[Guide] Transfer of specific Intel OROM VBIOS and GOP VBT settings by using Intel BMP tool
Thank you. For the setting in iBMP I know what most of them do and the meaning.
But I could not figure out how to extract and what to extract. And also what each VBT do.
That is why I was lost.
I need to extract EFCB9C70-8705-41EF-939D-B7818C80E60E with UEFITool ?
(This I don’t know how to do, I will try to figure it out)
Then I load it in iBMP with 203 vbt.bsf from your mega archive.
Then I Change the settings in iBMP, and save. To upload it back to the BIOS with UEFITool.
For now Thank you for telling me only 203 was active, did you check if it has 52Hz refresh rate locked ?
EDIT : Thank you for the extract, I did not know how to do it !
I can edit these files in iBMP now ?
EDIT2 : I Found the problem of why the panel was unable to be recognized, and it took me 2 minutes with iBMP.
I can’t understand how a company was not able to understand this !
And it was thanks to you SoniX, without you I would have found nothing.
Now I will try to understand why it is locked at 52Hz, wish me luck !
@vigan1
Ok.
Use only UEFIYool v0.25.0
1) Open BIOS to UT (UEFITool)
2) Ctrl+F - Find as GUID
3) Locate on file (RAW Section)
4) "Extract body"
5) Edit this file to iBMP eith vbt.bsf v203
After
1-3
4) "Replace body"
5) Save and exit and flash
I don’t know how to thank you ! Thank you so much.
Can I Flash with the manufacturer method (a fat32 usb in the built in uefi shell) or should I order a EEPROM Flash BIOS USB Programmer ?
@vigan1
The BIOS turns out to be modified, so there can be a lot of nuances.
But get ready for a brick. So before flashing BIOS, you need to take care of the recovery options.
How to flash this is no longer for me.
Yes, I will definitely buy a flasher, I know about bricked devices, and will look for recovery before flashing.
I will not touch at default settings, because I found out this laptop is very picky about settings and sometime will not post when some settings have been modified (I remove the battery and it start again with default).
I will first try with only the gop modified settings, it should be close enough. because the 2017 and 2018 are basically the same bioses, only with 203 different settings.
I will try using replace with UEFITool now. Thank you.
Ok. Good luck!
Hi I did the vbt mod with iBMP.
I replaced the vbt guid with UEFITool v0.25. Then I compared both bios and the hex are very different !
But it’s probably normal, because even when I compare both 2017 and 2018 hex they are also very different.
I will order the black CH341A Black usb Flasher. I hope I will receive one with 3.3V, because I read there is an old version with 5V on the pins :
https://www.youtube.com/watch?v=-ln3VIZKKaE
I don’t know if you knew this. Check your version to not damage chips.
I want a method that create bios to be flashed by USB. So I can edit and flash easily.
Thank you very much. The bios is ready but I did not test it yet I am waiting to receive the flasher.
I hope god or someone will help you as much as you help the others.
UPDATE :
HI it worked perfectly I could flash the bios from the USB drive.
Thank you very much for you patience and kindness, I appreciate it !
@SoniX - Can you please spare me a few minutes to help user who is doing good for his community and using donated systems to help local children to learn piano for free
I need to update VBT and GOP for this user, on two different BIOS, for now I am focusing on one as test subject to see if this helps to solve his issue. https://download.gigabyte.com/FileList/B…455n-d3h_f3.zip
User has no display at startup/Win10 loading etc, when using UEFI mode. He would prefer to use Win7, but that has other issues in OS with Intel driver and or Standard MS VGA driver.
Hoping maybe update of these items will help with at least one of those scenarios (preferably Win7, but I doubt)
The structure, or build method(?), of this BIOS is such that you cannot view DXE volume in any UEFITool, only in MMTool 5.02.0024/25
Replacing 24 with 25 does not help to find and define items in UBU Scan either, so all must be found and worked on manually from MMTool
Anyway, the question I have that I hope you can help with, there is 5x “Broxton” VBT in there, and I’m not sure why, or if I should update them all or somehow find out which is used etc?
All files are located at bottom in MMTool
GOP is 1030 - GUID - A0327FEFE0-xxx
VBT 1-5 GUID’s as noted below
E08CA6D5-GOPVBT1
DBADD769-GOPVBT2
C7DCFF6F-GOPVBT3
B850A139-GOPVBT4
21E70404-GOPVBT5
I guess my main question is >> Can I update the VBT’s via CloneVBT? If yes, to what should I use, I don’t think Broxton VBT in GOP/VBT package, which now I see will be an issue with below statement too
I assume I can update the GOP via BMP, so no question there.
Thanks, hope you can help!
Other system is the following, in case you have time and don’t mind updating or looking etc.
I’ve not looked into this one to gather info yet, but BIOS structure is same so same method must be used
https://download.asrock.com/BIOS/CPU/J3455-ITX(1.80)ROM.zip
@Lost_N_BIOS If I read that correctly you can’t update with CloneVBT, version wouldn’t be same, and size wouldn’t be same. I can confirm that at least for IVB, clonevbt doesn’t work for an update.
@SoniX Is there a way to find out which VBT a system/ bios does use in such a case?
(Why are manufacturers configure a bios with 5 different VBTs for UEFI but just one single orom with one single configuration for legacy? Just used an unchanged reference design? I own a Samsung HM75 notebook with 5 VBTs- 4 IVB, 1 SNB and would really like to know which one’s used by the dxe)
@lfb6 - Yes, I don’t know, that is why I asked. Yeah, I guess cloneVBT would not be ideal in update due to update
I think these different VBT’s are used for different display outputs, but I can’t be sure. Something I was looking at in there made me think such, but I’m not looking at the BIOS right now.
If I update my IVB GOP VBT from 165 to 174 with settings tranfer accoording to the book I have a dark screen until windows starts.
Samsung NP300E5C, HM 75, i7-3820qm, Phoenix bios- updated GOP drivers from 3.0.1015 to 3.0.1030 (IVB) [and 2.0.1018 to 2.0.1024 (SNB)] long ago, working fine with old GOP VBT 165
4 GOP VBT IVB, 1 GOP VBT SNB in bios, see picture
Relevant/ used is the first GOP VBT with the GIUD beginning with 60… .
If I leave this GOP VBT with 165 everything is fine, if I update this GOP VBT with 174 with settings transfered according to the book I get no picture/ a dark screen (no backlight, too) until graphic mode of Windows comes up.
There aren’t many settings changed/ added when changing from 165 to 174, tried to change these settings, but to no avail.
Tried another LCD- panel, same behaviour.
Tried a working GOP VBT 174 taken from another IVB notebook, same behaviour.
Tried the working GOP VBT 174 (taken from another IVB notebook) with the panel it works with in other notebook, same behaviour.
Someone an idea what’s the reason for this behaviour?
Thanks in advance!
PAGE VBT Information
PAGE Chipset Selection
$Chipset 14
PAGE Message Options
STRING $Signon Intel(R) Sandybridge/Ivybridge PCI Accelerated SVGA BIOS\r\nBuild Number: 0000 PC 14.34 10/12/2011 21:46:24\r\nDECOMPILATION OR DISASSEMBLY PROHIBITED\r\n
$Msg_Enable 01
$Cls_After_Signon 00
PAGE General Features
$CRT_DDC_GMBUS_Pin 02
$LFP_DDC_GMBUS_Pin 03
$bmp_Display_Detect 00
$CUIHotK_Static_Display 00
$Single_DVI_I 00
$Int_CRT_Support 01
$DP_SSC_Enb 00
$DP_SSC_Dongle_Enb 00
$FDI_RX_POL 00
$Embedded_Platform 00
PAGE General Video BIOS Features
$bmp_VBIOS_Post_Mode 00
$bmp_Resize_PCI_BIOS 01
$DPMS_AIM_Bit 01
$Enable_LFPOn_Override 00
$Allow_Boot_DVI 00
$Enable_Panel_Fitting 03
$Override_VGA_720p 00
$Hotplug_Support_Enb 00
$Enable_Panel_Timing 00
PAGE General Driver Features
$VBT_Customization_Version 00
$Driver_Boot_Device 00
$Allow_FDOS_Disp_Switch 00
$Hot_Plug_DVO 01
$Hot_Plug_CRT 01
$Enable_LFP_Primary 00
$Use_110h_for_LFP 00
$DVD_Sprite_Clone 01
$GTF_Mode_Pruning 00
$Sprite_Display_Assign 00
$Enable_Int_Src_Term 00
PAGE Display Features
$CUI_Maintain_Aspect 01
$Preserve_Aspect_Ratio 00
PAGE Legacy Monitor Mode Limit
$Legacy_Monitor_Max_X 00 00
$Legacy_Monitor_Max_Y 00 00
$Legacy_Monitor_Max_RR 55
PAGE Power Conservation
$SDVO_Device_Power_Down 00
$PC_Fields_Enable 01
$PM_RMPM_Enable 01
$PM_S2DDT_Enable 01
$PM_DPST_Enable 01
$BIA_Aggress_Level 06
$PM_BLC_Enable 01
$PM_ADB_Enable 01
$PM_DRRS_Enable 01
$PM_RS_Enable 01
$PM_GPMT_Enable 01
$PM_Turbo_Enable 01
PAGE ADB Response Data
TABLE $ALS_Response_Data 46 00 00 00 49 00 0A 00 55 00 50 00 64 00 2C 01 96 00 E8 03
PAGE Rotation Configuration
$Rot_Enable 01
PAGE Graphics Mode to Boot on Windows
$Driver_Boot_Mode_X 56 05
$Driver_Boot_Mode_Y 00 03
$Driver_Boot_Mode_BPP 08
$Driver_Boot_Mode_RR 3C
PAGE Driver Persistence
$Driver_Persist_PM 01
$Driver_Persist_Lid_Switch 01
$Driver_Persist_Hotkey 01
$Driver_Persist_Docking 01
$PersistHotkeyRestoreCloneMDS 01
$PersistHotkeyRestoreRefreshrate 01
$PersistHotkeyRestorePipe 01
$PersistHotkeyRestoreMode 01
$PersistEDIDRestoreMode 01
$PersistHotPlugRestoreMode 01
$PersistMaxConfig C8
PAGE TV Features
$Under_Over_Scan_Via_YPrPb 00
$Under_Over_Scan_Via_HDMI 00
$Add_Overscan_Mode 00
PAGE Boot Display Algorithm
