BIOS of the ASUS P8P67 (REV 3.1) BIOS 3602.
[Tool] “UEFI BIOS Updater” (UBU) (21)
Here is the reason:
an the solution:
I think the principle should work for your BIOS too because the main difference of the ASUS P8P67 and the ASUS P8P67 (REV 3.1) is only the different USB3-chip (NEC and ASMEDIA).
@mswg :
You can remove the following (unused) to gain some space:
Marvl ST (1b4b,917a): Removed, unused
Marvl ST (1b4b,91a0): Removed, unused
Marvl ST (1b4b,9120): Removed, unused
For the Marvel controller only (1b4b,9172) is used (tested, I own this board).
Nice TOOL… Thumbs up
Would wondering UBU 1.81 I saw cpu microcode there 1155over.ffs 6a7-28. while non overclock 6a7-29. rev 29 is better than 28? the overclock version is good because It wont cause to clear cmos if overlock fail. just wondering the microcode rev 29 any good for processor? thanks
@ 9tailsfox
As far as I remember, 28 microcode for stable overclocking requires less voltage than 29.
Hi all.
I’ve been reading a lot of extremely instructive and well written stuff around here and I’m almost ready to start using UBU. However I still have some questions. First one is for Sonix :wink:
I’ve noticed that Intel RST OROM 12.9.0.2006 with “TRIM6” support in UBU is different in 1 byte at offset 0x17 from the same modified OROM that can be downloaded from here. According to CPL0 method, modifyng that offset is not required for adding the TRIM support.
Hello SoniX! I can confirm that Rev 28 CPU micro-code for Sandy Bridge is better than Rev 29, and recently I’ve tested Rev 1B for Ivy Bridge and it’s seems that Rev 19 is better…
Would be nice to have in UBU an option for CPU micro-code update dedicated to Overclockers (SB 28/IB 19) and another option for people who want the latest CPU micro-code (SB 29/IB 1B)…
Thanks in advance for your patience and kindness.
Cheers,
KK
@ Reducer:
The checksum-8 of all original Option ROM files is 0 and the byte at offset 0x17 is the one, which can be altered to correct the checksum of the Intel RAID ROM modules. The TRIM modded Intel RAID ROM modules, which are within the UBU tool, are already checksum corrected, whereas the modules I am offering within the start post of >this< thread, are not yet checksum corrected. The manual checksum correction of modded Option ROM modules is not really required, because the BIOS tools like the AMI Aptio MMTool does the checksum correction automaticly while inserting the module.
So the difference between both modules is nothing to worry about.
Regards
Fernando
Ok. Will be done.
Hello SoniX and thanks a lot! Fast and kind as usual… :wink:
Cheers,
KK
hey, thanks. So meaning ver 28 is better than ver 29 for overclocking. because just wondering 29 microcode from date 2013 while 28 microcode is date 2012. So just wondering any improvement for the latest version. Seems like ver 28 is better I might flash to back to ver 28
EDIT: Great!
Hope to see the latest version with overclock feature. thanks
Edit by Fernando: I have merged the 3 posts to save space within this already very voluminous thread.
First, a big thanks to Sonix and Fernando for this handy utility. Since I got the following message (using v1.8.1):
3 LAN OROM PXE and EFI UNDI - Intel, Realtek, BCM, QCA
OROM Realtek PXE - 2.56
Found EFI Realtek UNDI - GUID Unknown. Please contact me.
I post here to let you know that I uploaded the BIOS file to http://1drv.ms/1ovPJKj
[Edit: I attached the extracted module here (GUID: 82CBD50E-D18A-46A8-B14B-4D206B33183F)]
I believe the PC has Realtek LAN integrated on MB, but can’t check right now because I changed disks to MBR to boot CSM for flashing under DOS, while OS is installed in GPT-mode. LAN did show up in EFI-mode under win8, but not in SCM-mode under win7.
Neither can I locate the chip on MB. Hth. If you need more information, I’m always willing to help.
Anyways, happy coding!
Rick.
RtkUndiDxe64_v2022.rar (38.2 KB)
@ rikiwiki:
Hello Rick,
welcome at Win-RAID Forum and thanks for your contribution!
Thanks for your feedback.
SoniX will be happy about your information.
Regards
Fernando
Unknown Intel LAN version.
My motherboard is BIOSTAR H81MG
My network card can not be normal use .Realtek RTL8111G
I can’t speak English.
Using translation software,
Hope to be able to understand.
Thank you, I have been concerned about this forum
OROM Realtek PXE - 2.60
Enter number:3
LAN OROM PXE and EFI UNDI Intel, Realtek, BCM, QCA
1 - Update ALL LAN OROM and EFI:
Realtek LAN OROM 2.60 EFI 2.028
0 - Exit Main Menu
Enter number:1
* Update EFI Realtek UNDI GUID 5A4D0030 -…Ok!
* Update OROM Realtek LAN PXE Device ID 8168…Ok!
RtkundilanX61_2_028.rar
http://pan.baidu.com/s/1sjK20jz
