@BetaTester :
Thanks for your report. It is fine, that you were able to get my latest mod+signed Intel USB 3.0 drivers properly installed.
Regarding the “UCSI USB Connector Manager” I recommend again to do a right click onto it and to choose the option “Uninstall device”. If the device comes up again after the reboot, try to update its driver by choosing the options “Update driver”
> “Search automaticly…”. Maybe Windows Update has a suitable driver for that device.
After seeing 100PIER BM results it got me thinking, I never to bother to test USB ports and got some weird results (maybe normal as I don’t/never tested before.
What I did was use a ADATA USB3.1 stick (UV128/32GB) in each port
So results are from back panel I/O Intel controller (Win10 MS driver), back panel I/O again ASMedia usb3 (1.16.41.3) and last front panel of case, goes to a ASMedia usb3.0 internal plug (P8Z77V Pro has Intel and ASMdedia usb3 internal plugs)
I get lower results on front panel even though both are ASMedai controller (I double check device manger , view by connection" that they are using right USB3 controller and not usb2.
Anyway, results below:
Intel back panel USB3
* MB/s = 1,000,000 bytes/s [SATA/600 = 600,000,000 bytes/s]
* KB = 1000 bytes, KiB = 1024 bytes
Sequential Read (Q= 32,T= 1) : 73.376 MB/s
Sequential Write (Q= 32,T= 1) : 42.075 MB/s
Random Read 4KiB (Q= 32,T= 1) : 5.957 MB/s [ 1454.3 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 0.787 MB/s [ 192.1 IOPS]
Sequential Read (T= 1) : 73.401 MB/s
Sequential Write (T= 1) : 41.942 MB/s
Random Read 4KiB (Q= 1,T= 1) : 4.303 MB/s [ 1050.5 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 0.712 MB/s [ 173.8 IOPS]
Test : 100 MiB [G: 0.1% (0.0/28.9 GiB)] (x1) [Interval=5 sec]
Date : 2018/03/11 9:45:24
OS : Windows 10 Professional [10.0 Build 15063] (x64)
ADATA back Intel usb3
ASMedia back panel port
Sequential Read (Q= 32,T= 1) : 96.846 MB/s
Sequential Write (Q= 32,T= 1) : 42.281 MB/s
Random Read 4KiB (Q= 32,T= 1) : 6.188 MB/s [ 1510.7 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 0.774 MB/s [ 189.0 IOPS]
Sequential Read (T= 1) : 95.000 MB/s
Sequential Write (T= 1) : 42.787 MB/s
Random Read 4KiB (Q= 1,T= 1) : 5.208 MB/s [ 1271.5 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 0.704 MB/s [ 171.9 IOPS]
Date : 2018/03/11 9:55:28
ADATA back ASM usb3
Last Front panel ASMedia 3.0
Sequential Read (Q= 32,T= 1) : 41.621 MB/s
Sequential Write (Q= 32,T= 1) : 33.056 MB/s
Random Read 4KiB (Q= 32,T= 1) : 4.644 MB/s [ 1133.8 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 0.626 MB/s [ 152.8 IOPS]
Sequential Read (T= 1) : 40.272 MB/s
Sequential Write (T= 1) : 32.505 MB/s
Random Read 4KiB (Q= 1,T= 1) : 3.891 MB/s [ 950.0 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 0.564 MB/s [ 137.7 IOPS]
Date : 2018/03/11 9:39:16
ADATA front ASMedia usb3
Edit: I feel dumb, should of ran multiple passes, ran front one again an all good (results are pretty random from this stick):
Sequential Read (Q= 32,T= 1) : 93.024 MB/s
Sequential Write (Q= 32,T= 1) : 41.308 MB/s
Random Read 4KiB (Q= 32,T= 1) : 6.160 MB/s [ 1503.9 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 0.777 MB/s [ 189.7 IOPS]
Sequential Read (T= 1) : 91.655 MB/s
Sequential Write (T= 1) : 40.059 MB/s
Random Read 4KiB (Q= 1,T= 1) : 4.961 MB/s [ 1211.2 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 0.701 MB/s [ 171.1 IOPS]
Date : 2018/03/11 13:32:13
EDIT by Fernando: Detailed results put into “spoilers” (to save space)
NEW AMD USB 3.0+3.1 Drivers
AMD_USB_Drivers.rar (1.61 MB)
@kgbab :
Thank you for the link to the new AMD USB 3.0/3.1 drivers!
