Thanks for the guide, but I’m stuck at point number 13 - "Update for Aptio 4" as there is a screenshot missing, could you fix that, or write down what file has to be selected and what option have to be checked?
My Motherboard is Asus P8Z77-V, with newest BIOS 2104. OROM version is 2132 and i wanted to update this BIOS to OROM with version 2171. I think i need a little help.
Also from what i understand from this:
I will need to manually check the changed setting - the ones which icon change to a red book in BMP:
most of these are about I2C and DDC interfaces,
Am i right about this? Also… Maybe someone would be so kind and do that for me? I’ve updated every module, but i have no idea how to update the VBIOS… I’ve attached my BIOS…
Would you please help me to update VBIOS? My original VBIOS version is 1036. I am trying to update it into 1051. I am successfully changed and flashed the updated version, but unfortunately, it still shows the vbios version 1036.
ASCII text "1036" found in 58B6E809-808B-4C26-BC0A-BFD7B770D721 at body-offset C1Fh ASCII text "1036" found in B981F167-9D2B-4CA0-82E9-63DF0E3C3BF3 at body-offset C1Fh ASCII text "1036" found in 9AECBA5E-37ED-4A37-83C7-0F73FB34B5DB at body-offset C1Fh ASCII text "1036" found in B92571E7-739B-4B2C-B6AF-CEC02A209C86 at body-offset C1Fh ASCII text "1036" found in 54D1018A-2FB1-41C1-B73D-DA1A420C1E1F at body-offset C1Fh ASCII text "1036" found in C5A4306E-E247-4ECD-A9D8-5B1985D3DCDA at body-offset C1Fh
PS If this VBIOS for a notebook or tablet, then I strongly advise not to do an update.
