Yes, I never have internet connected during any OS install, ever, since XP and before until today and beyond.
Disable your internet adapter, or remove it for a minute if you have key stored and set to always connect (I’d remove, in case MS auto-connects it). Or shut off router until you are done, that way no connection possible.
If you are using ISO installers, there is nothing to download (upgrade or not, do not download anything)
"The OS installation has to be done in UEFI mode by using the GUIMode Partion Table scheme (MBR partition scheme only possible with the Samsung 950 Pro SSD). Otherwise you will not be able to boot off the NVMe SSD. Fur further details please look into the chapter “Installation of the OS onto the NVMe SSD”, which you can find within the start post of >this< thread."
GPT option is greyed out. Please see the screenshot below:-
Appreciate if someone could please advice how to proceed. I’ve completed the steps to integrate the Hotfix & NVMe drivers into the WIM image using NTLite already, now stuck at Rufus.
ETA: Nevermind, sorry!! Turns out I used the wrong ISO. Popped the right one into Rufus and GPT etc. were all available. My bad!
Thanks for this useful information
Hi, i have motherboard GA H55M-S2H and SSD Gigabyte NVMe M2 whit adapter, but dont function in windows 7 64bits.
Maybe are windows not compatibility? Help me plz, im speak spanish better than english ![]()
@Kyo23 - I suggest you use my guided method to clone Win7 to NVME
Post #5 - Installing Clean Win7x64 on M2.2280 PCIe Gen3x4 SSD A-DATA SX8200 Pro
Hi, i have motherboard Gigabyte H55M-S2H rev and i tried install SSD M.2 NVMe 128gb whit adapter NVMe PCIe x4 M.2…but my BIOS does not recognize the disk to install the operating system.
Maybe can help me?
My BIOS are this:
Flash memory tipe: Winbond 25Q64V
Flash memory size: 64M bits
BIOS sign on message: H55M-S2H F7
BIOS vendor: AWARD BIOS
I already tried windows 7 and 10 but could not.
Hi, i also have a intel H370 i tried to install windows 7 with the usb 3 drivers with ntlite but every time i install the iso it bluescreens, can you please help me?
@Turboslayer123 - your probably hitting a Win7 incompatibility with the board/BIOS, nothing to do with NVME or USB 3.0
Can you install Win7 without adding the USB drivers? If not, then it may be this, or it may be you are not adding them correctly, try another tool/method etc.
Sorry, I can’t help with that, but there is many guides about this in google. Intel/AMD/Microcosoft are actively trying to block/remove compatibility with older systems, and have been since Z170 era, so it may be your board/BIOS more than a simple driver issue.
@Kyo23 :
You got the answer to your request already >here<.
To be able to boot off an NVMe SSD (only exception: Samsung 950 PRO) a mainboard with an UEFI BIOS is required.
Can someone please tell me, what I am doing wrong? (or if I am doing nothing wrong at all but my approach may simply not work…)
I always get the error “a required CDROM drive driver is missing” during Win7 Setup Menu when I only integrate the MS NVMe Hotfixes - if I use the original Samsung NVMe driver 3.3 instead (only; without the NVMe hotfixes), then everything finally works fine and I can install Windows 7! But I do want to integrate the NVMe Hotfixes only and install Samsung’s NVMe driver after having installed Windows 7!
Since Fernando recommended me to only integrate the MS NVMe Hotfixes (the original Samsung NVMe driver I’ll install AFTER having successfully installed Win7) into install.wim and boot.wim, I did exactly as told and integrated only those 3 NVMe Hotfixes along the modified Z390 USB drivers and some essential Windows Updates (I did NOT integrate the Windows Updates into “boot.wim”, though - only “install.wim” !).
C:\Windows\system32>cd “C:\Program Files\Windows AIK\Tools\amd64\Servicing”
[Preparing install.wim]
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Get-WimInfo /WimFile:C:\Win7\sources\install.wim
Details für Abbild: "C:\Win7\sources\install.wim"
Index: "1"
Name: "Windows 7 HOMEBASIC"
Beschreibung: "Windows 7 HOMEBASIC"
Größe: 11.623.452.494 Bytes
Index: "2"
Name: "Windows 7 HOMEPREMIUM"
Beschreibung: "Windows 7 HOMEPREMIUM"
Größe: 12.136.659.100 Bytes
Index: "3"
Name: "Windows 7 PROFESSIONAL"
Beschreibung: "Windows 7 PROFESSIONAL"
Größe: 12.037.929.390 Bytes
Index: "4"
Name: "Windows 7 ULTIMATE"
Beschreibung: "Windows 7 ULTIMATE"
Größe: 12.200.638.813 Bytes
Der Vorgang wurde erfolgreich beendet.