TABLE $Dev_Boot_Table 09 08 00 0C 04 00 48 40 00 28 20 00 05 01 00 41 00 00 21 00 00 44 00 00 0D 00 00 45 00 00 64 00 00 49 00 00 29 00 00 4C 00 00 24 00 00 2C 00 00
PAGE Display Device Toggle Lists
PAGE Display Toggle List 1
TABLE $IVM_Toggle_List1 01 09 08 02 05 04 0C 00 00 00 00 00 00 00 00 00
PAGE Display Toggle List 2
TABLE $IVM_Toggle_List2 01 09 08 02 05 04 0C 00
PAGE Display Toggle List 3
TABLE $IVM_Toggle_List3 01 09 08 02 05 04 0C 00
PAGE Display Toggle List 4
TABLE $IVM_Toggle_List4 01 09 08 02 05 04 0C 00
PAGE System BIOS Hooks
$H14_Get_Misc_Status 01
$H31_POST_End_Hook 00
$H33_After_Mode_Set 00
$H34_Set_LFP_Fitting 01
$H35_Bootup_Display 01
$H36_Boot_TV_Format 00
$H38_Before_Mode_Set 00
$H40_Set_Panel_Type 01
$H45_VESA_DDC_Hook 00
$H46_VESA_PM_Hook 00
$H47_Notify_Display_Sw 00
$H48_After_VESA_PM 00
$H49_Get_BL_Inv_Pol 01
$H51_LFP_Panel_Type 01
$H52_LFP_Panel_Color_Depth 01
$H53_Get_EDID_SBIOS 00
$H54_Get_Int_DP_HDMI_Cfg 00
PAGE Modes Removal Table
TABLE $Mode_Rem_Table 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF
PAGE Display Configuration Removal Table
TABLE $Dev_IVM_Removed_Table 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE OEM Customizable Modes 2.0
PAGE OEM Mode #1
$OEM_Mode_Flags1 00
$OEM_Display_Flags1 00
$OEM_Mode_X1 00 00
$OEM_Mode_Y1 00 00
$OEM_Mode_Color1 07
$OEM_Mode_RRate1 3C
PAGE DTD
TABLE $OEM_Mode_DTD1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE OEM Mode #2
$OEM_Mode_Flags2 00
$OEM_Display_Flags2 00
$OEM_Mode_X2 00 00
$OEM_Mode_Y2 00 00
$OEM_Mode_Color2 07
$OEM_Mode_RRate2 3C
PAGE DTD
TABLE $OEM_Mode_DTD2 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE OEM Mode #3
$OEM_Mode_Flags3 00
$OEM_Display_Flags3 00
$OEM_Mode_X3 00 00
$OEM_Mode_Y3 00 00
$OEM_Mode_Color3 07
$OEM_Mode_RRate3 3C
PAGE DTD
TABLE $OEM_Mode_DTD3 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE OEM Mode #4
$OEM_Mode_Flags4 00
$OEM_Display_Flags4 00
$OEM_Mode_X4 00 00
$OEM_Mode_Y4 00 00
$OEM_Mode_Color4 07
$OEM_Mode_RRate4 3C
PAGE DTD
TABLE $OEM_Mode_DTD4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE OEM Mode #5
$OEM_Mode_Flags5 00
$OEM_Display_Flags5 00
$OEM_Mode_X5 00 00
$OEM_Mode_Y5 00 00
$OEM_Mode_Color5 07
$OEM_Mode_RRate5 3C
PAGE DTD
TABLE $OEM_Mode_DTD5 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE OEM Mode #6
$OEM_Mode_Flags6 00
$OEM_Display_Flags6 00
$OEM_Mode_X6 00 00
$OEM_Mode_Y6 00 00
$OEM_Mode_Color6 07
$OEM_Mode_RRate6 3C
PAGE DTD
TABLE $OEM_Mode_DTD6 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE Integrated HDMI/DisplayPort Configuration with External Connectors
PAGE Device 1
$Int_EFP1_Type D6 60
$Int_EFP1_Port 01
$Int_EFP1_DDC_Pin 05
$Int_EFP1_AUX_Channel 00
$Int_EFP1_HDMI_LS_Type 04
$Int_EFP1_Port_Dockable 00
PAGE Select DisplayPort Redriver Configuration ( Dock/ OnBoard )
$Int_EFP1_OnBoard_Redriver_Present 00
$Int_EFP1_OnBoard_Pre_emphasis 00
$Int_EFP1_OnBoard_Voltage_swing 02
$Int_EFP1_Dock_Redriver_Present 00
$Int_EFP1_Dock_Pre_emphasis 00
$Int_EFP1_Dock_Voltage_swing 02
PAGE Device 2
$Int_EFP2_Type D2 60
$Int_EFP2_Port 00
$Int_EFP2_DDC_Pin 00
$Int_EFP2_AUX_Channel 00
$Int_EFP2_HDMI_LS_Type 04
$Int_EFP2_Port_Dockable 00
$Int_EFP2_OnBoard_Redriver_Present 00
$Int_EFP2_OnBoard_Pre_emphasis 00
$Int_EFP2_OnBoard_Voltage_swing 02
$Int_EFP2_Dock_Redriver_Present 00
$Int_EFP2_Dock_Pre_emphasis 00
$Int_EFP2_Dock_Voltage_swing 02
PAGE Device 3
$Int_EFP3_Type D6 60
$Int_EFP3_Port 00
$Int_EFP3_DDC_Pin 00
$Int_EFP3_AUX_Channel 00
$Int_EFP3_HDMI_LS_Type 04
$Int_EFP3_Port_Dockable 00
$Int_EFP3_OnBoard_Redriver_Present 00
$Int_EFP3_OnBoard_Pre_emphasis 00
$Int_EFP3_OnBoard_Voltage_swing 02
$Int_EFP3_Dock_Redriver_Present 00
$Int_EFP3_Dock_Pre_emphasis 00
$Int_EFP3_Dock_Voltage_swing 02
PAGE Motherboard-Down SDVO Devices
PAGE Device 1
$Dev1_Type 00 00
$Dev1_DVO 01
$Dev1_I2C_Pin 05
$Dev1_Slave_Add 70
$Dev1_I2CSpeed 03
$Dev1_DDC_Pin 1D
PAGE Dot Clock Override Table
TABLE $Clock_Override_Table 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE LFP Configuration
$LVDS_Config 01
PAGE LFP (Integrated LVDS) Features
PAGE LVDS Dot Clock Override Table
TABLE $LVDS_Clock_Override_Tbl 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE LFP Display Configuration
$bmp_Panel_type 0C
$bmp_Panel_EDID 01
PAGE Panel #1
STRING $Panel_Name_01 LFP_PanelName
$Panel_Width_01 80 02
$Panel_Height_01 E0 01
$Int_LVDS_Panel_1_Channel_Type 00
$INT_Panel_Color_Depth01 00
$Enable_SSC01 00
$Disable_SSC_DDT01 00
$DPS_Panel_Type_01 00
$Blt_Control_01 00
PAGE Panel Power Sequencing
$Power_On_Backlight_Enable_Delay_01 D0 07
$PowerUpDelay_01 58 02
$Power_Backlight_Off_Power_Down_Delay_01 D0 07
$PowerDownDelay_01 F4 01
$PowerCycleDelay_01 05
PAGE DTD Timings
TABLE $DVO_Tbl_01 D6 09 80 90 20 E0 1D 10 08 60 22 00 00 00 00 00 00 1E
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_01 36 7F 01 00 01 00 00 00 00 0C
PAGE Backlight Control Parameters
$BLC_Inv_Type_1 02
$BLC_Inv_Polarity_1 00
$BLC_Min_Brightness_1 00
$POST_BL_Brightness_01 FF
$PWM_Frequency_1 10 27
PAGE Panel #2
STRING $Panel_Name_02 LFP_PanelName
$Panel_Width_02 20 03
$Panel_Height_02 58 02
$Int_LVDS_Panel_2_Channel_Type 00
$INT_Panel_Color_Depth02 00
$Enable_SSC02 00
$Disable_SSC_DDT02 00
$DPS_Panel_Type_02 00
$Blt_Control_02 00
$Power_On_Backlight_Enable_Delay_02 D0 07
$PowerUpDelay_02 58 02
$Power_Backlight_Off_Power_Down_Delay_02 D0 07
$PowerDownDelay_02 F4 01
$PowerCycleDelay_02 05
PAGE DTD Timings
TABLE $DVO_Tbl_02 A0 0F 20 00 31 58 1C 20 28 80 14 00 00 00 00 00 00 1E
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_02 36 7F 02 00 02 00 00 00 00 0C
$BLC_Inv_Type_2 02
$BLC_Inv_Polarity_2 00
$BLC_Min_Brightness_2 00
$POST_BL_Brightness_02 FF
$PWM_Frequency_2 C8 00
PAGE Panel #3
STRING $Panel_Name_03 LFP_PanelName
$Panel_Width_03 00 04
$Panel_Height_03 00 03
$Int_LVDS_Panel_3_Channel_Type 00
$INT_Panel_Color_Depth03 00
$Enable_SSC03 00
$Disable_SSC_DDT03 00
$DPS_Panel_Type_03 00
$Blt_Control_03 00
$Power_On_Backlight_Enable_Delay_03 D0 07
$PowerUpDelay_03 58 02
$Power_Backlight_Off_Power_Down_Delay_03 D0 07
$PowerDownDelay_03 F4 01
$PowerCycleDelay_03 05
PAGE DTD Timings
TABLE $DVO_Tbl_03 64 19 00 40 41 00 26 30 18 88 36 00 00 00 00 00 00 18
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_03 36 7F 03 00 03 00 00 00 00 0C
$BLC_Inv_Type_3 02
$BLC_Inv_Polarity_3 00
$BLC_Min_Brightness_3 00
$POST_BL_Brightness_03 FF
$PWM_Frequency_3 C8 00
PAGE Panel #4
STRING $Panel_Name_04 LFP_PanelName
$Panel_Width_04 00 05
$Panel_Height_04 00 04
$Int_LVDS_Panel_4_Channel_Type 00
$INT_Panel_Color_Depth04 00
$Enable_SSC04 00
$Disable_SSC_DDT04 00
$DPS_Panel_Type_04 00
$Blt_Control_04 00
$Power_On_Backlight_Enable_Delay_04 D0 07
$PowerUpDelay_04 58 02
$Power_Backlight_Off_Power_Down_Delay_04 D0 07
$PowerDownDelay_04 F4 01
$PowerCycleDelay_04 05
PAGE DTD Timings
TABLE $DVO_Tbl_04 30 2A 00 98 51 00 30 40 30 70 13 00 00 00 00 00 00 1E
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_04 36 7F 05 00 04 00 00 00 00 0C
$BLC_Inv_Type_4 02
$BLC_Inv_Polarity_4 00
$BLC_Min_Brightness_4 00
$POST_BL_Brightness_04 FF
$PWM_Frequency_4 C8 00
PAGE Panel #5
STRING $Panel_Name_05 LFP_PanelName
$Panel_Width_05 78 05
$Panel_Height_05 1A 04
$Int_LVDS_Panel_5_Channel_Type 00
$INT_Panel_Color_Depth05 00
$Enable_SSC05 00
$Disable_SSC_DDT05 00
$DPS_Panel_Type_05 00
$Blt_Control_05 00
$Power_On_Backlight_Enable_Delay_05 D0 07
$PowerUpDelay_05 58 02
$Power_Backlight_Off_Power_Down_Delay_05 D0 07
$PowerDownDelay_05 F4 01
$PowerCycleDelay_05 05
PAGE DTD Timings
TABLE $DVO_Tbl_05 30 2A 78 20 51 1A 10 40 10 70 13 00 00 00 00 00 00 1E
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_05 36 7F 01 90 05 00 00 00 00 0C
$BLC_Inv_Type_5 02
$BLC_Inv_Polarity_5 00
$BLC_Min_Brightness_5 00
$POST_BL_Brightness_05 FF
$PWM_Frequency_5 C8 00
PAGE Panel #6
STRING $Panel_Name_06 LFP_PanelName
$Panel_Width_06 78 05
$Panel_Height_06 1A 04
$Int_LVDS_Panel_6_Channel_Type 00
$INT_Panel_Color_Depth06 00
$Enable_SSC06 00
$Disable_SSC_DDT06 00
$DPS_Panel_Type_06 00
$Blt_Control_06 00
$Power_On_Backlight_Enable_Delay_06 D0 07
$PowerUpDelay_06 58 02
$Power_Backlight_Off_Power_Down_Delay_06 D0 07
$PowerDownDelay_06 F4 01
$PowerCycleDelay_06 05
PAGE DTD Timings
TABLE $DVO_Tbl_06 A8 2F 78 E0 51 1A 26 40 58 98 13 00 00 00 00 00 00 1E
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_06 36 7F 01 90 06 00 00 00 00 0C
$BLC_Inv_Type_6 02
$BLC_Inv_Polarity_6 00
$BLC_Min_Brightness_6 00
$POST_BL_Brightness_06 FF
$PWM_Frequency_6 C8 00
PAGE Panel #7
STRING $Panel_Name_07 LFP_PanelName
$Panel_Width_07 40 06
$Panel_Height_07 B0 04
$Int_LVDS_Panel_7_Channel_Type 00
$INT_Panel_Color_Depth07 00
$Enable_SSC07 00
$Disable_SSC_DDT07 00
$DPS_Panel_Type_07 00
$Blt_Control_07 00
$Power_On_Backlight_Enable_Delay_07 D0 07
$PowerUpDelay_07 58 02
$Power_Backlight_Off_Power_Down_Delay_07 D0 07
$PowerDownDelay_07 F4 01
$PowerCycleDelay_07 05
PAGE DTD Timings
TABLE $DVO_Tbl_07 48 3F 40 30 62 B0 32 40 40 C0 13 00 00 00 00 00 00 1E
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_07 36 7F 06 00 07 00 00 00 00 0C
$BLC_Inv_Type_7 02
$BLC_Inv_Polarity_7 00
$BLC_Min_Brightness_7 00
$POST_BL_Brightness_07 FF
$PWM_Frequency_7 C8 00
PAGE Panel #8
STRING $Panel_Name_08 LFP_PanelName
$Panel_Width_08 56 05
$Panel_Height_08 00 03
$Int_LVDS_Panel_8_Channel_Type 00
$INT_Panel_Color_Depth08 00
$Enable_SSC08 00
