is v11 Canon Lake only? Is it proper for Kaby Lake?
Please have a look into the start post of this thread.
There I have clearly stated, which GopDriver version is currently the latest for systems with a KabyLake CPU.
Some corrections regarding Cannon Lake at the OP: Z390 is Coffee Lake and X399 does not exist. There are only 2 systems with Cannon Lake CPUs so far: Lenovo IdeaPad 330-15ICN and Intel NUC8i3CYSM/NUC8i3CYSN. Both systems include an i3-8121U which has no integrated graphics because it is broken on the early CNL chips. Effectively that means that currently no systems exist which work with GOP v11.
That table is not very accurate. All 300-series can run either Coffee Lake, Cannon Lake, Whisky Lake (U) or Amber Lake (Y) CPUs. We know that CFL, WSL and AML use GOP v9 and CNL uses GOP v11. All 300-series (except Z370 and H310C) use the Cannon Point (CNP) PCH. CNP was supposed to launch with Cannon Lake (CNL) but the constant delays have made Intel mess up their lineup completely. They instead launched CNP-H with CFL and it seems that CNL will only be used for mobile systems (CNP-LP) and for desktop they’ll use a different name such as Ice Lake or whatever, when 10nm process is finally ready. As for the followup to X299, the rumors point to a future X599 platform, maybe to skip AMD’s X399.
Intel RSTe RAID 4.7.0.1017
8086-2826 Intel RSTe RAID 4.7.0.1017
Intel RSTe RAID 4.7.0.1017.rar (118 KB)
@all:
Update of the start post
Changelog:
- new: “pure” Intel RSTe EFI “RaidDriver” v4.7.0.1017 without header (for DEV_2826 Intel SATA RAID Controllers)
Thanks to plutomaniac for the source file.
Good luck with this new Intel EFI RAID module!
Dieter (alias Fernando)
Hi,
Is it possible to include the .ffs files in the .rar archives? The .efi files cannot be used by the MMTool and UEFITool cannot handle compressed modules.
Anyway, Win-Raid is an excellent resource for drivers ! Donation has been made.
@olehaus :
Welcome to the Win-RAID Forum!
The problem is, that there are a lot of different FFS files for the same DXE Driver version available (due to the various GUID headers and dependencies), but only 1 single EFI file (containing the only relevant code of the DXE Driver “body”).
All EFI files, which are offered within the start post, are uncompressed and can be converted to FFS files by using the UEFITool.
By the way: The UEFITool can handle compressed BIOS files. The only thing, what cannot be done by the UEFITool, is the extraction of a compressed BIOS file as uncompressed.
Regards
Fernando
Hello,
I plan to update the firmware for IRST and IRSTe controllers on my x79 motherboard (ASUS P9X79 Pro) with UBU (UEFI BIOS Updater) v1.70 RC 10.2
Current firmware versions:
- IRST v12.7.0.1936 (should I use v12.9.0.2006 or v13.5.0.2164 ?)
- IRSTe v3.5.0.1005 (should I use v3.8.0.1029 or v5.3.0.1052 ?)
Windows 10 Device Manager:
- Intel(R) C600 series chipset SATA AHCI Controller
- PCI\VEN_8086&DEV_1D02
- DEV_2826 (RSTe mode) resp. DEV_2822 (RST mode)
- Windows Driver v5.4.9.1004 (IRSTe)
UEFITool:
- GUID: 43A0A7B3-1E92-42EF-A46D-DDC03E52CB5C
Thank you for your help!
UPDATE 1
The latest firmaware for IRSTe v5.3 doesn’t show when I copy the EFI file to UBU - it must be a different GUID.
UPDATE 2
Unfortunately, I am not able to update the IRST/IRSTe because UBU hangs on: OROM IRST DevID 2822.
More specifically, it opens MMTool and displays: “Error in opening the input module file”.
