@ kanikia-CN
False positives in DrvVer. Why, I’ll watch.
Added:
@kanikia-CN
@All
The corrected file DrvVer.exe
drvver.rar (44.6 KB)
@ kanikia-CN
Added:
@kanikia-CN
@All
@ kanikia-CN:
Welcome at Win-RAID Forum and thanks for your contribution, which will help SoniX to optimize his UBU tool.
Regards
Fernando
How can i know what is changed in OROM Realtek PXE - 2.60?
I have 2.59 in in my updated Bios,I downloaded PXE ROM code,PXE and RPL ROM code,UEFI UNDI Driver from http://www.realtek.com.tw/downloads/down…111G/RTL8111GUS but i cant find any “change log” or something similar in that files,there is just instructions for installation.
Thanks.
@ Veky83:
I have never seen an officially published changelog for BIOS modules done by the chipset manufacturer.
@SoniX
@Fernando
Thank you!
Problem solved.
Enter number:3
LAN OROM PXE and EFI UNDI Intel, Realtek, BCM, QCA
1 - Update ALL LAN OROM and EFI:
Realtek LAN OROM 2.60 EFI 2.028
0 - Exit Main Menu
Enter number:1
* Update EFI Realtek UNDI GUID 5A4D0030 -…Ok!
* Update OROM Realtek LAN PXE Device ID 8168…Ok!
EFI Realtek UNDI - 2.028
OK,thanks.
Not sure whether "officially published", but Broadcom offers a nice changelog for their LAN OROMs in their latest known Software Kit. Sample changelog/rev history from 16.0.1 (here) to 16.2.1 (in UBU 1.8.2):
wondering if there another silly options rev 29 /1B with overclock feature… haha
@ Reducer
Unfortunately, not always there is a description of the changes.
@ 9tailsfox
Do you have any suggestions?
That puzzled. ![]()
https://drive.google.com/file/d/0B2E2S35…dit?usp=sharing
It reminds me of a parody of Aptio 5. All modules OROM in GUID 9F3A0016-AE55-4288-829D-D22FD344C347.
Edit:
Who has ideas on how to update the BIOS without using such Hex Editor?
haha
always thought latest is the best.
If only it were so, the problems with the upgrade was much less.
@ SoniX can we also use this UBU tool to insert file, like to have a better native UEFI bios for Hackintoch, I seen in other forums people replacing file system and inserting them in Bios like for instance the HFS+ file system that this OS use and some other for example. Can u help me on that or can I find the files and U help me out I know they have to be in a FFS format not EFI but U should know what I’m talking about.
@ Camp Anaconda:
Welcome at Win-RAID Forum!
Although I doubt, that there will be an UBU tool option to insert any additional modules into the BIOS (UBU means "UEFI BIOS Updater"), only SoniX knows the answer.
I am sure, that you will get it very soon.
Regards
Fernando
Hello,
i have an ASRock H97 Pro4 Mainboard.
Is there a way to enable All Core Turbo for non K CPUs (like the Intel Xeon E3-1231 v3)
I read that you have to change the microcode from 306C3/9 to 306C3/7, but I don’t know how to do that^^
Thanks in advance
Never done it, so I can not say anything. ![]()
@Camp_Anaconda
You should check google for “Ozmosis” BIOS but it does not work for every UEFI. With my X79 Board I had too many problems on this.
Good hack hanson
EDIT: check this page for detailed “how to”
@ dewa710
In this case, you’d better contact support ASRock.
Thanks guy appreciate your answer I will look in to it, I know that read some where some forum that I don’t remember now about a tool that does this, I believe it was Aptio Tool, but anyway thanks.
@SoniX or @Fernando
Would you please locally upload UBU v1.7.0? My MB is either having a problem with the latest BIOS or the latest UBU. Asus updated the BIOS for IM memory use. I’d need v1.7.0 to test it out. I’ve blue screened once, woke up to a restart at the logon screen, and my network connection stopped working 3 times now. Thank you.
