Hi sorry for the delay… i had a long night
i tested the bios but it seems HPET is still enabled
@Kujira - This is not possible in the BIOS I sent you. Whatever the issue was that made you want it disabled should now be solved, and or lesser than before.
On modern boards and or Win10, you will always see High Precision Timer in Device manager because it’s used by other timers by windows only under that same umbrella name.
Please see my comments, info, and testing image here under change log area
There you will see how to test this, and how you should have BCDEdit useplatformclock set, in case you messed with that before/already.
you were right!
using that command line game me the lowest timers 3.580mhz
@Kujira - Nice to see Probably some time previously, you maybe disabled useplatformclock via BCDEdit trying to disable HPET or lower timers etc.
With how windows/timers work now, with BIOS disabled HPET and useplatformclock Enabled (Yes/TRUE) it’s best results that way.
@Lost_N_BIOS
sadly i have a new issue.
i tried to revert back to an older bios version just to test if it openes some hidden settings. just for test purpose
now when im trying to update to your bios that you linked me it says "check id error" or something like that and i cant update the bios
i tried to update to a clean f10 version and it worked…
what could be the issue that now i can use your bios anymore?
edit:wanted to add that im using the aorus pro wifi and not the regular aorus pro <
@Kujira - Sorry, it looks like I sent you BIOS for non-Wifi, which you should not have been able to flash in initially anyway, unless you were already using the non-wifi model BIOS
That can happen sometimes if you use @BIOS to download file from online, or use @BIOS with wrong file you downloaded (Sometimes it will not check BIOS ID).
So, I will have to make you a new BIOS for the WIFI model! Sorry, and not sure how you flashed in that first file I sent you via Qflash You should have got the error then, that you are getting now
To answer your original thought, no, if you flash back in other non-mod BIOS, anything that was hidden and revealed or changed in the mod BIOS, will be gone once you flash back in stock BIOS
So, you need BIOS from this page, with VMX and HPET Hard disabled, correct - https://www.gigabyte.com/Motherboard/Z39…support-dl-bios
What version?
Sorry for the long delay. had some real life issues ;0
anyway. yes it is what i need. F11 would be fine.
Thank you
@Kujira - No worries about delayed reply, I’m always lost and behind anyway
Due to your current BIOS/board mismatch situation, Please flash using the included modified EFIFlash 0.80
Use this command line >> Efiflash80mod.exe Z390AOPW.F11 /C /DB
http://s000.tinyupload.com/index.php?fil…569097783244951
*** For anyone else using this BIOS later on >> Simply flash via Qflash ***
so it’s not with Q flash? how exactly i do it?
@Kujira - No, you can’t Qfash it, because right now you have incorrect BIOS flashed into your board, so QFlash would tell you no
You need to make DOS Bootable USB, and flash with EFIFlash using the command I mentioned.
Here in this post #10 is my suggested way to make a bootable DOS USB stick, you can use step #1-2 ONLY (USB may look empty to you, depending on your file/folder view settings, it’s not empty)
Use F12 boot menu to choose USB (not UEFI-USB), then at CMD prompt run command I gave above
@Lost_N_BIOS
Hi, I flashed the bios and it worked!
but sadly. my gpu RGB suddenly stopped working after the bios update
no idea what to do. cant get it to work
edit:gpu rgb work after using OpenRGB
But i do have few questions regarding HPET if i may
1.with HPET disabled in BIOS. would it be better to reinstall windows?
2.I feel like the FPS is better and the Windows is snappier but it feels like windows takes abit more time to restart/shutdown - is it related?
3.what about other commands like disabledynamictick\tscyncpolicy? should i mess with them?
WinTimerTest- shows 3.5mhz for me
Thanks
Hello, I’m interested in flashing a modded BIOS because I’ve seen that old microcodes usually have better performance and with a modded BIOS you can disable/enable certain hidden settings (to boost performance).
Anyways, I have a Gigabyte Z390 Aorus Pro (NOT Wi-Fi) paired with a 9700K. I’m also running latest (F12k) BIOS version and D6 microcode.
My questions are:
Which microcode offers the best performance, oldest one or somewhere in the middle or latest? Also, does an older microcode offer better overclocking potential and stability?
Which BIOS version is best for performance? Again, does an older BIOS version offer better overclocking potential and stability?
What hidden settings are worth disabling for better performance? Right now, VT-x is hidden in my BIOS and I want it disabled.
Can someone make me a modded BIOS with best microcode and best version of BIOS and VT-x disabled?