$Disable_SSC_DDT08 00
$DPS_Panel_Type_08 00
$Blt_Control_08 00
$Power_On_Backlight_Enable_Delay_08 D0 07
$PowerUpDelay_08 58 02
$Power_Backlight_Off_Power_Down_Delay_08 D0 07
$PowerDownDelay_08 F4 01
$PowerCycleDelay_08 05
PAGE DTD Timings
TABLE $DVO_Tbl_08 66 21 56 AA 51 00 1E 30 46 90 14 00 00 00 00 00 00 18
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_08 36 7F 03 90 08 00 00 00 00 01
$BLC_Inv_Type_8 02
$BLC_Inv_Polarity_8 00
$BLC_Min_Brightness_8 00
$POST_BL_Brightness_08 FF
$PWM_Frequency_8 C8 00
PAGE Panel #9
STRING $Panel_Name_09 LFP_PanelName
$Panel_Width_09 90 06
$Panel_Height_09 1A 04
$Int_LVDS_Panel_9_Channel_Type 00
$INT_Panel_Color_Depth09 00
$Enable_SSC09 00
$Disable_SSC_DDT09 00
$DPS_Panel_Type_09 00
$Blt_Control_09 00
$Power_On_Backlight_Enable_Delay_09 D0 07
$PowerUpDelay_09 58 02
$Power_Backlight_Off_Power_Down_Delay_09 D0 07
$PowerDownDelay_09 F4 01
$PowerCycleDelay_09 05
PAGE DTD Timings
TABLE $DVO_Tbl_09 7C 2E 90 A0 60 1A 1E 40 30 20 36 00 00 00 00 00 00 1E
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_09 36 7F 04 90 09 00 00 00 00 0C
$BLC_Inv_Type_9 02
$BLC_Inv_Polarity_9 00
$BLC_Min_Brightness_9 00
$POST_BL_Brightness_09 FF
$PWM_Frequency_9 C8 00
PAGE Panel #10
STRING $Panel_Name_10 LFP_PanelName
$Panel_Width_10 80 07
$Panel_Height_10 B0 04
$Int_LVDS_Panel_10_Channel_Type 00
$INT_Panel_Color_Depth10 00
$Enable_SSC10 00
$Disable_SSC_DDT10 00
$DPS_Panel_Type_10 00
$Blt_Control_10 00
$Power_On_Backlight_Enable_Delay_10 D0 07
$PowerUpDelay_10 58 02
$Power_Backlight_Off_Power_Down_Delay_10 D0 07
$PowerDownDelay_10 F4 01
$PowerCycleDelay_10 05
PAGE DTD Timings
TABLE $DVO_Tbl_10 28 3C 80 A0 70 B0 23 40 30 20 2A 00 00 00 00 00 00 1E
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_10 36 7F 05 90 0A 00 00 00 00 0C
$BLC_Inv_Type_10 02
$BLC_Inv_Polarity_10 00
$BLC_Min_Brightness_10 00
$POST_BL_Brightness_10 FF
$PWM_Frequency_10 C8 00
PAGE Panel #11
STRING $Panel_Name_11 LFP_PanelName
$Panel_Width_11 A0 05
$Panel_Height_11 84 03
$Int_LVDS_Panel_11_Channel_Type 00
$INT_Panel_Color_Depth11 00
$Enable_SSC11 00
$Disable_SSC_DDT11 00
$DPS_Panel_Type_11 00
$Blt_Control_11 00
$Power_On_Backlight_Enable_Delay_11 D0 07
$PowerUpDelay_11 58 02
$Power_Backlight_Off_Power_Down_Delay_11 D0 07
$PowerDownDelay_11 F4 01
$PowerCycleDelay_11 05
PAGE DTD Timings
TABLE $DVO_Tbl_11 9A 29 A0 D0 51 84 22 30 50 99 17 00 00 00 00 00 00 1E
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_11 36 7F 03 00 0B 00 00 00 00 0C
$BLC_Inv_Type_11 02
$BLC_Inv_Polarity_11 00
$BLC_Min_Brightness_11 00
$POST_BL_Brightness_11 FF
$PWM_Frequency_11 C8 00
PAGE Panel #12
STRING $Panel_Name_12 LFP_PanelName
$Panel_Width_12 40 06
$Panel_Height_12 84 03
$Int_LVDS_Panel_12_Channel_Type 00
$INT_Panel_Color_Depth12 00
$Enable_SSC12 00
$Disable_SSC_DDT12 00
$DPS_Panel_Type_12 00
$Blt_Control_12 00
$Power_On_Backlight_Enable_Delay_12 D0 07
$PowerUpDelay_12 58 02
$Power_Backlight_Off_Power_Down_Delay_12 D0 07
$PowerDownDelay_12 F4 01
$PowerCycleDelay_12 05
PAGE DTD Timings
TABLE $DVO_Tbl_12 30 2A 40 C8 60 84 64 30 18 51 04 00 00 00 00 00 00 1E
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_12 36 7F 03 00 0C 00 00 00 00 0C
$BLC_Inv_Type_12 02
$BLC_Inv_Polarity_12 00
$BLC_Min_Brightness_12 00
$POST_BL_Brightness_12 FF
$PWM_Frequency_12 C8 00
PAGE Panel #13
STRING $Panel_Name_13 LFP_PanelName
$Panel_Width_13 56 05
$Panel_Height_13 00 03
$Int_LVDS_Panel_13_Channel_Type 00
$INT_Panel_Color_Depth13 00
$Enable_SSC13 01
$Disable_SSC_DDT13 00
$DPS_Panel_Type_13 02
$Blt_Control_13 00
$Power_On_Backlight_Enable_Delay_13 A0 0F
$PowerUpDelay_13 90 01
$Power_Backlight_Off_Power_Down_Delay_13 88 13
$PowerDownDelay_13 2C 01
$PowerCycleDelay_13 05
PAGE DTD Timings
TABLE $DVO_Tbl_13 9E 1B 56 78 50 00 18 30 30 20 25 00 25 A5 10 00 00 19
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_13 4C A3 00 02 FF FF FF FF 00 0C
$BLC_Inv_Type_13 02
$BLC_Inv_Polarity_13 00
$BLC_Min_Brightness_13 00
$POST_BL_Brightness_13 FF
$PWM_Frequency_13 D2 00
PAGE Panel #14
STRING $Panel_Name_14 LFP_PanelName
$Panel_Width_14 56 05
$Panel_Height_14 00 03
$Int_LVDS_Panel_14_Channel_Type 00
$INT_Panel_Color_Depth14 01
$Enable_SSC14 01
$Disable_SSC_DDT14 00
$DPS_Panel_Type_14 02
$Blt_Control_14 00
$Power_On_Backlight_Enable_Delay_14 D0 07
$PowerUpDelay_14 58 02
$Power_Backlight_Off_Power_Down_Delay_14 D0 07
$PowerDownDelay_14 2C 01
$PowerCycleDelay_14 05
PAGE DTD Timings
TABLE $DVO_Tbl_14 9E 1B 56 78 50 00 18 30 30 20 25 00 35 AE 10 00 00 19
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_14 4C A3 00 02 FF FF FF FF 00 0C
$BLC_Inv_Type_14 02
$BLC_Inv_Polarity_14 00
$BLC_Min_Brightness_14 00
$POST_BL_Brightness_14 FF
$PWM_Frequency_14 D2 00
PAGE Panel #15
STRING $Panel_Name_15 LFP_PanelName
$Panel_Width_15 40 06
$Panel_Height_15 84 03
$Int_LVDS_Panel_15_Channel_Type 00
$INT_Panel_Color_Depth15 01
$Enable_SSC15 01
$Disable_SSC_DDT15 00
$DPS_Panel_Type_15 02
$Blt_Control_15 00
$Power_On_Backlight_Enable_Delay_15 D0 07
$PowerUpDelay_15 58 02
$Power_Backlight_Off_Power_Down_Delay_15 D0 07
$PowerDownDelay_15 2C 01
$PowerCycleDelay_15 05
PAGE DTD Timings
TABLE $DVO_Tbl_15 38 27 40 C0 60 84 20 30 30 20 25 00 35 AE 10 00 00 19
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_15 4C A3 00 04 FF FF FF FF 00 0C
$BLC_Inv_Type_15 02
$BLC_Inv_Polarity_15 00
$BLC_Min_Brightness_15 00
$POST_BL_Brightness_15 FF
$PWM_Frequency_15 D2 00
PAGE Panel #16
STRING $Panel_Name_16 LFP_PanelName
$Panel_Width_16 00 08
$Panel_Height_16 00 06
$Int_LVDS_Panel_16_Channel_Type 00
$INT_Panel_Color_Depth16 00
$Enable_SSC16 00
$Disable_SSC_DDT16 00
$DPS_Panel_Type_16 00
$Blt_Control_16 00
$Power_On_Backlight_Enable_Delay_16 D0 07
$PowerUpDelay_16 58 02
$Power_Backlight_Off_Power_Down_Delay_16 D0 07
$PowerDownDelay_16 F4 01
$PowerCycleDelay_16 05
PAGE DTD Timings
TABLE $DVO_Tbl_16 29 40 00 60 80 00 13 60 10 10 11 00 00 00 00 00 00 1E
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_16 36 7F 03 00 10 00 00 00 00 0C
$BLC_Inv_Type_16 02
$BLC_Inv_Polarity_16 00
$BLC_Min_Brightness_16 00
$POST_BL_Brightness_16 FF
$PWM_Frequency_16 C8 00
PAGE Test Page 1 (General)
$SV_Wait_Timeout_Hang 00
$RelStage 01
PAGE Test Page 2 (Register Tables)
PAGE MMIO Boot Registers
TABLE $MMIO_Boot_Table 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE I/O SW Flag Registers
TABLE $SWF_IO_Table 18 00
PAGE MMIO SW Flag Registers
TABLE $SWF_MMIO_Table 40 F0 04 00 01 00 00 01 44 F0 04 00 00 00 00 00 48 F0 04 00 00 00 00 00 4C F0 04 00 00 00 03 03 50 F0 04 00 00 00 00 00 54 F0 04 00 01 00 00 00 58 F0 04 00 00 00 00 00
$Chipset 14
$Msg_Enable 01
$Single_DVI_I 00
$Int_CRT_Support 01
$DP_SSC_Enb 00
$FDI_RX_POL 00
$DPMS_AIM_Bit 01
$Allow_Boot_DVI 00
$Extd_DT_Mode 00
$Pipe_B_Boot_Display 00
$Hot_Plug_DVO 01
$Hot_Plug_CRT 01
$PM_RMPM_Enable 01
$PM_S2DDT_Enable 01
$PM_DPST_Enable 01
$PM_BLC_Enable 01
$PM_ADB_Enable 01
$PM_DRRS_Enable 01
$PM_RS_Enable 01
$PM_GPMT_Enable 01
$PM_Turbo_Enable 01
$Panel_Self_Refresh 01
$DMRRS 01
$Rot_Enable 01
PAGE TV Features
PAGE OEM Mode #1
$OEM_Mode_Flags1 00
$OEM_Mode_X1 00 00
$OEM_Mode_Y1 00 00
$OEM_Mode_Color1 07
$OEM_Mode_RRate1 3C
PAGE DTD
PAGE OEM Mode #2
$OEM_Mode_Flags2 00
$OEM_Mode_X2 00 00
$OEM_Mode_Y2 00 00
$OEM_Mode_Color2 07
$OEM_Mode_RRate2 3C
PAGE DTD
PAGE OEM Mode #3
$OEM_Mode_Flags3 00
$OEM_Mode_X3 00 00
$OEM_Mode_Y3 00 00
$OEM_Mode_Color3 07
$OEM_Mode_RRate3 3C
PAGE DTD
PAGE OEM Mode #4
$OEM_Mode_Flags4 00
$OEM_Mode_X4 00 00
$OEM_Mode_Y4 00 00
$OEM_Mode_Color4 07
$OEM_Mode_RRate4 3C
PAGE DTD
PAGE OEM Mode #5
$OEM_Mode_Flags5 00
$OEM_Mode_X5 00 00
$OEM_Mode_Y5 00 00
$OEM_Mode_Color5 07
$OEM_Mode_RRate5 3C
PAGE DTD
PAGE OEM Mode #6
$OEM_Mode_Flags6 00
$OEM_Mode_X6 00 00
$OEM_Mode_Y6 00 00
$OEM_Mode_Color6 07
$OEM_Mode_RRate6 3C
PAGE DTD
PAGE Device 1
$Int_EFP1_Port 01
PAGE Device 2
$Int_EFP2_Port 00
PAGE Device 3
$Int_EFP3_Port 00
PAGE Device 1
$Dev1_Type 00 00
$Dev1_DVO 01
$Dev1_I2C_Pin 05
$Dev1_Slave_Add 70
$Dev1_I2CSpeed 03
$Dev1_DDC_Pin 1D
$LVDS_Config 01
$bmp_Panel_type 0C
$bmp_Panel_EDID 01
PAGE Panel #1
$Enable_SSC01 00
$Blt_Control_01 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_1 02
PAGE Chromaticity Control
$Chromacity_Enable_1 00
$Override_EDID_Data_1 00
$Red_Green_1 88
$Blue_White_1 88
$Red_x_1 88
$Red_y_1 88
$Green_x_1 88
$Green_y_1 88
$Blue_x_1 88
$Blue_y_1 88
$White_x_1 88
$White_y_1 88
PAGE Panel #2
$Enable_SSC02 00
$Blt_Control_02 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_2 02
$Chromacity_Enable_2 00
$Override_EDID_Data_2 00
$Red_Green_2 88
$Blue_White_2 88
$Red_x_2 88
$Red_y_2 88
$Green_x_2 88
$Green_y_2 88
$Blue_x_2 88
$Blue_y_2 88
$White_x_2 88
$White_y_2 88
PAGE Panel #3
$Enable_SSC03 00
$Blt_Control_03 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_3 02
$Chromacity_Enable_3 00
$Override_EDID_Data_3 00
$Red_Green_3 88
$Blue_White_3 88
$Red_x_3 88
$Red_y_3 88
$Green_x_3 88
$Green_y_3 88
$Blue_x_3 88
$Blue_y_3 88
$White_x_3 88
$White_y_3 88
PAGE Panel #4
$Enable_SSC04 00
$Blt_Control_04 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_4 02
$Chromacity_Enable_4 00
$Override_EDID_Data_4 00
$Red_Green_4 88
$Blue_White_4 88
$Red_x_4 88
$Red_y_4 88
$Green_x_4 88
$Green_y_4 88
$Blue_x_4 88
$Blue_y_4 88
$White_x_4 88
$White_y_4 88
PAGE Panel #5
$Enable_SSC05 00
$Blt_Control_05 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_5 02
