Hi!
Does anyone know where are metadata blobs for modules (like bup.met, amt.met) in last versions of the CSME 12.0 firmware?
Intel removed the Module Metadata (.met) at CSME >= 12.0.30 firmware. They remain only at OEM-customizable LZMA compressed Modules like ish_bup or similar.
@plutomaniac
@ lost_N_bios
@ any one who can answerā¦
where to find sps Firmware Repositories for clean me?
is its method same as for me/txe for make it clean?
i attach the image & firmware also.
intel sps 02.02.00.036.rar (1.9 MB)
Thank you for the answer!
Metadata files were containing a lot of vital information to spawn processes in the system: entry point, BSS size, MMIO ranges and so on. It canāt just disappear, there needs to be a new place for such data structures. What do you think?
When 12.0.30 first appeared, I was mostly looking for the module hash and compressed size which are vital for Huffman decompression and found a structure at RBEP > rbe and FTPR > pm modules which contains some of the aforementioned info. I call it RBE_PM_Metadata at ME Analyzer and so far Iāve been able to determine these fields:
The RBE Partition (RBEP) has metadata at its modules like "rbe". Once the RBEP RSA Signature and Hash of module "rbe" are verified, it parses the RBE_PM_Metadata of "rbe" which includes, among others, the metadata of FTPR > "pm". So once FTPR is loaded, it can use the RBE_PM_Metadata of its "pm" module to get the metadata for the rest of the modules which are required for CSE operation. Basically, "rbe" verifies (among a few others) "pm" and "pm" verifies the rest. Since there is no module name field, in order to know which info corresponds to which module in FTPR, NFTP etc, the CSE probably uses the (apparently) hard-coded DEV_IDs. This is what Iāve understood at this point.
@earthoo7 - sorry I donāt have any of the v2 SPS FW files, and no we donāt have a repo for those.
Method to cleanup is similar as what you find in ME/TXE guides, but you may need to change some stuff manually too, check both side by side at each setting would be best way to do it manually.
Maybe once plutomaniac gets back he can find newer FW for you.
@plutomaniac
@Lost_N_BIOS
what stuff need to change bcoz fitc does not accept sps firmware?
pls describe if possible.
and is any universal method to edit bios logo for mostly support bios like 1 2 4 8 16mb bioses
how to find it & edit it manuallly with like uefitool?
thankyou
study 1.zip (538 KB)
@earthoo7 - You need SPS v2 FITc software, then it will work.
ME FW has nothing to do with BIOS Logo, on this I replied to your PM
Hi how are you please can you help me i have macbook with courrpt bin
when i check get error https://ibb.co/9Gcc8yJ
and i canāt find the verion of my file
CSE ME
11.8.50.3425
hello!
@plutomaniac
My mobo is ASUS P8B-C-SAS-4L,and I find itās SPS but not ME.The version is 02.02.00.42.
Would you had the repos of SPS?
Only (CS)ME, (CS)TXE, PMC and PCHC
Hi Team.
I have ME 11.7.0.3307, I guess it CON_LP_C_NPDM_PRD_EXTR in your classsification, from Voyo I7 plus tablet, I download it with fpt from one device and tried to flash to another tablet with no luck. Itās flashing but not working. From another side i can easy flash 11.8.55.3502_CON_LP_C_NPDM_PRD_EXTR.bin and it works but have couple issues.
Maybe it will be usefull for you, and even maybe you can help me flash it to another device.
https://dropmefiles.com/ppXfx
Thank you in advice. In any case.
Restore the original firmware via fpt or programmer and then read Intel Management Engine: Drivers, Firmware & System Tools to learn how to properly update the CSME firmware via FWUpdate tool.
Yes, thank you, I will.
But this one ME not included into collection of https://github.com/CHEF-KOCH/Intel-ME-Fiā¦ree/master/11.7
And I thought that it will helpful for you also.
These "collections" take firmware from repos such as this thread, combine them with stuff from SD, leave random names, dirty firmware etc. If you want help here then use whatever is found at the links of the first post.
@plutomaniac
update guide regarding Server Platform Services Firmware Repository like
how to clean sps based firmware.
manually or any tool as fitc available for this.
if can manually please update guidelines.
thankyou for your fabulous work.
@ earthoo7
(CS)SPS is provided for reference/research or for people (usually with NDA) who already have tools. Since finding (CS)SPS tools is nearly impossible and there are too many variants needed for each platform, there will be no cleanup guide instructions and no Firmware & System Tools thread for (CS)SPS.
SPS 5 seems to be new, too. (Just uploaded the region, SPS5 structure is not known to me):
sps5.zip (1.9 MB)
Yes found it yesterday as well from SuperMicro. The structure is the same as CSME 12+.
Hello. Where i can get cse txe 3.0.1.1105 firmware or repository? Thanks!