Thanks for your help.
Im unable to find a setting to disable it , i went through every setting and have not found it , theres just vt-d but does not disable intel virtualisation for me
im on Version f11k
@Pasjidadi - I can put old microcode into latest BIOS, if that is what you want? Sorry, I don’t know what microcode offers best performance/stability etc, you’ll have to google around about that.
Latest beta or latest final is my suggestion always, I use latest beta always unless there is some known issue.
If you want Virtualization disabled, see links below for already modified BIOS. If you need some other BIOS version edited you’ll have to let me know.
@whitehurricanez - Do you need virtualization disabled? If yes, see below, if F11 BIOS would be OK for you?
F11 VMX ONLY Disabled - Non-WIFI Version [Request] Z390 AORUS PRO Disable VMX / HPET (Post #10)
F11 VMX + HPET Disabled - Non-WIFI Version [Request] Z390 AORUS PRO Disable VMX / HPET (2) (Post #20)
F11 VMX + HPET Disabled - WIFI Version >> [Request] Z390 AORUS PRO Disable VMX / HPET (2) (post #28)
If you want me to do new edit to F11k, I can, but before I do, are you sure you don’t want to use latest final BIOS or latest beta?
@Lost_N_BIOS I Dont mind as long as it works , *F12k is my current bios sorry for typo , f11 would be fine too as i was on it previously .As long as vt-x is disabled .thank you
@Lost_N_BIOS THANK YOU SO MUCH IT WORKED
your a legend for doing this free of charge .
if you have a paypal ill happily donate <3
@Lost_N_BIOS I would like the latest (F12k) BIOS with this earliest microcode: cpu906EC_plat22_ver00000084_2018-02-19_PRD_F3514131.bin and VT-x DISABLED (I won’t ever need this setting enabled so you don’t have to make it visible).
@whitehurricanez - I can do F12k mod if you want too? I’ve already done mod to this BIOS to enable RGB edit changes via BIOS using mod BIOS + secret backdoor access.
I can add VMX Disable on top of that if you want, and show you how to access the RGB stuff in BIOS?
Glad to see F11 edit is OK for you! Yes, I disabled VMX, which disabled all virtualization
Let me know if you want F12k mod too?
If yes, I will make edit on top of this mod BIOS if you don’t mind, see post #6 (or post #16 I would use, if you also want HPET disabled)
How to hard disable HPET on Aorus Z390 Pro?
Or, if you don’t care about RGB access via BIOS, I can just edit stock F12k and disable VMX?
Thank you, I really appreciate it!! I can’t do paypal, however, I will send you some info about gift card and one of the ways you can use paypal
@Pasjidadi - What is your CPU model and SSPEC or stepping, are you sure your CPU is using 906EC?
If you are looking for a pre-spectre/metldown microcode, there is none for 906EC as the fixes are baked into CPU
Would you mind edit on top of the above linked BIOS too, would that be OK? I mean the #6 one + VMX disabled and microcode you wanted?
Or, if you don’t care about RGB access via BIOS, I can just edit stock F12k and disable V + microcode you want?
@Lost_N_BIOS I have a 9700K that has P0 (P0 so you know it’s not a typo) stepping.
I don’t care about RGB control in BIOS. I want the earliest microcode for P0 stepping (the one I mentioned in the earlier post), VT-x disabled (you don’t have to make it visible) and F12k latest version for Z390 Aorus Pro (NOT Wi-Fi).
Edit: How will Windows react to the new microcode? Will I have to reinstall Windows right away? Because I’m fine with that, just wanted to know.
@Pasjidadi - OK, I will make from stock F12k, just how you mentioned
New install of windows is not required/does not matter.
Windows will react like it always does, it will replace/use it’s own microcode whenever it sees fit to do so, unless you stop that from happening via this method -post #272
** Edit >>
@Pasjidadi @whitehurricanez @yaysonbourne @Kujira
F12j - WIFI Version - VMX Disabled + Additional BIOS with VXM+HPET Disabled
http://s000.tinyupload.com/index.php?fil…517144662134980
F12k - NON-WIFI Version - VMX Disabled + Additional BIOS with VXM+HPET Disabled
F12k - NON-WIFI Version 906EC Rev 84 - VMX Disabled + Additional BIOS with VXM+HPET Disabled
http://s000.tinyupload.com/index.php?fil…603447959464979
Flash via Qflash, once done, shut down, clear CMOS, boot into BIOS, load optimized, save/apply, reboot back to BIOS to make any changes you need.