$Chromacity_Enable_5 00
$Override_EDID_Data_5 00
$Red_Green_5 88
$Blue_White_5 88
$Red_x_5 88
$Red_y_5 88
$Green_x_5 88
$Green_y_5 88
$Blue_x_5 88
$Blue_y_5 88
$White_x_5 88
$White_y_5 88
PAGE Panel #6
$Enable_SSC06 00
$Blt_Control_06 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_6 02
$Chromacity_Enable_6 00
$Override_EDID_Data_6 00
$Red_Green_6 88
$Blue_White_6 88
$Red_x_6 88
$Red_y_6 88
$Green_x_6 88
$Green_y_6 88
$Blue_x_6 88
$Blue_y_6 88
$White_x_6 88
$White_y_6 88
PAGE Panel #7
$Enable_SSC07 00
$Blt_Control_07 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_7 02
$Chromacity_Enable_7 00
$Override_EDID_Data_7 00
$Red_Green_7 88
$Blue_White_7 88
$Red_x_7 88
$Red_y_7 88
$Green_x_7 88
$Green_y_7 88
$Blue_x_7 88
$Blue_y_7 88
$White_x_7 88
$White_y_7 88
PAGE Panel #8
$Enable_SSC08 00
$Blt_Control_08 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_8 02
$Chromacity_Enable_8 00
$Override_EDID_Data_8 00
$Red_Green_8 88
$Blue_White_8 88
$Red_x_8 88
$Red_y_8 88
$Green_x_8 88
$Green_y_8 88
$Blue_x_8 88
$Blue_y_8 88
$White_x_8 88
$White_y_8 88
PAGE Panel #9
$Enable_SSC09 00
$Blt_Control_09 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_9 02
$Chromacity_Enable_9 00
$Override_EDID_Data_9 00
$Red_Green_9 88
$Blue_White_9 88
$Red_x_9 88
$Red_y_9 88
$Green_x_9 88
$Green_y_9 88
$Blue_x_9 88
$Blue_y_9 88
$White_x_9 88
$White_y_9 88
PAGE Panel #10
$Enable_SSC10 00
$Blt_Control_10 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_10 02
$Chromacity_Enable_10 00
$Override_EDID_Data_10 00
$Red_Green_10 88
$Blue_White_10 88
$Red_x_10 88
$Red_y_10 88
$Green_x_10 88
$Green_y_10 88
$Blue_x_10 88
$Blue_y_10 88
$White_x_10 88
$White_y_10 88
PAGE Panel #11
$Enable_SSC11 00
$Blt_Control_11 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_11 02
$Chromacity_Enable_11 00
$Override_EDID_Data_11 00
$Red_Green_11 88
$Blue_White_11 88
$Red_x_11 88
$Red_y_11 88
$Green_x_11 88
$Green_y_11 88
$Blue_x_11 88
$Blue_y_11 88
$White_x_11 88
$White_y_11 88
PAGE Panel #12
$Enable_SSC12 00
$Blt_Control_12 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_12 02
$Chromacity_Enable_12 00
$Override_EDID_Data_12 00
$Red_Green_12 88
$Blue_White_12 88
$Red_x_12 88
$Red_y_12 88
$Green_x_12 88
$Green_y_12 88
$Blue_x_12 88
$Blue_y_12 88
$White_x_12 88
$White_y_12 88
PAGE Panel #13
$Enable_SSC13 01
$Blt_Control_13 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_13 02
$Chromacity_Enable_13 00
$Override_EDID_Data_13 00
$Red_Green_13 88
$Blue_White_13 88
$Red_x_13 88
$Red_y_13 88
$Green_x_13 88
$Green_y_13 88
$Blue_x_13 88
$Blue_y_13 88
$White_x_13 88
$White_y_13 88
PAGE Panel #14
$Enable_SSC14 01
$Blt_Control_14 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_14 02
$Chromacity_Enable_14 00
$Override_EDID_Data_14 00
$Red_Green_14 88
$Blue_White_14 88
$Red_x_14 88
$Red_y_14 88
$Green_x_14 88
$Green_y_14 88
$Blue_x_14 88
$Blue_y_14 88
$White_x_14 88
$White_y_14 88
PAGE Panel #15
$Enable_SSC15 01
$Blt_Control_15 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_15 02
$Chromacity_Enable_15 00
$Override_EDID_Data_15 00
$Red_Green_15 88
$Blue_White_15 88
$Red_x_15 88
$Red_y_15 88
$Green_x_15 88
$Green_y_15 88
$Blue_x_15 88
$Blue_y_15 88
$White_x_15 88
$White_y_15 88
PAGE Panel #16
$Enable_SSC16 00
$Blt_Control_16 00
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_16 02
$Chromacity_Enable_16 00
$Override_EDID_Data_16 00
$Red_Green_16 88
$Blue_White_16 88
$Red_x_16 88
$Red_y_16 88
$Green_x_16 88
$Green_y_16 88
$Blue_x_16 88
$Blue_y_16 88
$White_x_16 88
$White_y_16 88
$RelStage 01
$Strap_Check 00
GOPs_bios.zip (1.92 MB)
@lfb6 - you may need to also update VBT when updating 164 to 174, I am not 100% sure though someone else with more knowledge in this area will have to help you sort that out.
Or, it may just be 174 is not compatible with your system for some reason.
@Lost_N_BIOS Thanks for looking at this! I obviously mixed up these terms again!
The GOP driver ist updated a long time ago, but I didn’t update the GOP VBT to the corresponding version. It was:
IVB GOP 3.0.1015, VBT 165 ==>> GOP 3.0.1030, VBT 165 - working fine.
Now I try:
IVB GOP 3.0.1030, VBT 165 ==>> GOP 3.0.1030, VBT 174 - no picture, no backlight until Windows starts (settings transfered/ GOP VBT configured precisely following @SoniX s instructions)
So the latest IVB GOP driver works with an older GOP VBT, but not with the corresponding “right” GOP VBT version.
That reminds me a little of the problem ptran3014 has with his Broxton/ Apollolake boards for piano teaching since. But I am on ‘pure’ UEFI without CSM.
Hello. I have Ice Lake laptop from chinese vendor Hasee (KingBook X57S1). Got the latest BIOS from vendor (AMI) and it still has “old” GOP driver and “old” ME regions. So, i did update ME region - thanks for tools and guides (also unlocked hidden menus) + GOP.
So currently i have latest GOP driver for Ice Lake + latest ME and unlocked settings.
The problem is VBT GOP file - on latest BIOS update it’s 228, but i found on a forum here 230 version. So, currently latest GOP working with 228 okay and i have a question - should i update to VBT to 230? If yes - only manual way is possible, right?
With using guide from start of that topic i have a problem transferring settings from 228 to 229/230 (they are equal) inside BMP > many errors related to symbols. I will attach my BIOS, in case someone can help me answer how to transfer settings correctly and update VBT. Thanks!
Link to the FULL dump from FTP tool (including ME/desc/BIOS) - https://yadi.sk/d/FXNQdWVlymX0sQ
Link to ONLY BIOS dump from FTP tool - https://yadi.sk/d/XSowJz5JwB8EzA
Link to vendor latest BIOS update (FULL) with old GOP/ME/and locked advanced settings - https://yadi.sk/d/NXuZ-9DpglojRQ
Can someone please update this VBT 203 for me to 228, or whichever is proper version above 203 for GOP 9.0.1109 w/ target being SKY/Kaby, vBIOS is already SKY/KBL 1036
https://ufile.io/0d3e5f8c
Current BIOS contents below, target Sky/Kaby Mod BIOS - I think leave vBIOS/GOP is OK, and just need updated VBT. Correct? I assume GOP SKL-CML includes/means Sky through Comet, yes?
EFI GOP Driver SKL-CML - 9.0.1109
RAW GOP VBT SKYLAKE - 203
OROM VBIOS SKL-KBL - 1036
I get about 10 warning/errors similar to below, and pushing “Yes” to continue is OK until about 10+ and then BMP crashes out
Thank you!!
@Lost_N_BIOS Last version working without errors 221. When going via 221 to 228 it gives detailed errors:
From 221 to 228 several settings disappeared, or syntax changed.
$eDP_Link_DataRate_01 00 with 0=1.62 Gbps, 1=2.7Gbps…
changed to
$eDP_Fast_Link_Training_Data_Rate_01 2A 03 with data rate replaced by frequency divided by 200kHz (see help text)
Relation of frequency to datarate isn’t completely clear to me here, but wiki (https://en.wikipedia.org/wiki/DisplayPort) suggests:
HBR (High Bit Rate): 2.70 Gbit/s bandwidth per lane (270 MHz link symbol rate)
HBR2 (High Bit Rate 2): 5.40 Gbit/s bandwidth per lane (540 MHz link symbol rate), introduced in DP 1.2
If you change these items and values for all the 16 displays you’ll still get this list:
These values are no longer in 228- delete the lines in your transfer file and it will read without errors.
If the system you’re working on might miss these values is another question… (Fast Link training seems to be disabled anyway, the power options are Windows driver related- possibly won’t matter, too. Still $LVDS_Config and $180_degree_Rotation…)
PAGE General Platform Configuration
$bmp_Dynamic_CdClock_Supported 00
$Kvmr_Session_Enable 00
PAGE UEFI GOP Driver Configuration
PAGE Child Device List
$ChildDevice1Primary 08
$ChildDevice1Secondary 00
$ChildDevice2Primary 04
$ChildDevice2Secondary 00
$ChildDevice3Primary 00
$ChildDevice3Secondary 00
$ChildDevice4Primary 00
$ChildDevice4Secondary 00
$ChildDevice5Primary 00
$ChildDevice5Secondary 00
$ChildDevice6Primary 00
$ChildDevice6Secondary 00
$ChildDevice7Primary 00
$ChildDevice7Secondary 00
$ChildDevice8Primary 00
$ChildDevice8Secondary 00
$ChildDevice9Primary 00
$ChildDevice9Secondary 00
$ChildDevice10Primary 00
$ChildDevice10Secondary 00
$ChildDevice11Primary 00
$ChildDevice11Secondary 00
$ChildDevice12Primary 00
$ChildDevice12Secondary 00
$ChildDevice13Primary 00
$ChildDevice13Secondary 00
$ChildDevice14Primary 00
$ChildDevice14Secondary 00
$ChildDevice15Primary 00
$ChildDevice15Secondary 00
$ChildDevice16Primary 00
$ChildDevice16Secondary 00
PAGE Fixed Mode Feature
$Feature_Enable 00
$X_res 00 00 00 00
$Y_res 00 00 00 00
PAGE Windows Graphics driver Configuration
$Disable_DisplayEnum 00
$Rot_Enable 01
$PM_RMPM_Enable 01
$PM_S2DDT_Enable 01
$PM_BLC_Enable 01
$PM_RS_Enable 01
$PM_Turbo_Enable 01
$Dynamic_FPS_Enable 01
PAGE ADB Response Data (Mobile only)
PAGE Integrated Display Configuration
$LFP_Device_Class 06 18
$Int_eDP_Port 0A
$Int_LFP_AUX_Channel 40
$bmp_Panel_type 0E
$bmp_Panel_EDID 01
$LFP_Lane_Reversal 00
$LFP_IBoost_Enable 00
$Int_LFP_Dp_Boost_Magnitude 00
$Int_LFP_Dual_Pipe_Ganged_Enable 00
$Int_LFP_Slave_Dvo_Port 00
PAGE Panel #01
$eDP_VSwingPreEmph_01 00
$eDP_Panel_Color_Depth_01 00
$Panel_Rotation_01 00
$Enable_SSC01 00
$Blt_Control_01 02
$LcdVcc_On_During_S0_State_01 00
$eDP_T3_Optimization_01 01
$eDP_Vcc_To_Hpd_Delay_01 D0 07
$eDP_DataOn_To_BkltEnable_Delay_01 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_01 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_01 00 00
