This is what I have on them. As you can see, CloverView is rather thin and impossible to code a version detector based on the two samples.
C_View.rar (304 KB)
C_View.rar (304 KB)
@killer23d
Check mod. Change:
- IRST OROM and EFI 12.5.0.1815 -> 14.0.0.2209
- IRSTe OROM and EFI 3.8.0.1029 -> 4.1.0.1026
- LAN OROM Intel Boot Agent GE 1.5.50 -> 1.5.70
- LAN OROM Intel iSCSI Remote Boot 2.7.137 -> 3.0.48
- LAN EFI Intel PRO/1000 UNDI 5.4.19 -> 6.8.05
- VBIOS OROM Intel HSW-BDW 1030 -> 1038
- VBIOS OROM Intel HSW 2177 -> 2180
- EFI Intel GOP Driver 5.0.1034 -> 5.5.1032
- EFI Intel GOP Driver 5.0.1012 -> 5.0.1037
- Intel CPU Microcode 06C3 1C -> 1D
Lenovo_killer23d.rar (4 MB)
thanks creat the programe that make my computer work better on net.
maybe could add a function to select others after modded a bios file.
and a bug? if l keyin " " space,the programe will eject…
anyway thanks again ![]()
@ Shuan:
Welcome at Win-RAID Forum and thanks for your feedback.
Note: I have moved your post into the UBU discussion thread. The other UBU thread has been designed just for the guide and for new UBU releases d9one by the developer SoniX.
Which/what "others" do you mean?
Why did you try to edit quotation marks and space between them?
Regards
Dieter (alias Fernando)
@Sonix
Hi, sorry for bothering you. Could you explain me why on my Maximus VI Extreme mobo, UBU won’t update haswell vbios, leaving it at 2179 version instead than the new one ?
(It’s the same for me, of course, but I’d like to know why ubu doesn’t update it).
Thanks in advance.
For update in UBU Tool (only v1.20 and above), files saved as:
- Sandy/IvyBridge -> ‘Modules\VGA\vbiossib.dat’
- Hasweell/Broadwell -> ‘Modules\VGA\vbioshsw.dat’
sorry …my terrible english orz
i mean…
1.if i want to select other bios that is different MB ,seem to back desktop and run the program again?
2.that because i keyin spacebar and the programe show something then close…
1. Remove these strings. And you will always have the choice of a new file from any location.
for /f "tokens=*" %%i in ('dir *.CAP *.ROM *.F?? *.BS? *.0?? *.1?? *.2?? *.3?? *.4?? *.5?? *.6?? *.7?? *.8?? *.9?? *.??0 *.??1 *.??2 *.??3 *.??4 bios.bin /b') do (
echo %%i
set biosname=%%i
if /I %%i==bios.bin (
goto rise
) else (
if /I exist bios.bin del /f /q bios.bin
ren "%%i" bios.bin
goto rise
Thank you Sonix for not only making this app but also for the continuing of updates for it.
I used it this evening (Version 1.27) and when it came to updating the CPU code, there were two listings
1 for Haswell and 1 for Broadwell. I just updated the Broadwell and there is now only 1 listed and that lists
as Haswell/Broadwell, have I done this right or, did I mix it up? I have just bought a new i7 4790K cpu and just
wanted to make sure that the BIOS was as up to date as it could be.
If you require pics I can do it again. Thanks in advance. ![]()
@ Pendaws
[Discussions] UBU Tool related Questions, Reports and Suggestions (101)
If you do not use the processor Broadwell, then do not update its microcode.
I tried to flash it in both DOS and BIOS Recovery, it gives a warning on integrity check and stopped. I don’t think I can flash the BIOS without signing it.
Thanks for the work though.
You have to use the "Bios Flashback" procedure putting this bios into a USB Stick (NTFS formatted).
Shouldn’t it be FAT32 formatted?
Look >here<.
That’s an Asus feature ![]()
For the ThinkServer, I already tried to use the BIOS Recovery USB and it won’t even flash. When I put the original BIOS, it will flash regardless.
June 2015 microcode update for Intel processors in Windows
https://support.microsoft.com/en-us/kb/3064209
This update improves the reliability of systems that use certain Intel processors. This update also fixes some issues that could cause the operating system to function incorrectly.
(Didn`t know whether to create new thread, so did post in most related to CPU microcode thread.)
>Here< is a special CPU Microcode thread.
SoniX, I have thanked you before for making this utility available but I must now thank you again for the well laid out instructions of how to use it.
I used it to modify my BIOS and today I plucked up the courage to install it, WOW, it sure did help.
One thing I would ask, is there a way to change the BIOS number? The version that was on my machine was F6 and I wanted to change that number
to reflect the modification but, even though I called it F6B, it still shows as F6. Other than that little thing, it is great. ![]()
@ Pendaws
For detailed instructions thank Fernando. ![]()
I think that you can change the version of the BIOS, utilities use ~ DMIEdit or AMIBCP.
I am wondering if it is not posible to create a UBU Tool but only for the Aptio V BIOS where the the script uses UEFITool to replace the IRST EFI and OROM files.
This should be doable to create a script similar to that of UBU Tool where it scans the Aptio V BIOS and lists the IRST EFI and OROM versions inside the BIOS
just as it does now and also lets you update the BIOS with the collection of IRST EFI and OROM files included with it.
If I use a series 6-chipset motherboard, I wouldn’t need to use the Intel BMP to actually upgrade my iGPU vBIOS, right?
Also, would the v124_ILT be applicable in my environment or should I just use the latest v127?