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Mount-Wim /WimFile:C:\Win7\sources\install.wim /index:1 /MountDir:C:\Win7Mount<br />
Tool zur Abbildverwaltung für die Bereitstellung
Version: 6.1.7600.16385
Abbild wird bereitgestellt
[==========================100.0%==========================]
[Integrating the most essential Windows Updates]
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Image:C:\Win7Mount\ /Add-Package /PackagePath:"C:\Users[USERNAME][PATH TO MSU FILE]\Windows6.1-KB2670838-x64.msu"
Abbildversion: 6.1.7600.16385
1 von 1 werden verarbeitet - Paket “C:\Users[USERNAME][PATH TO MSU FILE]\Windows6.1-KB2670838-x64.msu” wird hinzugefügt
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Image:C:\Win7Mount\ /Add-Package /PackagePath:"C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb2834140-v2-x64_3db9d9b3dc20515bf4b164821b721402e34ad9d6.msu"
1 von 1 werden verarbeitet - Paket “C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb2834140-v2-x64_3db9d9b3dc20515bf4b164821b721402e34ad9d6.msu” wird hinzugefügt
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Image:C:\Win7Mount\ /Add-Package /PackagePath:"C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb2758857-x64_5e0aa18e88295276eb27aee6161c6a0ba3093d70.cab"
1 von 1 werden verarbeitet - Paket “Package_for_KB2758857~31bf3856ad364e35~amd64~~6.1.1.0” wird hinzugefügt
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Image:C:\Win7Mount\ /Add-Package /PackagePath:"C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb2852386-x64_3f924a0866401d6796413ad46ada8bb862e6c2c9.msu"
1 von 1 werden verarbeitet - Paket “C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb2852386-x64_3f924a0866401d6796413ad46ada8bb862e6c2c9.msu” wird hinzugefügt
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Image:C:\Win7Mount\ /Add-Package /PackagePath:"C:\Users[USERNAME][PATH TO MSU FILE]\Windows6.1-KB4019990-x64.msu"
1 von 1 werden verarbeitet - Paket “C:\Users[USERNAME][PATH TO MSU FILE]\Windows6.1-KB4019990-x64.msu” wird hinzugefügt
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Image:C:\Win7Mount\ /Add-Package /PackagePath:"C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb4474419-v3-x64_b5614c6cea5cb4e198717789633dca16308ef79c.msu"
1 von 1 werden verarbeitet - Paket “C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb4474419-v3-x64_b5614c6cea5cb4e198717789633dca16308ef79c.msu” wird hinzugefügt
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Image:C:\Win7Mount\ /Add-Package /PackagePath:"C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb4490628-x64_d3de52d6987f7c8bdc2c015dca69eac96047c76e.msu"
1 von 1 werden verarbeitet - Paket “C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb4490628-x64_d3de52d6987f7c8bdc2c015dca69eac96047c76e.msu” wird hinzugefügt
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Image:C:\Win7Mount\ /Add-Package /PackagePath:"C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb4536952-x64_87f81056110003107fa0e0ec35a3b600ef300a14.msu"
1 von 1 werden verarbeitet - Paket “C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb4536952-x64_87f81056110003107fa0e0ec35a3b600ef300a14.msu” wird hinzugefügt
[Integrating the Microsoft NVMe Hotfixes in the following order:]
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Image:C:\Win7Mount\ /Add-Package /PackagePath:"C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb2908783-x64_cc0fdf4fd413cf7ff72452f0a87d257e3f49901f.msu"
1 von 1 werden verarbeitet - Paket “C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb2908783-x64_cc0fdf4fd413cf7ff72452f0a87d257e3f49901f.msu” wird hinzugefügt
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Image:C:\Win7Mount\ /Add-Package /PackagePath:"C:\Users[USERNAME][PATH TO MSU FILE]\Windows6.1-KB2990941-v3-x64.msu"
1 von 1 werden verarbeitet - Paket “C:\Users[USERNAME][PATH TO MSU FILE]\Windows6.1-KB2990941-v3-x64.msu” wird hinzugefügt
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Image:C:\Win7Mount\ /Add-Package /PackagePath:"C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb3087873-v2-x64_098e3dc3e7133ba8a37b2e47260cd8cba960deb8.msu"
1 von 1 werden verarbeitet - Paket “C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb3087873-v2-x64_098e3dc3e7133ba8a37b2e47260cd8cba960deb8.msu” wird hinzugefügt
[Integrating the Z390 USB Drivers]
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Image:C:\Win7\ /Add-Driver /Driver:“C:\Users[USERNAME][…]\INTEL USB3.1 Driver 64bit” /Recurse /ForceUnsigned
Suche nach zu installierenden Treiberpaketen…
Anzahl der zu installierenden Treiberpakete: 3.
