@kmsilva
usb2.0 drivers wont work with usb3.0 controllers
you can get pcie usb2.0 cards
https://www.aliexpress.com/item/USB-2-0-…2819465989.html
@MeTeC :
Welcome to the Win-RAID Forum!
You should import the Certificate before starting with the installation of any of my mod+signed drivers.
Regards
Dieter (alias Fernando)
@Fernando
Thanks for the answer,but should I install these drivers even if I’m running on Windows 10 ?? It’s labelled as Windows 7 only
@MeTeC :
Yes. The mod+signed Intel USB 3.0/3.1 drivers, which I am offering within the start post, do support Win10 as well.
@Fernando I have updated with this pack : https://i.imgur.com/m4GQREZ.png
I have a Z270 mobo so I though it was good.
But after this update I couldn’t get my Rift S working, the Rift S USB Hub were in the hidden devices so I just uninstalled everything.
I tried to update USB Driver because the Oculus Software told me that there was an USB Update recommended.
Do you think this actual native driver for my Intel HOST Controller USB 3.0 is a better updated version compared to your modded drivers ? https://i.imgur.com/fJfF3rz.png
@MeTeC :
If you are not satisfied with the mod+signed Intel USB drivers, you can switch to the generic MS Win10 in-box drivers. There are no other/better options.
Hi,
Greets,
Any drivers for 8086 A36D for Win 7 64 as of now ?
Update : Yes they are here : [Solution] Win7 drivers for USB 3.0/3.1 Controllers of new Intel chipset systems
Thanks & Regards. …
Hello,
what driver i can use for the Asus Rampage V Extreme?
Thanks for your help
Hi,
Greets,
Which OS ? Hardware ID ?
Anyway, full driver support for Win 7 32/64 for Asus Rampage V Extreme : https://www.asus.com/in/Motherboards/RAM…pDesk_Download/
Please select OS : Win 7 64
Thanks & Regards. …
OH sorry… i forget it to write… so i have Window 10 x64 Enterprise LTSC…
Hardware ID? What is that… and the drivers from the Asus Homepage are so old… so i think that must be newer drivers… but when not is it ok… thanks for your fast replay…
You have already installed OS & Looking for the latest driver ? Right ?
Hardware ID in the Device Manager for the OS & Device which you want to update drivers for.
Here is a small tutorial in the below link. Though it tells to look hardware ID for unknown device but in your case it is/are known device. You would be wanting to update drivers for USB Ports, so tell the Hardware ID of USB controllers.
https://www.sevenforums.com/tutorials/96…wn-devices.html
( Anyway latest is not the best & product support sites normally provide good drivers. In my opinion change the driver only if it gives problem. But it’s up to your choice! )
Hey Fernando!
After installing the certificate and the Intel USB 3.0/3.1 drivers for win10, I only get a bluescreen with error "winload.efi 0xc00000e" now.
Do you know how to fix this?
Secure boot is disabled.
Thank you!
@ristridi :
>This< article lets me doubt, that your “winload.efi” BSOD has anything to do with the installation of the mod+signed Intel USB 3.0/3.1 drivers.
Which are the HardwareIDs of your in-board Intel USB 3.0/3.1 Controller (right-click onto it > “Properties” > “Details” > “Property” > “HardwareIDs”) and how did you try to get these USB drivers installed?
Regards
Hey, I attempted installing this driver under Windows 7 (the NVIDIA USB Type-C Port Policy Controller that is included in nvppc.inf,) and it’s failing with a Code 39. How did you get this working?
@Omicron
It can work use other modified usb driver, you can use my modified intel usb driver to add the nvidia usb dev id into the *.inf and intsall it after save.
@canonkong
I was actually able to get the AMD xHCI/Hub driver working by force installing it, I didn’t even need to add the ID to the inf - it appears to work flawlessly.
@Omicron
Yes, AMD Zeppelin usb driver is a generic usb driver, almost support all usb device. But it seems that not work well with AMD 3000series CPU and X570 boards , dev_149C.
@canonkong
Where were you able to find the 2.0.0.0068 AMD Zeppelin USB driver? I’ve looked all over the place online, and couldn’t even find it within the latest 1.07.29.0115 chipset driver package directly from AMD. Thanks!
Hi,
Which usb 3.0 drivers for msi h110m pro-d will outperform my oem ones when it comes to input lag for windows 7.
Right now i use oem 5.0.4.43 from msi website , are those posted here better?