$eDP_BkltDisable_To_DataOff_Delay_01 D0 07
$eDP_DataOff_To_PowerOff_Delay_01 F4 01
$eDP_PowerCycle_Delay_01 88 13
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_01 02
$Lfp_Pwm_Source_Selection_01 02
$BLC_Inv_Polarity_01 00
$BLC_Min_Brightness_01 00
$PWM_Frequency_01 C8 00
$Chromacity_Enable_01 00
$Override_EDID_Data_01 00
$Red_Green_01 88
$Blue_White_01 88
$Red_x_01 88
$Red_y_01 88
$Green_x_01 88
$Green_y_01 88
$Blue_x_01 88
$Blue_y_01 88
$White_x_01 88
$White_y_01 88
$Override_LUM_Data_01 00
$MinLuminance_01 00 00
$MaxFullLuminance_01 00 00
$MaxLuminance_01 00 00
$Override_Gamma_Data_01 00
$Gamma_01 FF
PAGE eDP Link Training Configuration Parameters
$eDP_Full_Link_Training_Params_Enable_01 00
$eDP_Full_Link_Train_PreEmp_01 00
$eDP_Full_Link_Train_Vswing_01 00
$eDP_Fast_Link_Training_Supported_01 00
$eDP_Link_LaneCount_01 01
$eDP_Link_PreEmp_01 00
$eDP_Link_Vswing_01 00
PAGE PSR feature
$PSR_FullLink_Enable_01 00
$PSR_Require_AUX2Wakeup_01 00
$PSR_Lines2Wait_B4LinkS3_01 00
$PSR_IdleFrames2Wait_01 00
$PSR_TP1_WaitTime_01 02 00
$PSR_TP_2_3_WaitTime_01 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_01 00
$eDP_Panel_Oui_01 00 00 00 00
$eDP_Dpcd_Base_Address_01 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_01 00 00 00 00
$eDP_Dpcd_Option_Select_01 00 00 00 00
$eDP_Dpcd_Backlight_01 00 00 00 00
$eDP_Ambient_Light_01 00 00 00 00
$eDP_Backlight_Scale_01 00 00 00 00
PAGE Power Features
$DPST_Enable_01 01
$PSR_Enable_01 01
$DRRS_Enable_01 01
$LACE_Enable_01 00
$ADT_Enable_01 00
$DMRRS_Enable_01 01
$ADB_Enable_01 01
$LACE_Status_01 00
$DPST_Aggressiveness_Profile_01 06
$LACE_Aggressiveness_Profile_01 00
PAGE Panel #02
$eDP_VSwingPreEmph_02 00
$eDP_Panel_Color_Depth_02 00
$Panel_Rotation_02 00
$Enable_SSC02 00
$Blt_Control_02 02
$LcdVcc_On_During_S0_State_02 00
$eDP_T3_Optimization_02 01
$eDP_Vcc_To_Hpd_Delay_02 D0 07
$eDP_DataOn_To_BkltEnable_Delay_02 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_02 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_02 00 00
$eDP_BkltDisable_To_DataOff_Delay_02 D0 07
$eDP_DataOff_To_PowerOff_Delay_02 F4 01
$eDP_PowerCycle_Delay_02 88 13
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_02 02
$Lfp_Pwm_Source_Selection_02 02
$BLC_Inv_Polarity_02 00
$BLC_Min_Brightness_02 00
$PWM_Frequency_02 C8 00
$Chromacity_Enable_02 00
$Override_EDID_Data_02 00
$Red_Green_02 88
$Blue_White_02 88
$Red_x_02 88
$Red_y_02 88
$Green_x_02 88
$Green_y_02 88
$Blue_x_02 88
$Blue_y_02 88
$White_x_02 88
$White_y_02 88
$Override_LUM_Data_02 00
$MinLuminance_02 00 00
$MaxFullLuminance_02 00 00
$MaxLuminance_02 00 00
$Override_Gamma_Data_02 00
$Gamma_02 FF
$eDP_Full_Link_Training_Params_Enable_02 00
$eDP_Full_Link_Train_PreEmp_02 00
$eDP_Full_Link_Train_Vswing_02 00
$eDP_Fast_Link_Training_Supported_02 00
$eDP_Fast_Link_Training_Data_Rate_02 2A 03
$eDP_Link_LaneCount_02 01
$eDP_Link_PreEmp_02 00
$eDP_Link_Vswing_02 00
PAGE PSR feature
$PSR_FullLink_Enable_02 00
$PSR_Require_AUX2Wakeup_02 00
$PSR_Lines2Wait_B4LinkS3_02 00
$PSR_IdleFrames2Wait_02 00
$PSR_TP1_WaitTime_02 02 00
$PSR_TP_2_3_WaitTime_02 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_02 00
$eDP_Panel_Oui_02 00 00 00 00
$eDP_Dpcd_Base_Address_02 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_02 00 00 00 00
$eDP_Dpcd_Option_Select_02 00 00 00 00
$eDP_Dpcd_Backlight_02 00 00 00 00
$eDP_Ambient_Light_02 00 00 00 00
$eDP_Backlight_Scale_02 00 00 00 00
PAGE Power Features
$DPST_Enable_02 01
$PSR_Enable_02 01
$DRRS_Enable_02 01
$LACE_Enable_02 00
$ADT_Enable_02 00
$DMRRS_Enable_02 01
$ADB_Enable_02 01
$LACE_Status_02 00
$DPST_Aggressiveness_Profile_02 06
$LACE_Aggressiveness_Profile_02 00
PAGE Panel #03
$eDP_VSwingPreEmph_03 00
$eDP_Panel_Color_Depth_03 00
$Panel_Rotation_03 00
$Enable_SSC03 00
$Blt_Control_03 02
$LcdVcc_On_During_S0_State_03 00
$eDP_T3_Optimization_03 01
$eDP_Vcc_To_Hpd_Delay_03 D0 07
$eDP_DataOn_To_BkltEnable_Delay_03 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_03 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_03 00 00
$eDP_BkltDisable_To_DataOff_Delay_03 D0 07
$eDP_DataOff_To_PowerOff_Delay_03 F4 01
$eDP_PowerCycle_Delay_03 88 13
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_03 02
$Lfp_Pwm_Source_Selection_03 02
$BLC_Inv_Polarity_03 00
$BLC_Min_Brightness_03 00
$PWM_Frequency_03 C8 00
$Chromacity_Enable_03 00
$Override_EDID_Data_03 00
$Red_Green_03 88
$Blue_White_03 88
$Red_x_03 88
$Red_y_03 88
$Green_x_03 88
$Green_y_03 88
$Blue_x_03 88
$Blue_y_03 88
$White_x_03 88
$White_y_03 88
$Override_LUM_Data_03 00
$MinLuminance_03 00 00
$MaxFullLuminance_03 00 00
$MaxLuminance_03 00 00
$Override_Gamma_Data_03 00
$Gamma_03 FF
$eDP_Full_Link_Training_Params_Enable_03 00
$eDP_Full_Link_Train_PreEmp_03 00
$eDP_Full_Link_Train_Vswing_03 00
$eDP_Fast_Link_Training_Supported_03 00
$eDP_Fast_Link_Training_Data_Rate_03 2A 03
$eDP_Link_LaneCount_03 01
$eDP_Link_PreEmp_03 00
$eDP_Link_Vswing_03 00
PAGE PSR feature
$PSR_FullLink_Enable_03 00
$PSR_Require_AUX2Wakeup_03 00
$PSR_Lines2Wait_B4LinkS3_03 00
$PSR_IdleFrames2Wait_03 00
$PSR_TP1_WaitTime_03 02 00
$PSR_TP_2_3_WaitTime_03 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_03 00
$eDP_Panel_Oui_03 00 00 00 00
$eDP_Dpcd_Base_Address_03 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_03 00 00 00 00
$eDP_Dpcd_Option_Select_03 00 00 00 00
$eDP_Dpcd_Backlight_03 00 00 00 00
$eDP_Ambient_Light_03 00 00 00 00
$eDP_Backlight_Scale_03 00 00 00 00
PAGE Power Features
$DPST_Enable_03 01
$PSR_Enable_03 01
$DRRS_Enable_03 01
$LACE_Enable_03 00
$ADT_Enable_03 00
$DMRRS_Enable_03 01
$ADB_Enable_03 01
$LACE_Status_03 00
$DPST_Aggressiveness_Profile_03 06
$LACE_Aggressiveness_Profile_03 00
PAGE Panel #04
$eDP_VSwingPreEmph_04 00
$eDP_Panel_Color_Depth_04 00
$Panel_Rotation_04 00
$Enable_SSC04 00
$Blt_Control_04 02
$LcdVcc_On_During_S0_State_04 00
$eDP_T3_Optimization_04 01
$eDP_Vcc_To_Hpd_Delay_04 D0 07
$eDP_DataOn_To_BkltEnable_Delay_04 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_04 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_04 00 00
$eDP_BkltDisable_To_DataOff_Delay_04 D0 07
$eDP_DataOff_To_PowerOff_Delay_04 F4 01
$eDP_PowerCycle_Delay_04 88 13
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_04 02
$Lfp_Pwm_Source_Selection_04 02
$BLC_Inv_Polarity_04 00
$BLC_Min_Brightness_04 00
$PWM_Frequency_04 C8 00
$Chromacity_Enable_04 00
$Override_EDID_Data_04 00
$Red_Green_04 88
$Blue_White_04 88
$Red_x_04 88
$Red_y_04 88
$Green_x_04 88
$Green_y_04 88
$Blue_x_04 88
$Blue_y_04 88
$White_x_04 88
$White_y_04 88
$Override_LUM_Data_04 00
$MinLuminance_04 00 00
$MaxFullLuminance_04 00 00
$MaxLuminance_04 00 00
$Override_Gamma_Data_04 00
$Gamma_04 FF
$eDP_Full_Link_Training_Params_Enable_04 00
$eDP_Full_Link_Train_PreEmp_04 00
$eDP_Full_Link_Train_Vswing_04 00
$eDP_Fast_Link_Training_Supported_04 00
$eDP_Fast_Link_Training_Data_Rate_04 2A 03
$eDP_Link_LaneCount_04 01
$eDP_Link_PreEmp_04 00
$eDP_Link_Vswing_04 00
PAGE PSR feature
$PSR_FullLink_Enable_04 00
$PSR_Require_AUX2Wakeup_04 00
$PSR_Lines2Wait_B4LinkS3_04 00
$PSR_IdleFrames2Wait_04 00
$PSR_TP1_WaitTime_04 02 00
$PSR_TP_2_3_WaitTime_04 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_04 00
$eDP_Panel_Oui_04 00 00 00 00
$eDP_Dpcd_Base_Address_04 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_04 00 00 00 00
$eDP_Dpcd_Option_Select_04 00 00 00 00
$eDP_Dpcd_Backlight_04 00 00 00 00
$eDP_Ambient_Light_04 00 00 00 00
$eDP_Backlight_Scale_04 00 00 00 00
PAGE Power Features
$DPST_Enable_04 01
$PSR_Enable_04 01
$DRRS_Enable_04 01
$LACE_Enable_04 00
$ADT_Enable_04 00
$DMRRS_Enable_04 01
$ADB_Enable_04 01
$LACE_Status_04 00
$DPST_Aggressiveness_Profile_04 06
$LACE_Aggressiveness_Profile_04 00
PAGE Panel #05
$eDP_VSwingPreEmph_05 00
$eDP_Panel_Color_Depth_05 00
$Panel_Rotation_05 00
$Enable_SSC05 00
$Blt_Control_05 02
$LcdVcc_On_During_S0_State_05 00
$eDP_T3_Optimization_05 01
$eDP_Vcc_To_Hpd_Delay_05 D0 07
$eDP_DataOn_To_BkltEnable_Delay_05 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_05 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_05 00 00
$eDP_BkltDisable_To_DataOff_Delay_05 D0 07
$eDP_DataOff_To_PowerOff_Delay_05 F4 01
$eDP_PowerCycle_Delay_05 88 13
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_05 02
$Lfp_Pwm_Source_Selection_05 02
$BLC_Inv_Polarity_05 00
$BLC_Min_Brightness_05 00
$PWM_Frequency_05 C8 00
$Chromacity_Enable_05 00
$Override_EDID_Data_05 00
$Red_Green_05 88
$Blue_White_05 88
$Red_x_05 88
$Red_y_05 88
$Green_x_05 88
$Green_y_05 88
$Blue_x_05 88
$Blue_y_05 88
$White_x_05 88
$White_y_05 88
$Override_LUM_Data_05 00
$MinLuminance_05 00 00
$MaxFullLuminance_05 00 00
$MaxLuminance_05 00 00
$Override_Gamma_Data_05 00
$Gamma_05 FF
$eDP_Full_Link_Training_Params_Enable_05 00
$eDP_Full_Link_Train_PreEmp_05 00
$eDP_Full_Link_Train_Vswing_05 00
$eDP_Fast_Link_Training_Supported_05 00
$eDP_Fast_Link_Training_Data_Rate_05 2A 03
$eDP_Link_LaneCount_05 01
$eDP_Link_PreEmp_05 00
$eDP_Link_Vswing_05 00
PAGE PSR feature
$PSR_FullLink_Enable_05 00
$PSR_Require_AUX2Wakeup_05 00
$PSR_Lines2Wait_B4LinkS3_05 00
$PSR_IdleFrames2Wait_05 00
$PSR_TP1_WaitTime_05 02 00
$PSR_TP_2_3_WaitTime_05 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_05 00
$eDP_Panel_Oui_05 00 00 00 00
