Hello everyone,
I received an OptiPlex 7020 Micro Plus from my workplace. It was supposed to have a faulty CPU, but I discovered the issue was just the RAM. After replacing the RAM, the system is working perfectly.
However, I’ve found that Intel AMT is disabled. The chassis has a sticker that says “3-disabled”, which seems to confirm this. The BIOS/UEFI has no options to enable it. My goal is to enable Intel AMT/vPro on this machine.
Found a topic here in the forum for another model, 7010, and the board and situation seems like the same.
Here is a summary of my hardware and what I have tried so far:
System Information:
- Model: Dell OptiPlex 7020 Micro MFF PLUS (2024/2025 model)
- CPU: Intel Core i5-14500T (vPro capable)
- SPI Chip 1: Winbond W25Q128JV (16MB / 128Mbit)
- SPI Chip 2: Winbond W25R256JV (32MB / 256Mbit)
Troubleshooting Steps & Findings:
- I’m using a CH341A programmer to read the firmware.
- I was able to successfully dump the 16MB (W25Q128JV) chip. Made 3 dumps, they all seems valid and match each other.
- I was unable to dump the 32MB (W25R256JV) chip. The programmer only reads empty
FFbytes, which I believe is due to a connection issue because my connector isnt a wson8 probe. - Here is where it gets confusing:
- When I loaded my 16MB dump into the Intel Flash Image Tool (FIT), it decomposed the image successfully, showing all the ME regions.
- However, a different analysis tool initially gave me a size error on this same dump (
expected 0x3000000 not 0x1000000), suggesting the firmware was incomplete.
- Based on advice I found from forum user “lfb6” regarding this specific model, it seems Dell is using a separated firmware architecture:
- The 16MB chip holds the Flash Descriptor (FD) and the Management Engine (ME) regions.
- The 32MB chip holds only the BIOS region.
This would explain why MFIT could read my 16MB dump successfully, and also why I should not need to touch the 32MB chip to enable AMT.
My Question:
Given this situation, it seems I only need to work with my 16MB dump from the W25Q128JV chip. Is the standard “CSME Clean-up Guide” the correct procedure to follow to enable AMT in this case? I want to be absolutely sure before I flash anything back.
I cant up my 16MB dump because im a new user.
Thank you for your time and expertise!
