Hello WinRaid forum
CPU: AMD Ryzen 2920X
Mainboard: Gigabyte AORUS x399 Extreme
HDD Western Digital (for data back, up not always connected, MBR)
SSD M2 Samsung 970 (for boot drive and day by day use, GPT)
I have a multiboot (GRUB boot loader and Windows boot loader) with Linux Kali and Windows 11.
I am a little nostalgic about Windows XP and I want to install it on the SSD M2, GPT.
I did the following steps:
a. run Easy2boot tool with the .iso âWindows XP Pro x86 VL Service Pack 3 en-US September 2018â.
b. started the setup process, pressed F7 to bypass the ACPI verification by the setup
I receive the normal message from the setup that no drives are found and I can press F3 to exit
a. integrated âAMD AHCI driver 1.2.1.321â with nLite on the .iso âWindows XP Pro x86 VL Service Pack 3 en-US September 2018â.
b. started the setup process with Easy2boot tool and the option âInstall XP using WinPEâ (because setup is not starting with this modified .iso), pressed F7 to bypass the ACPI verification by the setup
I receive the error âamd_sata.sys could not be foundâ
a. downloaded âSTORPORT.zipâ from this forum
b. extract and copy âstorport.sy_â to âI386â folder
c. edit âtxtsetup.sifâ with a new line âstorport.sys = 100,4,0,0â
d. rebuild the .iso with nLite
e. again started the setup process with Easy2boot tool and the option âInstall XP using WinPEâ (because setup is not starting with this modified .iso), pressed F7 to bypass the ACPI verification by the setup
I receive the error â0x0000007Bâ, so I understand I didnât integrated the correct drivers.
Please advise on how to proceed further.
Thank you !
PS: I noticed âGeorge_Kingâ notes about his tool âXP2ESDâ but I didnât find it to download it.