$eDP_Dpcd_Base_Address_05 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_05 00 00 00 00
$eDP_Dpcd_Option_Select_05 00 00 00 00
$eDP_Dpcd_Backlight_05 00 00 00 00
$eDP_Ambient_Light_05 00 00 00 00
$eDP_Backlight_Scale_05 00 00 00 00
PAGE Power Features
$DPST_Enable_05 01
$PSR_Enable_05 01
$DRRS_Enable_05 01
$LACE_Enable_05 00
$ADT_Enable_05 00
$DMRRS_Enable_05 01
$ADB_Enable_05 01
$LACE_Status_05 00
$DPST_Aggressiveness_Profile_05 06
$LACE_Aggressiveness_Profile_05 00
PAGE Panel #06
$eDP_VSwingPreEmph_06 00
$eDP_Panel_Color_Depth_06 00
$Panel_Rotation_06 00
$Enable_SSC06 00
$Blt_Control_06 02
$LcdVcc_On_During_S0_State_06 00
$eDP_T3_Optimization_06 01
$eDP_Vcc_To_Hpd_Delay_06 D0 07
$eDP_DataOn_To_BkltEnable_Delay_06 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_06 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_06 00 00
$eDP_BkltDisable_To_DataOff_Delay_06 D0 07
$eDP_DataOff_To_PowerOff_Delay_06 F4 01
$eDP_PowerCycle_Delay_06 88 13
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_06 02
$Lfp_Pwm_Source_Selection_06 02
$BLC_Inv_Polarity_06 00
$BLC_Min_Brightness_06 00
$PWM_Frequency_06 C8 00
$Chromacity_Enable_06 00
$Override_EDID_Data_06 00
$Red_Green_06 88
$Blue_White_06 88
$Red_x_06 88
$Red_y_06 88
$Green_x_06 88
$Green_y_06 88
$Blue_x_06 88
$Blue_y_06 88
$White_x_06 88
$White_y_06 88
$Override_LUM_Data_06 00
$MinLuminance_06 00 00
$MaxFullLuminance_06 00 00
$MaxLuminance_06 00 00
$Override_Gamma_Data_06 00
$Gamma_06 FF
$eDP_Full_Link_Training_Params_Enable_06 00
$eDP_Full_Link_Train_PreEmp_06 00
$eDP_Full_Link_Train_Vswing_06 00
$eDP_Fast_Link_Training_Supported_06 00
$eDP_Fast_Link_Training_Data_Rate_06 2A 03
$eDP_Link_LaneCount_06 01
$eDP_Link_PreEmp_06 00
$eDP_Link_Vswing_06 00
PAGE PSR feature
$PSR_FullLink_Enable_06 00
$PSR_Require_AUX2Wakeup_06 00
$PSR_Lines2Wait_B4LinkS3_06 00
$PSR_IdleFrames2Wait_06 00
$PSR_TP1_WaitTime_06 02 00
$PSR_TP_2_3_WaitTime_06 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_06 00
$eDP_Panel_Oui_06 00 00 00 00
$eDP_Dpcd_Base_Address_06 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_06 00 00 00 00
$eDP_Dpcd_Option_Select_06 00 00 00 00
$eDP_Dpcd_Backlight_06 00 00 00 00
$eDP_Ambient_Light_06 00 00 00 00
$eDP_Backlight_Scale_06 00 00 00 00
PAGE Power Features
$DPST_Enable_06 01
$PSR_Enable_06 01
$DRRS_Enable_06 01
$LACE_Enable_06 00
$ADT_Enable_06 00
$DMRRS_Enable_06 01
$ADB_Enable_06 01
$LACE_Status_06 00
$DPST_Aggressiveness_Profile_06 06
$LACE_Aggressiveness_Profile_06 00
PAGE Panel #07
$eDP_VSwingPreEmph_07 00
$eDP_Panel_Color_Depth_07 00
$Panel_Rotation_07 00
$Enable_SSC07 00
$Blt_Control_07 02
$LcdVcc_On_During_S0_State_07 00
$eDP_T3_Optimization_07 01
$eDP_Vcc_To_Hpd_Delay_07 D0 07
$eDP_DataOn_To_BkltEnable_Delay_07 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_07 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_07 00 00
$eDP_BkltDisable_To_DataOff_Delay_07 D0 07
$eDP_DataOff_To_PowerOff_Delay_07 F4 01
$eDP_PowerCycle_Delay_07 88 13
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_07 02
$Lfp_Pwm_Source_Selection_07 02
$BLC_Inv_Polarity_07 00
$BLC_Min_Brightness_07 00
$PWM_Frequency_07 C8 00
$Chromacity_Enable_07 00
$Override_EDID_Data_07 00
$Red_Green_07 88
$Blue_White_07 88
$Red_x_07 88
$Red_y_07 88
$Green_x_07 88
$Green_y_07 88
$Blue_x_07 88
$Blue_y_07 88
$White_x_07 88
$White_y_07 88
$Override_LUM_Data_07 00
$MinLuminance_07 00 00
$MaxFullLuminance_07 00 00
$MaxLuminance_07 00 00
$Override_Gamma_Data_07 00
$Gamma_07 FF
$eDP_Full_Link_Training_Params_Enable_07 00
$eDP_Full_Link_Train_PreEmp_07 00
$eDP_Full_Link_Train_Vswing_07 00
$eDP_Fast_Link_Training_Supported_07 00
$eDP_Fast_Link_Training_Data_Rate_07 2A 03
$eDP_Link_LaneCount_07 01
$eDP_Link_PreEmp_07 00
$eDP_Link_Vswing_07 00
PAGE PSR feature
$PSR_FullLink_Enable_07 00
$PSR_Require_AUX2Wakeup_07 00
$PSR_Lines2Wait_B4LinkS3_07 00
$PSR_IdleFrames2Wait_07 00
$PSR_TP1_WaitTime_07 02 00
$PSR_TP_2_3_WaitTime_07 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_07 00
$eDP_Panel_Oui_07 00 00 00 00
$eDP_Dpcd_Base_Address_07 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_07 00 00 00 00
$eDP_Dpcd_Option_Select_07 00 00 00 00
$eDP_Dpcd_Backlight_07 00 00 00 00
$eDP_Ambient_Light_07 00 00 00 00
$eDP_Backlight_Scale_07 00 00 00 00
PAGE Power Features
$DPST_Enable_07 01
$PSR_Enable_07 01
$DRRS_Enable_07 01
$LACE_Enable_07 00
$ADT_Enable_07 00
$DMRRS_Enable_07 01
$ADB_Enable_07 01
$LACE_Status_07 00
$DPST_Aggressiveness_Profile_07 06
$LACE_Aggressiveness_Profile_07 00
PAGE Panel #08
$eDP_VSwingPreEmph_08 00
$eDP_Panel_Color_Depth_08 00
$Panel_Rotation_08 00
$Enable_SSC08 00
$Blt_Control_08 02
$LcdVcc_On_During_S0_State_08 00
$eDP_T3_Optimization_08 01
$eDP_Vcc_To_Hpd_Delay_08 D0 07
$eDP_DataOn_To_BkltEnable_Delay_08 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_08 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_08 00 00
$eDP_BkltDisable_To_DataOff_Delay_08 D0 07
$eDP_DataOff_To_PowerOff_Delay_08 F4 01
$eDP_PowerCycle_Delay_08 88 13
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_08 02
$Lfp_Pwm_Source_Selection_08 02
$BLC_Inv_Polarity_08 00
$BLC_Min_Brightness_08 00
$PWM_Frequency_08 C8 00
$Chromacity_Enable_08 00
$Override_EDID_Data_08 00
$Red_Green_08 88
$Blue_White_08 88
$Red_x_08 88
$Red_y_08 88
$Green_x_08 88
$Green_y_08 88
$Blue_x_08 88
$Blue_y_08 88
$White_x_08 88
$White_y_08 88
$Override_LUM_Data_08 00
$MinLuminance_08 00 00
$MaxFullLuminance_08 00 00
$MaxLuminance_08 00 00
$Override_Gamma_Data_08 00
$Gamma_08 FF
$eDP_Full_Link_Training_Params_Enable_08 00
$eDP_Full_Link_Train_PreEmp_08 00
$eDP_Full_Link_Train_Vswing_08 00
$eDP_Fast_Link_Training_Supported_08 00
$eDP_Fast_Link_Training_Data_Rate_08 2A 03
$eDP_Link_LaneCount_08 01
$eDP_Link_PreEmp_08 00
$eDP_Link_Vswing_08 00
PAGE PSR feature
$PSR_FullLink_Enable_08 00
$PSR_Require_AUX2Wakeup_08 00
$PSR_Lines2Wait_B4LinkS3_08 00
$PSR_IdleFrames2Wait_08 00
$PSR_TP1_WaitTime_08 02 00
$PSR_TP_2_3_WaitTime_08 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_08 00
$eDP_Panel_Oui_08 00 00 00 00
$eDP_Dpcd_Base_Address_08 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_08 00 00 00 00
$eDP_Dpcd_Option_Select_08 00 00 00 00
$eDP_Dpcd_Backlight_08 00 00 00 00
$eDP_Ambient_Light_08 00 00 00 00
$eDP_Backlight_Scale_08 00 00 00 00
PAGE Power Features
$DPST_Enable_08 01
$PSR_Enable_08 01
$DRRS_Enable_08 01
$LACE_Enable_08 00
$ADT_Enable_08 00
$DMRRS_Enable_08 01
$ADB_Enable_08 01
$LACE_Status_08 00
$DPST_Aggressiveness_Profile_08 06
$LACE_Aggressiveness_Profile_08 00
PAGE Panel #09
$eDP_VSwingPreEmph_09 00
$eDP_Panel_Color_Depth_09 00
$Panel_Rotation_09 00
$Enable_SSC09 00
$Blt_Control_09 02
$LcdVcc_On_During_S0_State_09 00
$eDP_T3_Optimization_09 01
$eDP_Vcc_To_Hpd_Delay_09 D0 07
$eDP_DataOn_To_BkltEnable_Delay_09 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_09 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_09 00 00
$eDP_BkltDisable_To_DataOff_Delay_09 D0 07
$eDP_DataOff_To_PowerOff_Delay_09 F4 01
$eDP_PowerCycle_Delay_09 88 13
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_09 02
$Lfp_Pwm_Source_Selection_09 02
$BLC_Inv_Polarity_09 00
$BLC_Min_Brightness_09 00
$PWM_Frequency_09 C8 00
$Chromacity_Enable_09 00
$Override_EDID_Data_09 00
$Red_Green_09 88
$Blue_White_09 88
$Red_x_09 88
$Red_y_09 88
$Green_x_09 88
$Green_y_09 88
$Blue_x_09 88
$Blue_y_09 88
$White_x_09 88
$White_y_09 88
$Override_LUM_Data_09 00
$MinLuminance_09 00 00
$MaxFullLuminance_09 00 00
$MaxLuminance_09 00 00
$Override_Gamma_Data_09 00
$Gamma_09 FF
$eDP_Full_Link_Training_Params_Enable_09 00
$eDP_Full_Link_Train_PreEmp_09 00
$eDP_Full_Link_Train_Vswing_09 00
$eDP_Fast_Link_Training_Supported_09 00
$eDP_Fast_Link_Training_Data_Rate_09 2A 03
$eDP_Link_LaneCount_09 01
$eDP_Link_PreEmp_09 00
$eDP_Link_Vswing_09 00
PAGE PSR feature
$PSR_FullLink_Enable_09 00
$PSR_Require_AUX2Wakeup_09 00
$PSR_Lines2Wait_B4LinkS3_09 00
$PSR_IdleFrames2Wait_09 00
$PSR_TP1_WaitTime_09 02 00
$PSR_TP_2_3_WaitTime_09 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_09 00
$eDP_Panel_Oui_09 00 00 00 00
$eDP_Dpcd_Base_Address_09 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_09 00 00 00 00
$eDP_Dpcd_Option_Select_09 00 00 00 00
$eDP_Dpcd_Backlight_09 00 00 00 00
$eDP_Ambient_Light_09 00 00 00 00
$eDP_Backlight_Scale_09 00 00 00 00
PAGE Power Features
$DPST_Enable_09 01
$PSR_Enable_09 01
$DRRS_Enable_09 01
$LACE_Enable_09 00
$ADT_Enable_09 00
$DMRRS_Enable_09 01
$ADB_Enable_09 01
$LACE_Status_09 00
$DPST_Aggressiveness_Profile_09 06
$LACE_Aggressiveness_Profile_09 00
PAGE Panel #10
$eDP_VSwingPreEmph_10 00
$eDP_Panel_Color_Depth_10 00
$Panel_Rotation_10 00
$Enable_SSC10 00
$Blt_Control_10 02
$LcdVcc_On_During_S0_State_10 00
$eDP_T3_Optimization_10 01
$eDP_Vcc_To_Hpd_Delay_10 D0 07
$eDP_DataOn_To_BkltEnable_Delay_10 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_10 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_10 00 00
$eDP_BkltDisable_To_DataOff_Delay_10 D0 07
$eDP_DataOff_To_PowerOff_Delay_10 F4 01
$eDP_PowerCycle_Delay_10 88 13
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_10 02
$Lfp_Pwm_Source_Selection_10 02
$Red_Green_10 88
$Blue_White_10 88
$Red_x_10 88
$Red_y_10 88
$Green_x_10 88
$Green_y_10 88
$Blue_x_10 88
$Blue_y_10 88
$White_x_10 88
$White_y_10 88
$Override_LUM_Data_10 00
$MinLuminance_10 00 00
$MaxFullLuminance_10 00 00