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
Disk Controller
[Current version]
EFI IRST RAID for SATA - 12.7.0.1936
OROM IRST RAID for SATA - 12.7.0.1936
OROM IRSTe RAID for SATA - 3.5.0.1005
[Available version]
EFI IRST RAID for SATA - 13.5.0.2164
1 - Update
2 - Update only RST
3 - Update only RSTe
0 - Exit to Main Menu
Choice:2
EFI IRST GUID 43A0A7B3-1E92-42EF-A46D-DDC03E52CB5C
File replaced
2
3
4
5
6
7
8
9
10
11
12
13
14
15
Disk Controller
[Current version]
[Available version]
EFI IRSTe RAID for SATA - 4.7.0.1017
1 - Update
2 - Update only RST
Choice:1
Just wanted to submit a report that I tried flashing the 16.5.x and 16.7.x RaidDriver and OROM modules on my Asus Z170 board (Maximus VIII Hero), and it did not go well. The BIOS stopped recognizing all drives connected to Intel SATA ports. The latest versions that work are 15.9.x . Definitely have full backups readily accessible if you experiment with this. Flashing 16.x.x caused my RAID array to fail, and during the course of experimenting, I had to rebuild it from scratch several times. It was worth a shot, but there you go…
Time will eventually betray us all, I suppose.
Hi everyone,
Can someone guild me where I can find the EFI IRST RAID for SATA v11? These that are listed are v13 for the 7 series and are for enterprise.
I did find the OROM IRST RAID v11 as shown below from the UBU Tool results.
Disk Controller
[Current version]
EFI IRST RAID for SATA - 11.5.0.1582
OROM IRST RAID for SATA - 11.0.0.1339
[Available version]
OROM IRST RAID for SATA - 11.2.0.1527
Any help would be appreciated.
@Spindle :
Intel has never released RST EFI RAID BIOS modules, which belong to the v11 platform.
If you want, that your on-board Intel RAID Controller uses a v11 platform BIOS module (e.g. the Intel RAID ROM v11.2.0.1527), you have to install the OS in LEGACY mode.
Regards
@all:
Changelog:
- new: “pure” Intel RST(e) EFI “RaidDriver” v15.9.2.3386 without header for DEV_2822 Intel SATA RAID Controllers)
Notes:
The Intel RST RAID ROM/EFI RaidDriver BIOS modules from the v15 platform have been designed by Intel for the latest Intel Chipsets from 100-Series up. Thanks to Pacman for the source files.
Good luck with the new Intel EFI RAID module!
@Fernando
Thank you for welcoming me to the forum.
I’m trying to update a P8Z77-V-DELUXE. (Z77 chipset)
Would you kindly recommend me which alternative version I can use?
Can I use an enterprise version instead? Example; Intel RST(e) RAID ROM v13.1.0.2126 & Intel RST(e) EFI “RaidDriver” v13.1.0.2126
Disk Controller
[Current version]
Regards,
Spindle
Hi @Fernando !
I saw tests of raid drivers here: Performance of the Intel RST/RSTe AHCI/RAID Drivers and version Intel RST(e) v15.5.5.1059 WHQL has amazing perfomance…
Do you have in your base Intel RST(e) EFI “RaidDriver” v15.5.5.1059 (without header) with RaidDriver.efi?
I found only “pure” Intel RST(e) EFI “RaidDriver” v15.5.1.3017 (without header) at the first page of the topic
@hoffer :
An Intel RST(e) EFI RAID module v15.5.5.1059 doesn’t exist and is not required for your Intel RAID system at all.
The latest Intel EFI RAID module v15.5.1.3017 is the best choice for all existing and upcoming Intel RST(e) RAID drivers, which belong to the RST v15.5 development branch.
Thanks @Fernando !
If I choose best WRITE speed (with driver v16.0.10.1104) than best READ speed what version of EFI do you suggest v16.0.1.3397 (without header) or v16.0.7.3491 (without header) ?
Or may be it is better to choose v15.5.1.3017 (without header) with best READ? But score in orange box better in v16…What is better for overall maximum perfomance?