1 von 3 - C:\Users[USERNAME][…]\INTEL USB3.1 Driver 64bit\Hub Driver\iusb3hub.inf wird installiert: Das Treiberpaket wurde erfolgreich installiert.
2 von 3 - C:\Users[USERNAME][…]\INTEL USB3.1 Driver 64bit\Switch Driver\iusb3hcs.inf wird installiert: Das Treiberpaket wurde erfolgreich installiert.
3 von 3 - C:\Users[USERNAME][…]\INTEL USB3.1 Driver 64bit\XHCI Controller Driver\iusb3xhc.inf wird installiert: Das Treiberpaket wurde erfolgreich installiert.
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Unmount-Wim /MountDir:C:\Win7Mount /Commit
Abbilddatei: C:\Win7\sources\install.wim
Abbildindex: 1
Abbild wird gespeichert
Bereitstellung des Abbilds wird aufgehoben
[Repeating the above procedure for the remaining 3 indexes (index:2, index:3, index:4) of the install.wim file]
[Preparing boot.wim]
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Get-WimInfo /WimFile:C:\Win7\sources\boot.wim
Details für Abbild: "C:\Win7\sources\boot.wim"
Index: "1"
Name: "Microsoft Windows PE (x64)"
Beschreibung: "Microsoft Windows PE (x64)"
Größe: 993.105.022 Bytes
Index: "2"
Name: "Microsoft Windows Setup (x64)"
Beschreibung: "Microsoft Windows Setup (x64)"
Größe: 1.082.679.703 Bytes
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Mount-Wim /WimFile:C:\Win7\sources\boot.wim /index:1 /MountDir:C:\Win7Mount
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Image:C:\Win7Mount\ /Add-Driver /Driver:“C:\Users[USERNAME][…]\INTEL USB3.1 Driver 64bit” /Recurse /ForceUnsigned
Abbilddatei: C:\Win7\sources\boot.wim
Abbildindex: 1
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Mount-Wim /WimFile:C:\Win7\sources\boot.wim /index:2 /MountDir:C:\Win7Mount
C:\Program Files\Windows AIK\Tools\amd64\Servicing>dism /Image:C:\Win7Mount\ /Add-Package /PackagePath:“C:\Users[USERNAME][PATH TO MSU FILE]\windows6.1-kb3087873-v2-x64_098e3dc3e7133ba8a37b2e47260cd8cba960deb8.msu"
Abbildindex: 2
[Creating ISO]
C:\Program Files\Windows AIK\Tools\amd64\Servicing>cd “C:\Program Files\Windows AIK\Tools\amd64"
C:\Program Files\Windows AIK\Tools\amd64>oscdimg.exe -m -o -u2 -udfver102 -lWIN7 -bootdata:2#p0,e,b"C:\Win7\boot\etfsboot.com”#pEF,e,b"C:\Win7\efi\microsoft\boot\efisys.bin” “C:\Win7” "C:\Win7-ISO\Test.iso"
OSCDIMG 2.55 CD-ROM and DVD-ROM Premastering Utility
Copyright (C) Microsoft, 1993-2007. All rights reserved.
Licensed only for producing Microsoft authorized content.