$MaxLuminance_10 00 00
$Override_Gamma_Data_10 00
$Gamma_10 FF
$eDP_Full_Link_Training_Params_Enable_10 00
$eDP_Full_Link_Train_PreEmp_10 00
$eDP_Full_Link_Train_Vswing_10 00
$eDP_Fast_Link_Training_Supported_10 00
$eDP_Fast_Link_Training_Data_Rate_10 2A 03
$eDP_Link_LaneCount_10 01
$eDP_Link_PreEmp_10 00
$eDP_Link_Vswing_10 00
PAGE PSR feature
$PSR_FullLink_Enable_10 00
$PSR_Require_AUX2Wakeup_10 00
$PSR_Lines2Wait_B4LinkS3_10 00
$PSR_IdleFrames2Wait_10 00
$PSR_TP1_WaitTime_10 02 00
$PSR_TP_2_3_WaitTime_10 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_10 00
$eDP_Panel_Oui_10 00 00 00 00
$eDP_Dpcd_Base_Address_10 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_10 00 00 00 00
$eDP_Dpcd_Option_Select_10 00 00 00 00
$eDP_Dpcd_Backlight_10 00 00 00 00
$eDP_Ambient_Light_10 00 00 00 00
$eDP_Backlight_Scale_10 00 00 00 00
PAGE Power Features
$DPST_Enable_10 01
$PSR_Enable_10 01
$DRRS_Enable_10 01
$LACE_Enable_10 00
$ADT_Enable_10 00
$DMRRS_Enable_10 01
$ADB_Enable_10 01
$LACE_Status_10 00
$DPST_Aggressiveness_Profile_10 06
$LACE_Aggressiveness_Profile_10 00
PAGE Panel #11
$eDP_VSwingPreEmph_11 00
$eDP_Panel_Color_Depth_11 00
$Panel_Rotation_11 00
$Enable_SSC11 00
$Blt_Control_11 02
$LcdVcc_On_During_S0_State_11 00
$eDP_T3_Optimization_11 01
$eDP_Vcc_To_Hpd_Delay_11 D0 07
$eDP_DataOn_To_BkltEnable_Delay_11 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_11 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_11 00 00
$eDP_BkltDisable_To_DataOff_Delay_11 D0 07
$eDP_DataOff_To_PowerOff_Delay_11 F4 01
$eDP_PowerCycle_Delay_11 88 13
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_11 02
$Lfp_Pwm_Source_Selection_11 02
$Red_Green_11 88
$Blue_White_11 88
$Red_x_11 88
$Red_y_11 88
$Green_x_11 88
$Green_y_11 88
$Blue_x_11 88
$Blue_y_11 88
$White_x_11 88
$White_y_11 88
$Override_LUM_Data_11 00
$MinLuminance_11 00 00
$MaxFullLuminance_11 00 00
$MaxLuminance_11 00 00
$Override_Gamma_Data_11 00
$Gamma_11 FF
$eDP_Full_Link_Training_Params_Enable_11 00
$eDP_Full_Link_Train_PreEmp_11 00
$eDP_Full_Link_Train_Vswing_11 00
$eDP_Fast_Link_Training_Supported_11 00
$eDP_Fast_Link_Training_Data_Rate_11 2A 03
$eDP_Link_LaneCount_11 01
$eDP_Link_PreEmp_11 00
$eDP_Link_Vswing_11 00
PAGE PSR feature
$PSR_FullLink_Enable_11 00
$PSR_Require_AUX2Wakeup_11 00
$PSR_Lines2Wait_B4LinkS3_11 00
$PSR_IdleFrames2Wait_11 00
$PSR_TP1_WaitTime_11 02 00
$PSR_TP_2_3_WaitTime_11 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_11 00
$eDP_Panel_Oui_11 00 00 00 00
$eDP_Dpcd_Base_Address_11 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_11 00 00 00 00
$eDP_Dpcd_Option_Select_11 00 00 00 00
$eDP_Dpcd_Backlight_11 00 00 00 00
$eDP_Ambient_Light_11 00 00 00 00
$eDP_Backlight_Scale_11 00 00 00 00
PAGE Power Features
$DPST_Enable_11 01
$PSR_Enable_11 01
$DRRS_Enable_11 01
$LACE_Enable_11 00
$ADT_Enable_11 00
$DMRRS_Enable_11 01
$ADB_Enable_11 01
$LACE_Status_11 00
$DPST_Aggressiveness_Profile_11 06
$LACE_Aggressiveness_Profile_11 00
PAGE Panel #12
$eDP_VSwingPreEmph_12 00
$eDP_Panel_Color_Depth_12 00
$Panel_Rotation_12 00
$Enable_SSC12 00
$Blt_Control_12 02
$LcdVcc_On_During_S0_State_12 00
$eDP_T3_Optimization_12 01
$eDP_Vcc_To_Hpd_Delay_12 D0 07
$eDP_DataOn_To_BkltEnable_Delay_12 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_12 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_12 00 00
$eDP_BkltDisable_To_DataOff_Delay_12 D0 07
$eDP_DataOff_To_PowerOff_Delay_12 F4 01
$eDP_PowerCycle_Delay_12 88 13
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_12 02
$Lfp_Pwm_Source_Selection_12 02
$Red_Green_12 88
$Blue_White_12 88
$Red_x_12 88
$Red_y_12 88
$Green_x_12 88
$Green_y_12 88
$Blue_x_12 88
$Blue_y_12 88
$White_x_12 88
$White_y_12 88
$Override_LUM_Data_12 00
$MinLuminance_12 00 00
$MaxFullLuminance_12 00 00
$MaxLuminance_12 00 00
$Override_Gamma_Data_12 00
$Gamma_12 FF
$eDP_Full_Link_Training_Params_Enable_12 00
$eDP_Full_Link_Train_PreEmp_12 00
$eDP_Full_Link_Train_Vswing_12 00
$eDP_Fast_Link_Training_Supported_12 00
$eDP_Fast_Link_Training_Data_Rate_12 2A 03
$eDP_Link_LaneCount_12 01
$eDP_Link_PreEmp_12 00
$eDP_Link_Vswing_12 00
PAGE PSR feature
$PSR_FullLink_Enable_12 00
$PSR_Require_AUX2Wakeup_12 00
$PSR_Lines2Wait_B4LinkS3_12 00
$PSR_IdleFrames2Wait_12 00
$PSR_TP1_WaitTime_12 02 00
$PSR_TP_2_3_WaitTime_12 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_12 00
$eDP_Panel_Oui_12 00 00 00 00
$eDP_Dpcd_Base_Address_12 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_12 00 00 00 00
$eDP_Dpcd_Option_Select_12 00 00 00 00
$eDP_Dpcd_Backlight_12 00 00 00 00
$eDP_Ambient_Light_12 00 00 00 00
$eDP_Backlight_Scale_12 00 00 00 00
PAGE Power Features
$DPST_Enable_12 01
$PSR_Enable_12 01
$DRRS_Enable_12 01
$LACE_Enable_12 00
$ADT_Enable_12 00
$DMRRS_Enable_12 01
$ADB_Enable_12 01
$LACE_Status_12 00
$DPST_Aggressiveness_Profile_12 06
$LACE_Aggressiveness_Profile_12 00
PAGE Panel #13
$Panel_Width_13 00 04
$eDP_VSwingPreEmph_13 00
$eDP_Panel_Color_Depth_13 00
$Panel_Rotation_13 00
$Enable_SSC13 00
$DPS_Panel_Type_13 00
$Blt_Control_13 02
$LcdVcc_On_During_S0_State_13 00
$eDP_T3_Optimization_13 01
$eDP_Vcc_To_Hpd_Delay_13 D0 07
$eDP_DataOn_To_BkltEnable_Delay_13 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_13 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_13 00 00
$eDP_BkltDisable_To_DataOff_Delay_13 D0 07
$eDP_DataOff_To_PowerOff_Delay_13 F4 01
$eDP_PowerCycle_Delay_13 88 13
PAGE DTD Timings
TABLE $DVO_Tbl_13 64 19 00 40 41 00 26 30 18 88 36 00 00 00 00 00 00 1E
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_13 36 7F 03 00 0D 00 00 00 00 0C
$BLC_Inv_Type_13 02
$Lfp_Pwm_Source_Selection_13 02
$PWM_Frequency_13 C8 00
$Red_Green_13 88
$Blue_White_13 88
$Red_x_13 88
$Red_y_13 88
$Green_x_13 88
$Green_y_13 88
$Blue_x_13 88
$Blue_y_13 88
$White_x_13 88
$White_y_13 88
$Override_LUM_Data_13 00
$MinLuminance_13 00 00
$MaxFullLuminance_13 00 00
$MaxLuminance_13 00 00
$Override_Gamma_Data_13 00
$Gamma_13 FF
$eDP_Full_Link_Training_Params_Enable_13 00
$eDP_Full_Link_Train_PreEmp_13 00
$eDP_Full_Link_Train_Vswing_13 00
$eDP_Fast_Link_Training_Supported_13 00
$eDP_Fast_Link_Training_Data_Rate_13 2A 03
$eDP_Link_LaneCount_13 01
$eDP_Link_PreEmp_13 00
$eDP_Link_Vswing_13 00
PAGE PSR feature
$PSR_FullLink_Enable_13 00
$PSR_Require_AUX2Wakeup_13 00
$PSR_Lines2Wait_B4LinkS3_13 00
$PSR_IdleFrames2Wait_13 00
$PSR_TP1_WaitTime_13 02 00
$PSR_TP_2_3_WaitTime_13 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_13 00
$eDP_Panel_Oui_13 00 00 00 00
$eDP_Dpcd_Base_Address_13 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_13 00 00 00 00
$eDP_Dpcd_Option_Select_13 00 00 00 00
$eDP_Dpcd_Backlight_13 00 00 00 00
$eDP_Ambient_Light_13 00 00 00 00
$eDP_Backlight_Scale_13 00 00 00 00
PAGE Power Features
$DPST_Enable_13 01
$PSR_Enable_13 01
$DRRS_Enable_13 01
$LACE_Enable_13 00
$ADT_Enable_13 00
$DMRRS_Enable_13 01
$ADB_Enable_13 01
$LACE_Status_13 00
$DPST_Aggressiveness_Profile_13 06
$LACE_Aggressiveness_Profile_13 00
PAGE Panel #14
$Panel_Width_14 00 05
$Panel_Height_14 20 03
$eDP_VSwingPreEmph_14 00
$eDP_Panel_Color_Depth_14 00
$Panel_Rotation_14 00
$Enable_SSC14 00
$DPS_Panel_Type_14 00
$Blt_Control_14 02
$LcdVcc_On_During_S0_State_14 00
$eDP_T3_Optimization_14 01
$eDP_Vcc_To_Hpd_Delay_14 D0 07
$eDP_DataOn_To_BkltEnable_Delay_14 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_14 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_14 00 00
$eDP_BkltDisable_To_DataOff_Delay_14 D0 07
$eDP_DataOff_To_PowerOff_Delay_14 F4 01
$eDP_PowerCycle_Delay_14 88 13
PAGE DTD Timings
TABLE $DVO_Tbl_14 EA 1A 00 A0 50 20 17 30 0C 30 43 00 00 00 00 00 00 1E
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_14 36 7F 03 90 0E 00 00 00 00 0C
$BLC_Inv_Type_14 02
$Lfp_Pwm_Source_Selection_14 02
$PWM_Frequency_14 C8 00
$Red_Green_14 88
$Blue_White_14 88
$Red_x_14 88
$Red_y_14 88
$Green_x_14 88
$Green_y_14 88
$Blue_x_14 88
$Blue_y_14 88
$White_x_14 88
$White_y_14 88
$Override_LUM_Data_14 00
$MinLuminance_14 00 00
$MaxFullLuminance_14 00 00
$MaxLuminance_14 00 00
$Override_Gamma_Data_14 00
$Gamma_14 FF
$eDP_Full_Link_Training_Params_Enable_14 00
$eDP_Full_Link_Train_PreEmp_14 00
$eDP_Full_Link_Train_Vswing_14 00
$eDP_Fast_Link_Training_Supported_14 00
$eDP_Fast_Link_Training_Data_Rate_14 2A 03
$eDP_Link_LaneCount_14 01
$eDP_Link_PreEmp_14 00
$eDP_Link_Vswing_14 00
PAGE PSR feature
$PSR_FullLink_Enable_14 00
$PSR_Require_AUX2Wakeup_14 00
$PSR_Lines2Wait_B4LinkS3_14 00
$PSR_IdleFrames2Wait_14 00
$PSR_TP1_WaitTime_14 02 00
$PSR_TP_2_3_WaitTime_14 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_14 00
$eDP_Panel_Oui_14 00 00 00 00
$eDP_Dpcd_Base_Address_14 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_14 00 00 00 00
$eDP_Dpcd_Option_Select_14 00 00 00 00
$eDP_Dpcd_Backlight_14 00 00 00 00
$eDP_Ambient_Light_14 00 00 00 00
$eDP_Backlight_Scale_14 00 00 00 00
PAGE Power Features
$DPST_Enable_14 01
$PSR_Enable_14 01
$DRRS_Enable_14 01
$LACE_Enable_14 00
$ADT_Enable_14 00
$DMRRS_Enable_14 01
$ADB_Enable_14 01
$LACE_Status_14 00
$DPST_Aggressiveness_Profile_14 06
$LACE_Aggressiveness_Profile_14 00
PAGE Panel #15
$Panel_Width_15 80 07
$Panel_Height_15 38 04
$eDP_VSwingPreEmph_15 01
$eDP_Panel_Color_Depth_15 01
$Panel_Rotation_15 00
$Enable_SSC15 00
$DPS_Panel_Type_15 00
$Blt_Control_15 02
$LcdVcc_On_During_S0_State_15 00
