New here, first post. Sorry if I’m not in the right place to post.
I will need explanation on Pci Bifurcation and other mods.
My configs: 1: Dell T7610 (no boot ahci / nvme (ok clover) / no bifurcation) 2 x Xeon 2650V2 256G ° RAM DDR3 ECC 14900
2: Fujitsu Celsuis R940 (no boot ahci / nvme (clover ok) / bifurcation ok) 2x Xeon 2650v3 192GB DDR4 2133 ECC (I look to add the boot, I’ll open another post for that one).
And as a bonus to put in the T7610 , QUAD NVMe DELL cards
in stock 3 cards and 12 X 256GB Samsung NVMe PM961
The ideal will be in raid for my personal use and an NVMe formatting bay for my work. But I’ll see later. Already if the bios could see them it would be good.
I extracted both chips with a programmer. I attach the files
Should you put together the 2 files where each one has different roles? Add the X4x4x4x4 bifurcation on this machine is it possible?
I must continue to read the various explanations on the forum to understand how to do. Thank you for help.
try it and I look forward to your feedback post the launch list picture~~~ T7810 may not use your programmer,and it even just use some software to flash well~
@Maxpower Sorry I just see the pic your show in the title!!! Did the bifurcation of the 4 nvme SSD run well? I don’t think the bifurcation has PLX chip,because the card just incharge pcie lane splitering. And did you just install the system in one of the four? I imagine that it would show 4 pata ss in the lauch list~haha
@Maxpower Sorry I just see the pic your show in the title!!! Did the bifurcation of the 4 nvme SSD run well? And did you just install the system in one of the four? I imagine that it would show 4 pata ss in the lauch list~haha
For the moment, i just test with adapter for only 1 NVME for now.
For redirection, Your mod file is for T7810? or T7610 too? I am at work for now, I test this afternoon with full quad nvme.
I have a lot of machine available, if necessary for tests or other bios if need. Do not hesitate to ask.
For redirection, Your mod file is for T7810? or T7610 too? I am at work for now, I test this afternoon with full quad nvme. It’s T7810. and I wonder how you extract the bios by the programmer? Did you need to remove the bios chip or use the clip to link with the bios chip and programmer???
About bios version,you can upgrade your bios to the newest version first.
About whether the 25l32 bios contains serial, UUID, MAC Address etc… This question I think @Lost_N_BIOS could help you. For me,I think something information would be contain in the bios.So I suggest you’d better extract it by the programmer.
If you can do the mod on this dump, I test with Quad Nvme.
The files are too different between the two dump A03 and A16 (+ 90% difference), I do not take the risk. If I compare your mod, I just see that you add a whole part at the end of the dump on a free space. [[File:Nouvelle image bitmap (2).jpg]]
What software do you use to extract and inject the module or driver. I do not know what you call it.
@Maxpower Where did you buy the bifurcation card?I don’t think it is the original accessory of the this machine. Generally,if you want four nvme ssds in bifurcation card can be showed in PC,the bifurcation card must match the particular matherboard.so it’s very common your machine could just show one ssd per bifurcation card.
hello ,@gloobox It’s not original accessory for T7610 .it’s for T5810/7810/7910 etc …
Already test in T7810 and T5810, it works perfectly, he sees the 4 discs per card. And also in other PCs that accepts the bifurcation in native (Ex: My fujitsu R940 (bifurcation ok, no boot)
Yes,these type of bifurcation cards are kind of picky that only bringing into full play on particular machine(original accessory of the machine) Btw,how your T7810 runs after flashing my modded bios? And I am fascinated by your fujitsu R940 too`haha