Scanning source tree (500 files in 11 directories)
Scanning source tree complete (883 files in 206 directories)
Computing directory information complete
Image file is 3814653952 bytes (before optimization)
Writing 883 files in 206 directories to C:\Win7-ISO\Test.iso
100% complete
Storage optimization saved 44 files, 20293632 bytes (1% of image)
After optimization, image file is 3796680704 bytes
Space saved because of embedding, sparseness or optimization = 20293632
Done.
After completing all this, I “burned” the ISO onto a USB thumb drive and then applied Manatail’s UefiSeven fix for pure UEFI in Win7 without CSM.
And then I booted Win7 Setup from the USB thumb drive in UEFI mode… (CSM and SecureBoot disabled!)
And I still get the above mentioned error…
Please help!
AZ
EDIT by Fernando: Post shortened by putting the procedure details into a “spoiler”
Hello again,
After installation of USB 3.0 drivers and starting up a win 7 setup, Im facing problem that win 7 setup does not see the ssd to install. Previously on laptop there was a win10 working correctly. But it has been removed. The chipset is cm236 intel, and the drive is NVMe m2 ssd.
The funny thing is that, after updating iso with hotfix, the win7 seteup sees the ssd. And it is possible to install OS, but only if power supply cable is disconnected from my dell 5510 precision.
When the cable is conneected, after the hotfix update, the system is not booting up and even it can not start the setup from usb and it is facing blue screeen with Driver_irql_not_less_or_equal
0x000000D1 … stornvme.sys
Thee bios is uefi mode
Any ideas?
@AbsoluteZero :
The message "A required CDROM driver is missing" is obviously misleading, because the CDROM doesn’t need a 3rd party driver. Maybe a matching USB driver is missing?
That was a mistake. Storage drivers and the related MS Updates have to be integrated into the BOOT.WIM as well, because they are already required during the first steps of the OS installation.
Question: Which 3 MS NVMe Hotfixes did you integrate? I only know 2 of them and required is just 1 Hotfix (the other is a bug fix for old Win7 Editions).
@osdyseus :
To be honest I don’t have any idea regarding the specific source of your problem.
Maybe the Dell Support can help you (too much power/wrong voltage?).
Okay, the thing is that I installed win7 on my dell without a power cable, and after installation all drivers it runs correctly. BUT, finishin the topic, I am verey disappointed bcs I hold a latitude e6330 which is much slower with specification and boot up faster than my dell 5510…
@osdyseus : The booting time depends on other things than the performance.
My advice: Check the BIOS settings and the system drive connection of your Dell 5510.
@all users, who want to install Win7 onto an NVMe SSD:
A few days ago our Forum member Black6spdZ gave us the hint to previously unknown WHQL certified generic 32/64bit Phison NVMe drivers v1.5.0.0 dated 02/23/2018 for Win7 (Win8-10 drivers are available as well). Due to the fact, that these Phison NVMe drivers are generic (all NVMe Controllers are supported) and WHQL certified by Microsoft, they should be usable from scratch for Win7 users (either integrated into the OS Image or loaded during the OS installation), no matter which specific NVMe SSD is the target drive.
>Here< are the download links to these freshly discovered Phison NVMe drivers.
Especially the option to simply load the Phison NVMe driver at the beginning of the Win7 installation would be a big relief for the Win7 users, because the integration of the MS Hotfixes into the Win7 Image would be dispensable.
Before I am going to customize the start post of this thread, I need a proof, that this option really works.
So it would be very helpful, if anybody can test the F6 driver loading during the Win7 installation and give us a short feedback about the test result.
Thanks in advance!
I’ll image my old system and try this.
Any updates on this one?
Hello,
i’m trying to Install Windows 7 on a Dell 05R3W6 Notebook Mainboard.
The CPU is a Core i5-1021U.
The Setup hangs at the Reboot and the “Setup is Updating Registry Settings”.
I already Integrated the Modded NVME Drivers with NTlite and Installed it with Windows 10 PE.
The NVME Controller HWID: DEV_2263
@umount : Welcome to the Win-RAID Forum!
It doesn’t make sense to integrate a modded storage driver - only WHQL certified storage drivers are accepted by the OS Setup.
If you want to get Win7 installed onto an NVMe SSD, you should either integrate the related MS NVMe Hotfixes for Win7 or the generic Phison NVMe driver for Win7 (both listed >here<).
Anyway you have to install the OS in UEFI mode using the GUImode Partition Table (GPT).
Good luck!
Dieter (alias Fernando)