$eDP_T3_Optimization_15 01
$eDP_Vcc_To_Hpd_Delay_15 D0 07
$eDP_DataOn_To_BkltEnable_Delay_15 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_15 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_15 00 00
$eDP_BkltDisable_To_DataOff_Delay_15 D0 07
$eDP_DataOff_To_PowerOff_Delay_15 F4 01
$eDP_PowerCycle_Delay_15 88 13
PAGE DTD Timings
TABLE $DVO_Tbl_15 02 3A 80 18 71 38 2D 40 58 2D 36 00 00 00 00 00 00 1E
PAGE LFP PnP ID
TABLE $LVDS_PnP_ID_15 36 7F 03 00 0F 00 00 00 00 0C
$BLC_Inv_Type_15 02
$Lfp_Pwm_Source_Selection_15 02
$BLC_Min_Brightness_15 19
$PWM_Frequency_15 C8 00
$Red_Green_15 88
$Blue_White_15 88
$Red_x_15 88
$Red_y_15 88
$Green_x_15 88
$Green_y_15 88
$Blue_x_15 88
$Blue_y_15 88
$White_x_15 88
$White_y_15 88
$Override_LUM_Data_15 00
$MinLuminance_15 00 00
$MaxFullLuminance_15 00 00
$MaxLuminance_15 00 00
$Override_Gamma_Data_15 00
$Gamma_15 FF
$eDP_Full_Link_Training_Params_Enable_15 00
$eDP_Full_Link_Train_PreEmp_15 00
$eDP_Full_Link_Train_Vswing_15 00
$eDP_Fast_Link_Training_Supported_15 00
$eDP_Fast_Link_Training_Data_Rate_15 46 05
$eDP_Link_LaneCount_15 01
$eDP_Link_PreEmp_15 00
$eDP_Link_Vswing_15 00
PAGE PSR feature
$PSR_FullLink_Enable_15 00
$PSR_Require_AUX2Wakeup_15 00
$PSR_Lines2Wait_B4LinkS3_15 00
$PSR_IdleFrames2Wait_15 00
$PSR_TP1_WaitTime_15 02 00
$PSR_TP_2_3_WaitTime_15 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_15 00
$eDP_Panel_Oui_15 00 00 00 00
$eDP_Dpcd_Base_Address_15 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_15 00 00 00 00
$eDP_Dpcd_Option_Select_15 00 00 00 00
$eDP_Dpcd_Backlight_15 00 00 00 00
$eDP_Ambient_Light_15 00 00 00 00
$eDP_Backlight_Scale_15 00 00 00 00
PAGE Power Features
$DPST_Enable_15 01
$PSR_Enable_15 01
$DRRS_Enable_15 01
$LACE_Enable_15 00
$ADT_Enable_15 00
$DMRRS_Enable_15 01
$ADB_Enable_15 01
$LACE_Status_15 00
$DPST_Aggressiveness_Profile_15 06
$LACE_Aggressiveness_Profile_15 00
PAGE Panel #16
$eDP_VSwingPreEmph_16 00
$eDP_Panel_Color_Depth_16 00
$Panel_Rotation_16 00
$Enable_SSC16 00
$Blt_Control_16 02
$LcdVcc_On_During_S0_State_16 00
$eDP_T3_Optimization_16 01
$eDP_Vcc_To_Hpd_Delay_16 D0 07
$eDP_DataOn_To_BkltEnable_Delay_16 0A 00
$eDP_PwmOn_To_Bklt_Enable_Delay_16 00 00
$eDP_Bklt_Disable_To_PwmOff_Delay_16 00 00
$eDP_BkltDisable_To_DataOff_Delay_16 D0 07
$eDP_DataOff_To_PowerOff_Delay_16 F4 01
$eDP_PowerCycle_Delay_16 88 13
PAGE DTD Timings
PAGE LFP PnP ID
$BLC_Inv_Type_16 02
$Lfp_Pwm_Source_Selection_16 02
$Red_Green_16 88
$Blue_White_16 88
$Red_x_16 88
$Red_y_16 88
$Green_x_16 88
$Green_y_16 88
$Blue_x_16 88
$Blue_y_16 88
$White_x_16 88
$White_y_16 88
$Override_LUM_Data_16 00
$MinLuminance_16 00 00
$MaxFullLuminance_16 00 00
$MaxLuminance_16 00 00
$Override_Gamma_Data_16 00
$Gamma_16 FF
$eDP_Full_Link_Training_Params_Enable_16 00
$eDP_Full_Link_Train_PreEmp_16 00
$eDP_Full_Link_Train_Vswing_16 00
$eDP_Fast_Link_Training_Supported_16 00
$eDP_Fast_Link_Training_Data_Rate_16 2A 03
$eDP_Link_LaneCount_16 01
$eDP_Link_PreEmp_16 00
$eDP_Link_Vswing_16 00
PAGE PSR feature
$PSR_FullLink_Enable_16 00
$PSR_Require_AUX2Wakeup_16 00
$PSR_Lines2Wait_B4LinkS3_16 00
$PSR_IdleFrames2Wait_16 00
$PSR_TP1_WaitTime_16 02 00
$PSR_TP_2_3_WaitTime_16 02 00
PAGE Apical Feature
$eDP_Apical_Display_Ip_Enable_16 00
$eDP_Panel_Oui_16 00 00 00 00
$eDP_Dpcd_Base_Address_16 00 00 00 00
$eDP_Dpcd_Irdidix_Control0_16 00 00 00 00
$eDP_Dpcd_Option_Select_16 00 00 00 00
$eDP_Dpcd_Backlight_16 00 00 00 00
$eDP_Ambient_Light_16 00 00 00 00
$eDP_Backlight_Scale_16 00 00 00 00
PAGE Power Features
$DPST_Enable_16 01
$PSR_Enable_16 01
$DRRS_Enable_16 01
$LACE_Enable_16 00
$ADT_Enable_16 00
$DMRRS_Enable_16 01
$ADB_Enable_16 01
$LACE_Status_16 00
$DPST_Aggressiveness_Profile_16 06
$LACE_Aggressiveness_Profile_16 00
PAGE Integrated DisplayPort/HDMI Configuration with External Connectors
$DP_SSC_Enb 00
$DP_SSC_Dongle_Enb 00
PAGE Device 1 (EFP1)
$Int_EFP1_Type D2 60
$Int_EFP1_Port 01
$Int_EFP1_HDMI_LS_Type 00
$Int_EFP1_IBoost_Enable 00
$Int_EFP1_Dp_Boost_Magnitude 00
$Int_EFP1_Hdmi_Boost_Magnitude 02
$EFP1_EDIDless_en 00
$LSPcon1_Options 00
$EFP1_Lane_Reversal 00
$EFP1_USB_C_DongleFeature_Enabled 00
$EFP1_DP_Port_Trace_Length 00
PAGE EDID-less EFP Panel DTD Timings
TABLE $EFP1_DTD D6 09 80 90 20 E0 1D 10 08 60 22 00 00 00 00 00 00 1E
PAGE Device 2 (EFP2)
$Int_EFP2_Type 00 00
$Int_EFP2_Port 00
$Int_EFP2_HDMI_LS_Type 08
$Int_EFP2_IBoost_Enable 00
$Int_EFP2_Dp_Boost_Magnitude 00
$Int_EFP2_Hdmi_Boost_Magnitude 02
$EFP2_EDIDless_en 00
$LSPcon2_Options 00
$EFP2_Lane_Reversal 00
$EFP2_DP_Port_Trace_Length 00
$EFP2_USB_C_DongleFeature_Enabled 00
TABLE $EFP2_DTD D6 09 80 90 20 E0 1D 10 08 60 22 00 00 00 00 00 00 1E
PAGE Device 3 (EFP3)
$Int_EFP3_Type 00 00
$Int_EFP3_Port 00
$Int_EFP3_HDMI_LS_Type 08
$Int_EFP3_IBoost_Enable 00
$Int_EFP3_Dp_Boost_Magnitude 00
$Int_EFP3_Hdmi_Boost_Magnitude 02
$EFP3_EDIDless_en 00
$LSPcon3_Options 00
$EFP3_Lane_Reversal 00
$EFP3_DP_Port_Trace_Length 00
$EFP3_USB_C_DongleFeature_Enabled 00
TABLE $EFP3_DTD D6 09 80 90 20 E0 1D 10 08 60 22 00 00 00 00 00 00 1E
PAGE Device 4 (EFP4 for DDI-E only)
$Int_EFP4_Type 00 00
$Int_EFP4_Port 00
$Int_EFP4_AUX_Channel 00
$Int_EFP4_IBoost_Enable 00
$Int_EFP4_Dp_Boost_Magnitude 00
PAGE Display Device Toggle Lists (Mobile only)
PAGE Display Toggle List 1
TABLE $Toggle_List1 08 00 04 00 40 00 20 00 10 00 0C 00 48 00 28 00 18 00 44 00 24 00 14 00 60 00 50 00 30 00 00 00
PAGE Display Toggle List 2
TABLE $Toggle_List2 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE Display Toggle List 3
TABLE $Toggle_List3 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE Display Toggle List 4
TABLE $Toggle_List4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE Modes Removal Table
TABLE $Mode_Rem_Table 80 07 B0 04 00 FF FF 33 FF FF 80 07 A0 05 00 FF FF 33 FF FF 00 08 80 04 00 FF FF 33 FF FF 00 08 00 06 00 FF FF 33 FF FF 00 0A A0 05 00 FF FF 13 FF FF 00 0A 40 06 00 FF FF 33 FF FF 00 0A 80 07 00 FF FF 33 FF FF 00 0A 00 08 00 FF FF 33 FF FF 00 0A 38 04 00 FF FF 33 FF FF 00 0F 70 08 00 FF FF 33 FF FF 00 10 70 08 00 FF FF 33 FF FF 80 07 70 08 00 FF FF 33 FF FF 00 05 70 08 00 FF FF 33 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 FF FF
PAGE Display Configuration Removal Table (Mobile only)
TABLE $Dev_Removed_Table 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE OEM Customizable Modes
PAGE OEM Mode #1
$OEM_Mode_Flags1 00
$OEM_Display_Flags1 00
$OEM_Mode_X1 00 00
$OEM_Mode_Y1 00 00
$OEM_Mode_Color1 07
$OEM_Mode_RRate1 3C
PAGE DTD
TABLE $OEM_Mode_DTD1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE OEM Mode #2
$OEM_Mode_Flags2 00
$OEM_Display_Flags2 00
$OEM_Mode_X2 00 00
$OEM_Mode_Y2 00 00
$OEM_Mode_Color2 07
$OEM_Mode_RRate2 3C
PAGE DTD
TABLE $OEM_Mode_DTD2 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE OEM Mode #3
$OEM_Mode_Flags3 00
$OEM_Display_Flags3 00
$OEM_Mode_X3 00 00
$OEM_Mode_Y3 00 00
$OEM_Mode_Color3 07
$OEM_Mode_RRate3 3C
PAGE DTD
TABLE $OEM_Mode_DTD3 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE OEM Mode #4
$OEM_Mode_Flags4 00
$OEM_Display_Flags4 00
$OEM_Mode_X4 00 00
$OEM_Mode_Y4 00 00
$OEM_Mode_Color4 07
$OEM_Mode_RRate4 3C
PAGE DTD
TABLE $OEM_Mode_DTD4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE OEM Mode #5
$OEM_Mode_Flags5 00
$OEM_Display_Flags5 00
$OEM_Mode_X5 00 00
$OEM_Mode_Y5 00 00
$OEM_Mode_Color5 07
$OEM_Mode_RRate5 3C
PAGE DTD
TABLE $OEM_Mode_DTD5 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PAGE OEM Mode #6
$OEM_Mode_Flags6 00
$OEM_Display_Flags6 00
$OEM_Mode_X6 00 00
$OEM_Mode_Y6 00 00
$OEM_Mode_Color6 07
$OEM_Mode_RRate6 3C
PAGE DTD
TABLE $OEM_Mode_DTD6 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
@lfb6 - Thanks for your help looking at this! So 221 would be OK maybe, yes?
I’m not sure, in the VBT doc file, NONE of the versions mention going with any GOP as high as 9.0.1109, maybe I need to downgrade this too (To 9.0.1086)? This is probably the better thing to do here, I was not sure about this being SKY-CML anyway
@Lost_N_BIOS Since I just had the VBT I can only state that it works technically according to the described procedure with 221 with your VBT and the bsf 228 for SKL-KBL.
Which system does this system belong to? Are these versions you mention used with the original bios?
@lfb6 - But, you said it does not work with 228, so we’re not going there.
Original BIOS contents, as I posted initially, it’s Lenovo Y910 >>
I’m doing a SKY >> Kaby Mod, vBIOS looks OK as-is, and I assumed GOP maybe was too (if SKL-CML also included between those @ Kaby)
But, due to VBT so low and SKY only, I was going to try to upgrade it to 228 so better fit with 9.0.1109 << But, this not even in the VBT doc file either.
And since stock VBT 203 updated to 221 OK, then I think I can just downgrade GOP to 9.0.1086 and update VBT to 221, correct?
@Lost_N_BIOS There are several configurations for Y910. If it’s from this thread [Request] Lenovo IdeaCentre Y910 7th Gen microcode
the original content is
EFI GOP Driver SKL-KBL - 9.0.1045
and that’d consistent with the original bios https://support.lenovo.com/sg/en/downloads/ds118645/
203 would also fit better to 9.0.1045 according to table
Seems to be SKL-KBL, but not CML??
And if this is the bios from the mentioned thread- it seems to have a rather corrupted ME, lots of red from MEA (didn't read if you did already work on that)