@ all:
Update of the Start Post
Changelog:
- new: “pure” 32/64bit AMD USB 3.0 Controller and Hub Drivers v1.1.0.249 WHQL dated 05/05/2017 (for AMD H-Series Chipsets)
- new: “pure” 64bit AMD USB 3.0 Controller and Hub Drivers v2.0.0.48 WHQL dated 12/11/2017 (for AMD Zeppelin Chipsets)
- new: “pure” 32/64bit AMD USB 3.1 Controller and Hub Drivers v1.0.5.3 WHQL dated 01/22/2018
Good luck with these new AMD USB 3.0 and 3.1 drivers!
Dieter (alias Fernando)
Finally, USB works, and I can fully use my new PC ![]()
I wonder if those intel guys ever copied some files over USB… it’s a mess with the standard driver on Windows 10. Disconnects, or if powermanagement is adjustet, it simply hangs when copying.
@Controller :
Welcome to the Win-RAID Forum and thanks for your feedback!
Regards
Hello.
I downloaded your drivers and installed them…
Everything is ok
Thank you for your awesome work.
Please continue the good work!!!
Just for your information:
Before the installation I had a lot of problems with an external seagate hard drive 4tb
After the installation of your moded drivers everything is perfect
Thank you:)
@Steg :
Welcome to the Win-RAID Forum and thanks or your feedback!
Regards
Hello i seem to have a problem with the certificate the driver works well when i disable driver signature but when its on it sayw that the is a problem with the signature.I tried installing the certificate again and it says that it is already there.Windows 10 pro system.Any solution?
@Anaxagoras :
About which driver are you talking and how did you install it?
Did you import the Certificate before starting to install the driver? If yes, did you get the OS message, that the Certificate had been successfully imported?
How do you disable the driver’s signature?
The latest intel usb 3.0/3.1 driver.I had an older driver from this forum and i tried to install the latest again from this forum but it says that the windows cant allow the signature cause something is wrong.The message said that the certificate was already in the computer,i restarted holding shift and in start up settings i used number 7 to disable the force driver signature.Sorry about my english.@Fernando
@Anaxagoras :
When you open the Device Manager and look for the currently running driver of the Intel USB 3.0 Controller, which message do you get regarding its digital signature?
So you didn’t disable the digital signature of the driver, but just forced the usage of a driver, whose digital signature hasn’t been accepted by the OS.
I am very sorry i just did a reinstallation and it worked…
@Anaxagoras :
Thanks for your feedback! It is fine, that the driver works now as it should.
A new ASMedia USB3.0/3.1 version is available:
@ all:
Changelog:
- new: “pure” 32/64bit ASMedia USB 3.0/3.1 Drivers v1.16.51.1 WHQL for Win10 dated 02/06/2018 (incl. DPInst files)
- new: “pure” 32/64bit ASMedia USB 3.0/3.1 Drivers v1.16.51.1 WHQL for Win8 dated 02/06/2018
- new: “pure” 32/64bit ASMedia USB 3.0/3.1 Drivers v1.16.51.1 WHQL for Win7 dated 02/06/2018
- new: ASMedia USB 3.0+3.1 Drivers & Software Set v1.16.51.1 WHQL for Win7-10 dated 02/13/2018
Thanks to Pacman resp. Station-Drivers for the source package.
It has now to be tested, whether the old ASMedia USB 3.0/3.1 drivers v1.16.41.3 are still better than the newest v1.16.51.1 drivers. If not, I will remove the old drivers from the start post.
Please give me your feedback!
Good luck with these new ASMedia USB 3.0/3.1 drivers!
@Fernando ,
ASMedia USB 3.0/3.1: The Dpinst64 option (as administrator) (pure driver) does not work on a W10 RS3 x64 FR Home version.
Nothing does happen when trying to update from v1.16.50.1 to v1.16.51.1 , no error message. strange because we can see the job done, however the current driver version does remain in place (and working).
the "have disk" method does work without any problem.
@100PIER :
I cannot confirm your report.
Meanwhile I have tested the DPInst method successfully on 2 different system drives running Win10 x64 v1709 resp. v1803 (Test1: replacement of the generic MS USB 3.0 driver, Test2: update from v1.16.50.1 to v1.16.51.1).
Here is the proof:
@Fernando
I got the same picture as you (on the left), however no change observed. (Z370 machine test)
With the have disk method the update from v1.16.50.1 to v1.16.51.1 is accepted with a message telling that Windows can’t guarantee the support of this new version.
@100PIER :
That is really strange. Thanks for your tests and reports!
